Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door won't close unless i push button on wall several times
Door won't close unless i push button several times to get it to go about 12" at a time (start & stop). wife then pulled chain to release and work by hand . I tried looking at it and pushed button, motor engages ,but chain does not move.
  • deamond311 Feb 22, 2009
    Thanks for the help u were right , bought a new opener and am going to install myself
  • 112 Answers
You probably have a stripped gear inside opener. Take off cover and the bottom will be filled with white flakes from stripped gear
Posted on Jan 29, 2009
My Craftsman garage door will not close, only a few inches at a time
have a problem which returns every year when outdoor temperatures drop close to freezing. garage door will open only a few inches, then stops. I can close it and try opening it again... same result. After five or six such attempts it typically will open. Interestingly, when I push the switch button mounted on the interior wall of my garage and keep it pushed, the door will open, until I release the button at which point it stops opening.
Dec 19, 2013 | Building Materials
My Dishwasher won't start unless I push firmly on the door.
Change the handle there is a switch on the handle that activates when the door is closed the switch is broken you have to buy the whole handle not just the switch
Apr 11, 2013 | GE Dishwashers
Chamberlain 9902 won't close at times
Does the motor run? Does it make a noise. What actually happens?
Apr 09, 2012 | Sears Craftsman LiftMaster Chamberlain...
My LG washer wont turn on, if I unplug it from the wall and plug it back in, it will work for one cycle, but then the next time I go to use it, I have to unplug it again to get it to work.
After searching for the answer as to why my LG WM2455H wouldn't start unless I unplugged it and then plugged it again, and trying many "solutions", such as holding the power and start buttons for x amount of seconds, I finally found one that worked. Just before ordering a new control panel, I decided to search one more time for an answer, and found a young man claim that his uncle told him the answer to solving the problem. It's a little weird, and I was very skeptical, as you will be, but it DID WORK to let my washer power on after running cycles of wash. Here it is: Within 12 seconds, push in the POWER button and let go, then open and close the washer door, repeat by pushing in power button again, and let it go, then immediately open and close the washer door again. Do this six times within a 12 second time span. According to the young man on youtube, this procedure RESETS the controls. I would still be a little skeptical, except my machine behaves like it's suppose to now. PLUS, I did nothing that might be attributed to the solution (except think about how I was going to move the heavy washer away from the wall to replace the Control Panel I planned to buy). So, I hope this works for you. It certainly saved me a lot of time and money.
Feb 12, 2012 | LG WM2455 Front Load Washer
DRIVER'S DOOR DOESN'T CLOSE ALL THE WAY
It sounds like tha door latch is getting stiff, it needs some lubrication. I wouls spray some penetrating fluid into it through the spot where it catch's the door post and work the latch by hand several times until it moves freely. You may have to do this several times, or over the course of a couple days to get it free. Don't be shy with the penetrating fluid. Once you have it working freely, respray it with a spray lube such as white lithium grease. This should keep it working. Don't forget the other doors. Hope this helps.
Nov 16, 2011 | 1997 Toyota Camry
My Chamberlain Liftmaster Formula 1 garage door (2002) has stopped working. The power is on -- light turns on when I push the wall mount button. But the remotes no longer work. The door does not move. ...
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Jun 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: My craftsman 1/2 hp garage dood does not close whe...
If the main light flashes 10 times when you try to close the door it is a sensor problem. Make sure they are not flickering ever so slightly and that they are not loose on their brackets. Tweak them a little bit.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Have to hold the wall button to lower the door.
Most likely your door sensors have been bumped so that they are no longer aligned. They must point at each other and the small light on each one must be on and not flickering. Tweak them a bit.
Jun 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
GARAGE DOOR OPENS AND CLOSES ON OWN LT BLINKS SEVERAL TIMES
Anytime a door opens and/or closes by itself I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
This can also interfere with remote controls
HOPE THIS HELPS
Mar 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberplain Garage Door Opener problem
IF U HAVE TWO EYE,SENSORS ON EACH SIDE OF THE DOOR SEE IF SOMETHING IS BLOCKING THE EYES OR SOETHING IS COVERING THEM, OR THEY ARE OUT OF ALIGNMENT, ONE SHOULD SHOW GREEN, AND ONE RED EYE, GOOD LOCK
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
166 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
