Question about Maxi Aids Shake n Wake ZZZ Vibrating Alarm Clock Watch
Setting instructions for Shake-a-Wake alarm watch
I need instructions on what to do to start the setting sequence. Randomly pushing buttons sometimes gets me into the setting sequence and then I can set it. It is very frustrating to not be able to get it into the sequence. Which of the 4 buttons do you push in what sequence to get it into setting mode?
I have a Timex Wacky Wake-up Alarm clock and can't
When you are setting the alarm on the wacky wake-up timex alarm, if you keep pressing FWD, you will see a small PM in the bottom right hand corner. When the PM sign is gone, you will now that it is set to AM.
Mar 09, 2012 | Timex Watches
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 | Watches
Aspen watch
this should work with your aspen watch let me know if it doesn't
http://dive.scubadiving.com/members/gearreviews.php?s=593
Quote
For the alarm: If you want to use it (I think both it and the light use battery faster than when not used), you set it by pushing mode button twice, as indicated above, then go to hour or minute setting by pushing the lap/reset button, and advance to the time you want by pressing the start/stop button. Pushing mode will take you back to normal time again.
To turn alarm on or off, hold lap/reset button in and at the same time push the start/stop button. Alarm icon will show on or off. When you release the lap/reset button, it will revert to normal time.
If the alarm is on, at the designated time it will start beeping for awhile or until the lap/reset button is pushed (off) or start/stop button (snooze).
Aug 08, 2008 | JCPenney Armitron Sport Link Bracelet...
How do you set the time on an Armitron 165 wrist-watch?
Hi wtgillo,
Hi there I see that you are in need of assistance setting time on your Armitron Wrist watch.
I would be more than glad to give you details on how to, Please see steps below.
  • Your Armitron Watch will have Four Button on the side of the watches rim.
  • Button on the upper Left is MODE.
  • Button on the lower Left is LIGHT.
  • Button on the upper right is DATE.
  • Button on the lower right is Alarm.
See Steps below:
*Setting the time*
  • Press and Hold down the Mode Button til the Hours flash
  • Then push Alarm Button to set the Hours
  • Press and Hold down the Date Button till the Minutes flash, then push D/Alarm Button to set the minutes
  • After setting the minutes on your watch, Press date till you get the month flashing push Alarm to set the month
  • Press the Date again till the Date flashes, then push Alarm to set date
  • Press the Date again till the Date on your watch flashes, then push Alarm to set the date
  • After setting everything push the Mode Button again just once to set everything or finalize your settings on the watch.
I hope that this will be of help regarding your query on how to set the time on your Armitron watch, I also included the setting of the time and date just for further details.
Have a nice day,
mvincentc
Apr 21, 2011 | Armitron Watches
Do you have directions for armitron mens pro sport watch 49/1000
Hi robinmsavage,
I will be glad to help you with your concern regarding your Armitron Wristwatch, what exactly would you be experiencing? cause I only put info on how to set time and date on the Watch.
Please see below steps:
See Steps below:
*Setting the time*
  • Press and Hold down the Date Button till the Minutes flash, then push Alarm Button to set the minutes
  • After setting the minutes on your watch, Press Date till you get the month flashing push Alarm to set the month
Thank you for choosing Fixya,
mvincentc
Apr 21, 2011 | Armitron Chronograph Sport #204345BKBK...
How do I turn off the alarm on my Armitron watch?
I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
Nik.
http://home.earthlink.net/~eldonenew/armitron.htm
or
http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
Other People Are Reading
Setting Date, Time and Alarm
  • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
Using Chime and Alarm
  • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
Backlight
  • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
Read more : http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Jul 20, 2010 | Armitron Round Digital Sport 408089 Watch
How do i set alarm on a gap sport watch?
For setting Time & Date...
1. Push "MODE" button three times (change Mode to TimeSet)
Time -> StopWatch -> AlarmTimeSet -> TimeSet -> Time ->...
2. Flashing Second Number Digits
3. Push "RESET" to select...
Second -> Minute -> Hour(12hr<->24hr) ->...
Date -> Month -> Day of Week -> Second -> ....(repeat)
4. Use "START" to set each item...
For setting Alarm ON/OFF
1. Push "RESET" button then Push "START" same time...
Alarm ON -> Alarm OFF -> ... (repeat)
Jan 09, 2009 | Columbia All Sport Digi Watch l
Setting time & alarm on Sharp Chronograph wristwatch.
Instructions for Sharp Alarm Chrono (Digital)
Push "Mode" button until the mode is shown that you want to reset, do this even if the mode you want to reset is all ready showing.
Push "Reset", continue pushes until the desired Parameter (Minute, Hour, or Second) is flashing.
Use "Start" button to advance the digits to the desired setting.
Push "Mode" Button to finish.
Jan 12, 2008 | Watches
Watch isn't recognised by computer
Hi Hoffman518,
To set the alarm on your Timex Ironman, please follow the steps below.
1. Begin by pressing the "mode" button until the alarm screen appears.
2. Press the "set" button and use the "advance" button to set the hour for your alarm.
3. Repeat the same procedure to set minutes and seconds for your alarm.
4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
Hope it helps.
Thank you for using FixYa.
Aug 08, 2007 | Timex Ironman 53151 Wrist Watch
Maxi Aids Shake n Wake ZZZ Vibrating Alarm Clock Watch Logo
173 people viewed this question
Top Maxi Aids Watches Experts
Jimmy Accardi
Are you a Maxi Aids Watch Expert? Answer questions, earn points and help others
