Question about HP DeskJet F4280 All In One Printer InkJet
Errore connessione 0x00000709 stampante deskjetf4280
Non funziona lo scanner
4 Suggested Answers
  • 628 Answers
SOURCE: la stampante non mi fa lo scanner dei documenti
Hai provatao di ripristinare il software driver per lo stampante?
Posted on Jan 24, 2010
pineworks
  • 4041 Answers
SOURCE: problema di bloccaggio HP C5180, errore inchiostro 0xc18a0107
Hi no harm in trying I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
seeker5211
  • 1089 Answers
SOURCE: stampante nf 1522 errore 49
49 error is an internal embedded software error.
1) turn off power and wait about 30 seconds, power on and if error comes back, see step 2
2) www.hp.com/support/ljm1522
Posted on Jan 15, 2011
Ciao e stata bagnata una telecomanda tv samsung e non funziona piu ! cosa faccio?
si dovrebbe fare è cercare di aprire il telecomando, pulita fino a secco.
se c'è una connessione carbone manca, non funziona più.
controllare e sostituire il batery a causa dei danni. speriamo di aiuto.
Mar 16, 2011 | Samsung TV Remote Control
Errore f2 whirlpool sesto senso lavastoviglie
Ciao. La machhina risponde con F2 quando c'e aqua alla base della vasca ed il ciclo di scarico non e' completato in tempo limite (long drain) o quando il meccanismo che determina il livello dell'acqua segnala che l'acqua e' oltre il limite. In entrambi i casi ci sara acqua alla base della lavastoviglie.
Il codice d'errore si resetta tenendo premuto il tasto ON per 5 secondi, e poi riavviando un ciclo.
Se questo non funziona stacca la spina dalla corrente, rimuovi tutta l'aqua dal pannello base della vasca, e controlla lo scarico. Controlla anche l'altezza e il gomito del tubo di scarico dietro la lavastoviglia. Assicurati che rispetti le specifiche che trovi nel manuale, altrimenti rischi un effetto sifone causato dal riflusso d'acqua di scarico dentro la vasca della lavastoviglie. Questo puo provocare lo stesso errore.
In bocca al lupo.
Ginko.
Feb 02, 2011 | Dishwashers
Non funziona il tasto virtual surround sound.non
Per il tasto surround, sempreché non sia un danno hardware, prova a reinstallare drivers: http://support.acer-euro.com/drivers/notebook/as_6920G.html
Per il problema delle SD Card, verifica che il lettore SD sia elencato in Hardware del Pannello di Controllo. Se non lo è, il problema è di driver oppure grosso guaio hardware (improbabile). Se lo è, potrebbe essere un problema con la scheda SD (prova con un'altra), o semplicemente sporco il contatto all'interno del lettore, che può pulire con aria compressa o inserendo/disinserendo la scheda SD poche volte.
Jun 07, 2010 | Computers & Internet
La stampante non mi fa lo scanner dei documenti
Jan 24, 2010 | HP DeskJet F380 All-In-One Printer
Problema di bloccaggio HP C5180, errore inchiostro 0xc18a0107
HOLA!
YO TUVE EL MISMO PROBLEMA CON MI IMPRESORA HP PHOTOSMART C7180 ALL IN ONE ,,,,Y LO QUE HICE FUE LO SIGUIENTE:
1.-ESTANDO ENCENDIDA LA IMPRESORA, DESCONECTE EL CABLE POSTERIOR(EL DE ATRAS DE LA IMPRESORA)
2.-PRESIONE LA TECLA DE "OK" Y "AYUDA" AL MISMO TIEMPO COMO UN MINUTO
3.-VOLVI A CONECTAR EL CABLE POSTERIOR
4.- LUEGO PRENDI LA IMPRESORA
5.- CAPTURE LOS DATOS QUE ME PEDIA, POR EJEMPLO: IDIOMA ESPAñOL, PAIS MEXICO, ETC.
6.- Y EMPEZO A TRABAJAR CORRECTAMENTE
MUCHA SUERTE, ESPERO LES SIRVA ESTO QUE A MI SI ME FUNCIONO! SALUDOS REBE!
Jun 19, 2009 | HP Photosmart C5180 All-In-One InkJet...
Reset the product:
5. Wait 60 seconds.
Jun 15, 2009 | HP Photosmart C5180 All-In-One InkJet...
Scanner
Questo spesso succede quando colleghi la stampante prima di aver installato il software, o quando non installi tutto il software.
Devi installare tutto il software presente sul disco, controlla anche il cavo usb, un cavo usb difettoso puo far funzionare la stampante e non lo scanner.
Se non funziona, fai un system restore (recupero del sistema? non mi ricordo come si chiama in Italiano.
Dicevo fai un system restore da Avvio>>programmi>>accessori>>utilita di sistema...
Questa procedura riportera' il computer come stava prima che Windows installasse automaticamente i driver per la stampante.
Dopo il system restore installa tutto il software sul disco della stampante SENZA collegare la stampante finche' esplicitamente richiesto dal programma di installazione.
Se non hai il disco devi scaricare i programmi dal sito Lexmark, che pero e' in inglese, o chiedere una copia del disco al rivenditore.
Qui c'e' il sito web della Lexmark : Official Lexmark Drivers and Software
In bocca al lupo.
Nov 20, 2008 | Lexmark X2500 All-In-One Printer
Errore stampante canon MP130/110
Try this -
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by presing <--- or ---> then OK
3) SET ABS-M LEVEL TO 0
4) OK
Oct 15, 2008 | Canon PIXMA MP170 All-In-One InkJet...
HP DeskJet F4280 All In One Printer InkJet Logo
78 people viewed this question
Seeker5211
Seeker5211
