Question about Home
How does a thermos work? - Home
    Problem Solver:
  • 22 Answers
A thermos is a vacuum flask that has two flasks. One flask is in the other flask and they are joined at the top. The gap doesnt have a lot of air. This makes a near-vacuum with the prurpose of stopping the transfer of heat or cold. Therefore, the thermos keeps a drink hot or cold.
Posted on Jan 14, 2013
WHRE IS THE FAN FUSEE IN A 1.3 TOYOTA TAZZ
you changed the thermo switch and relays and it didnt fix it
did you test the fan motor itself
the fuse box cover should have a fuse layout diagram
engine cooling fan
look for a 30 amp fuse
they usually near the fan relays
is the air con cooling fan working with air con on
and engine running
26238251-04wei2fenntfkeahz4fn3g0j-5-0.jpgwhre-fan-fusee-in-1-3-toyota-tazz#sln-36379873-rmi0ll110lgwm2wbdtthe4rs-3-2_0.jpg
Jul 15, 2016 | Toyota Cars & Trucks
Need a regulator for Thermos Grill 2 Go
I bought this to replace the regulator I lost for my Thermos Grill2Go. Little modification to the grill and it worked like a champ. Portable Propane Table Top Regulator 1 by 20 Female Throwaway Cylinder... need-regulator-thermos-grill-2-go-2i4ggwcr0e0sverpwaph0wvr-1-0.jpg
Aug 22, 2012 | Thermos Grill2Go Fire+Ice
Skytech-3001 Thermo won't work
I am having some trouble! Mine became unconnected and I don't know how to reconnect. There is two wire, red and white, a box that sits inside the fireplace that has an on/off sitch and a box that sits outside the fireplace with a off/remore/on switch. How do I connect it back? Please help!
Jan 28, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
Volkswagon POLO 2001 Manual Problem: thermo fan not working. Hi all, I have since ordered and replaced the fan with a another fan and the fan still does not work!! Could it be the fuse? Initial...
CHECK TO SEE IF POWER GOING TO COOLANT FAN AND COOLANT FAN THERMO SWITCH.THERMO SWITCH LOCATED BOTTOM OF RADIATOR ON THE LEFT HAND SIDE.IF POWER GOING TO THERMO SWITCH THEN SWITCH IS FAULTY.IF NO POWER GOING TO THERMO SWITCH OR COOLING FAN.CHECK LARGE FAN FUSE IN THE ENGINE COMPARTMENT AND YOU HAVE FUSE 16 IN FUSE HOLDER.IF FUSES GOOD YOU HAVE SHORT IN THE FAN WIRE OR FAULTY FAN CONTROL MODULE.SHAKE FAN WIRES IF FAN WORKS PROBLEM IN THE FAN WIRES YOU HAVE A SHORT IN THE WIRES..
Jan 12, 2011 | 1996 Volkswagen Golf
Thermos Vacuum Bottle Stopper No. 781
You can get replacement stoppers for the 781 by using the 750
This is currently available on Ebay and he ships worldwide
Here http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180592070973&ssPageName=STRK:MEWNX:IT
Jul 29, 2009 | Sport & Outdoor - Others
Qt9093 heater shuts off after approx 1 min.N
had one one time! lasted for about two years...yes there is a thermo switch, mine was same! heated for about one minute..then off....would come back on after cool down.to replace thermo was like as much as whole unit....crazy I just lived with it! I know this does not fix yours and i'm sorry ...your thermo could be cheaper! check it out
Mar 21, 2009 | Broan-NuTone NuTone - Vent Fan - QT9093WH
Goldstar Microwave
Could be the relay, an internal fuse. With the power off, open up the key panel and search for a fuse. Also, there are thermo sensors black, diameter of a dime and 3/8 inch thick with two wires. Check the fuse and replace if necessary. The thermo can be jumped out to test. Remove the wires, use a paper clip between them and tape it up. Briefly turn the unit on. Replace if it works now. The thermo is generally clamped to the wall of the oven behind the key panel. Never run without the thermo sensor.
Dec 18, 2007 | Goldstar MV-1501 Microwave Oven
Home Logo
763 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
