Question about Cooktops
Where is fuse box for Defy thermofan oven 731T?
2 Suggested Answers
  • 3 Answers
SOURCE: What thickness cable should be used?
15 amp cable
Posted on Jul 20, 2009
We set the ovens to bake, they click but do not heat up.
Could be the elements.if it is a fan oven the elements sit behind the rep late.first check the fuse box.then if the oven lights up it could only be the elements.they are easy to replace .you can buy the replacement units off eBay.you can also watch a tutorial on replacing them on YouTube.
Jan 18, 2015 | Electrolux Frigidaire Gallery 30" Double...
How to replace a fuse?
It is fused through the house breaker box.
Mar 15, 2017 | GE Select-Top 30" Modular Downdraft...
Fef379ach cooktop works oven does not
They are SEPERATE. Oven controls are on a separate circuit. Look for a short, disconnect of one or more connections, or if fused, check for continuity. Check you home fuse box and make certain both circuit breakers are closed. This is a 220VAC system.
Mar 17, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
St George Rotomaster stove/oven turning itself on.
This certanally sounds like a bad switch.
Availablity of a replacment switch I am not shure.
But you can try. Here is a link to service agents that
should be able to help you
http://www.sga.com.au/Services/default.aspx
Hope this helps.
Please leave feedback.
Dec 06, 2009 | Cooktops
On-site breaker panel routing
white and ground are grounds there should be a ground rial in the fuse box, stove is 220 black and red go to 2 seperate breakers, 25 amps, and 15 amp is for 110 regular outlet
Oct 08, 2009 | GE Cooktops
Hotpoint
just a thought - check the connection block where incoming mains connects to the hob. these quite commonly burn out
Sep 07, 2008 | Cooktops
GE electric cooktop
Try looking at the junction box that it is connected to. Maybe one or more of the wires have burned off or come loose from the wire nuts. How many amps is the breaker? Most electric codes require separate circuits (Breakers) for each appliance. First turn off the breaker. There should be an outlet box of some kind on the wall or behind the cabinet. Follow the wire from the cooktop and see where it goes. Open it up and check if any wires are burnt or loose. If it was installed wrong I would change it. Most cooktops shouldn't be fused at more than 30 amps. Single ovens the same, double ovens up to 45 amps. The problem is if they used an old range outlet with 6 gauge wire and tried to connect both appliances to the same wire. This is hard to do without it coming loose.
Jun 10, 2008 | GE 30 in. JP326 Electric Cooktop
Cooktops Logo
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
