Question about Home
I'm looking for a dishrack that has room for all my dishes and will drain well (not just make the other dishes all wet).
    New Friend:
    Problem Solver:
  • 8 Answers
I like the first one from this top ten list the best. http://www.realsimple.com/home-organizing/organizing/kitchen/dish-rack-00100000076215/index.html
Posted on Jan 14, 2013
Dishwasher washes dishes but does not dry even though that display shows dry icon
First ,Check for a water puddle on the bottom of the dishwasher .If you have water there, you more than likely have a plugged drain or drain hose, or bad drain pump (less likely) If no water is there see if the dishes are hot after a cycle. If they are not you could have a bad heater (that circular thing on the bottom of the dishwasher) other problems could be the timer or computer Depending on the model brand and age of the dishwasher .One last thing there is a vent to let moisture escape that could be bad but then you would have hot wet dishes
Aug 07, 2014 | Blomberg Dishwashers
Kenmore dishwasher leaving a lot of water on door, bottom, wall and dishes! it STINKS!
The pump could be leaking. The drain could be plugged - hence the smell. Taking a look underneath could reveal what needs to be fixed. I don't have an answer for why dishes are still wet even after a hot wash and heated dry but perhaps it is related to the other problem
Oct 22, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
I have DISH NETWORK & something happend so whatever is on in 1 room appears on my TV that I dont like how can I control ONLY my TV & fix this problem?
Brandonhusse,
It sounds like the receiver is in single mode, which will allow both TV's to show the same picture with 'Shared Viewing' enabled. On the front of the receiver should be a 'Mode' button. Press that to change it from Dual to Single or Single to Dual. The orange light on the front of the box will let you know which one it is on.
Once changed to Dual mode, try the TV's again and see if they are functioning separately. If the problem continues, let me know here or at thomas.faust@dish.com!
Tommy Faust
DISH Social Media Representative
Jun 25, 2012 | DISH Network Televison & Video
Diswasher water isn't draining?
It is most likely the drain pump. If the drain pump passes a tech's test ok, have the drain passage checked for clogs.
Apr 17, 2012 | Dishwashers
Why on model #665.7797 dishes rest wet? Looks like drying cycle was never on.
Look for an 'energy saver' switch. It may turn off the dryer heating coils. If not that, try to examine the connection to the coils.
Mar 16, 2012 | Kenmore Dishwashers
How to find a short
use key in door to disable alarm 1st, look for any corrosion those kind of shorts are in connectors
Nov 28, 2017 | Infiniti Cars & Trucks
Added a 322 reciever to my lake house to be able to watch tv in 3rd room i had 2 standard recievers before. i installed a dish pro quad lnb & reciever had a separator w/it says dp plus 123254 tuner 2...
Is TV 2 off the 322 receiver being back fed from the receiver or do you have a direct connection to the 3rd room? If it is a direct connection, you would screw the coax from the 3rd bedroom directly to the TV 2 Home Distribution channel 21-69 out port.
If you are back feeding, you need 2 diplexers that connect 1) by the receiver and 2) between the receiver and the 3rd TV. The back feeding will use the same cable coming from the dish to the receiver.
If you have any other questions, please don't hesitate to ask.
Jun 26, 2011 | DISH Network 322 DTV Receiver
Zanussi ZDT 6244 Dishwasher , wash cycle completes , all water drains out , but the dishes are not brilliant clean & dishes are still wet
Try cleaning all the jet orifices in the rotating vanes. Use tooth brush. Check for dish plate is touching the rotating arm in the wash chamber. Rotate by hand for freeness.
Mar 29, 2010 | Zanussi 24 in. DE6544 Built-in Dishwasher
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
I can't get it to work i can trun it on but thats it. i can get work
hi
could be several things,
are the dishes wet at all?
is there a puddle of water in the bottom ?
do you have children?
If the dishes are wet , then its not draining, up on top of the sink theres an aerator , pull the chrome cap straight up and under that is a white knob, unscrew that counterclockwise and look for debris, reinstall
theres a round white float inside the machine below the bottom rack near the front that can get stuck in the up position and prevent draining, grasp the float to see if you can get it to move up and down slightly, look under float for dishes/debris
look under the sink for kinked hoses with a flashlight, make sure all faucet knobs are turned on under the sink.
lastly, toddlers and small children can crank the control knob in the wrong direction, bending contact points in the timer, if thats the case , youll need a new timer..
good luck
J
Jul 11, 2008 | Dishwashers
Home Logo
486 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
