Banging then freezes red light flashes - Washing Machines
  • Washing Mach... Master
  • 17,130 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Jan 14, 2013
Washing machine makes loud banging noise then freezes then red light flashed on and of
If this is a new machine then you must contact the dealer immediately as it is due to damage in transit or alignment issues with the drum while it was moved. Possible the drum or suspension is out of sync and must be replaced, also if there is damage on the chassis then it must be claimed on warranty.
Jan 14, 2013 | Washing Machines
I have 8 flashes on my Panasonic TCP60S30 - 60" Plasma.. Does anyone know what this problem is or how to fix it? I heard a big bang then screen went black, now I keep seeing 8 red light flashes.
8 blinks Driver SOS 3 SS Board (SS energy recovery circuit). This is the fault. Can you follow? Just check this site, and see whether it help you. It has details about the blinking codes and fault locations to Panasonic Plasmas.
Jan 14, 2013 | Panasonic TCP60S30 Plasma TV
Three flashing red lights
If you have the 3 red lights this is because the GPU and the CPU have heat up you need to stop the heat, you can send it in to do this or you can fix it with a good repair guide
Dec 24, 2009 | Microsoft Xbox 360 Console
I have 3 red lights flashing and my disk tray gets stuck
when u have 3 red flashing lights its called RROD or red ring of death. u have a 3 year warrenty on that so just sent it in and for the disk problem, if u still have ur warrenty , you can just send it in so they can fix it.
Dec 08, 2009 | Microsoft Xbox 360 Console
Game keeps freezing and sometimes only 3 red lights flashes
The game is overheating. Although Microsoft doesn't recommend or honor a fan (for warranty) , I would suggest purchasing one and placing on X-box. Try not to play for long hours as this can cause overheating and eventually lead to hardware failure. If you still have a warranty, contact Microsoft ASAP.
Oct 03, 2009 | Microsoft Xbox 360 Console
One flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
Games freeze. red light flashes when i turn on
see if youre disk is cracked in the circle and make sure all the cords are plugged
May 02, 2009 | Microsoft Xbox 360 Arcade
Flashing
revisar el nivel puesto que las lav tienen un sistema de anti bibracion que el cual la detiene
Aug 05, 2008 | Washing Machines
Ice Maker Not making Ice
Water is in the tray and you have freezing temps? Can you tell me a little more? The flashing red light began when the ice tray filled and did not freeze? Let me know when possible, Thanks JT
Oct 23, 2007 | Kenmore 50522 / 50524 Side by Side...
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
