Question about Minolta X-370S 35mm SLR Camera
Shutter will not close back to starting position with each shot
I have a Minolta X-370, it has been in storage for the past 5 years as I have a new digital. I wanted to use it but the shutter is stickiing with each shot preventing me from taking another, what should I do? Can you think of why it will not move all the way back into starting position? Please help.
    Scholar:
  • 185 Answers
Cablechick25,
do you mean the shutter doesn't close all the way? put select on B , gently push shutter to the left to fully close the shutter. charge shutter and fire it a few times, it should free itself after a few shots.
any mechanical device needs a periodic clean, lube & adjust, ( CLA ), after not being used for 5 years your X350 just needs that. take it or send to a camera repair shop for an estimate first. there are no new parts available for this model minolta.
Posted on Jan 25, 2009
How to reset combination
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
the door and conceal your combination
7. Close the shutter door
Sep 03, 2014 | Master Lock 5400d: Portable Select Access...
I have a Minolta X-370 camera that will not advance the film. Lever seems to be frozen.
The shutter is already wound and the shutter is not releasing.
You may have bad shutter release capacitors if the batteries are good.
May 11, 2010 | Minolta X-370S 35mm SLR Camera
MINOLTA X 300 SHUTTER RELEASE JAMMED. FITTING NEW BATTERIES DOES'NT HELP AT ALL. Barry.
The Minolta X-series (X-300/370, X-570, X-700) were known for this issue. Two capacitors under the top and bottom covers go bad over time. They prevent the shutter from releasing, so you cannot wind to re-**** the shutter. If you're handy at these things, you can buy the caps, remove the covers, solder in the new caps, and be fine. This issue is well known and you can find instructions on the web. Or you can send it in for repair. Garry's Camera repair in Niles,ILL will do it cheaply at $58 incl return postage. Look him up on the web.
Sep 30, 2009 | Minolta Photography
My pics come out half black when I use the X-370 flash
motley45
this happens when the shutter speed is not correct. set the speed to 1/60 sec.
if the X-370 flash is new it may not be compatible with your camera. with the flash turned on it should set the shutter speed automatically to either 1/60sec or 1/125sec. looking in the finder the shutter speed should not change to various amounts of light. if the shutter speed changes with the flash turned on it is not dedicated to your camera.
May 03, 2009 | Minolta X-370S 35mm SLR Camera
Minolta X-9
Mar 22, 2009 | Minolta X-700 35mm SLR Camera
Minolta 35mm X-370 stuck shutter
You are probably on the right track with the batteries. Stick some fresh ones in and the shutter should release. Your may need to use the advance lever to re-**** the shutter and drop the mirror down. You could also try removing the lens and manually pushing the mirror down to see if it stays in the down position.
Mar 16, 2009 | Minolta X-370S 35mm SLR Camera
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
factory to 0-0-0-0
(see instructions above)
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Konica Minolta X-370 Wont develop
Two possibilities : 1 ) your film was not properly loaded into the pick up spool and hence it was transported or exposed ; what you took to the lab was unexposed film. 2) the shutter is not opening and again no exposure takes place. To check this open back , set to slow speed like 8th of a second, and see if the shutter opens and closes properly. If the shutter does not open then it will have to go in, unfortunately. Cost ? If it is just an adjustment ( as I suspect is the case ) you should not pay more than $ 100.
Nov 01, 2007 | Minolta X-370S 35mm SLR Camera
Minolta X-370 wont shoot
Shutter release capacitor needs replacing and is easy to replace on these models. Remove bottom cover ( 4 screws ) and locate the small 6v 220 microF capacitor and replace making sure you get the polarity right. ( these capacitors have life span of 10 years and then the rubber iside perishes and they leak.)
Jan 25, 2007 | Minolta X-370S 35mm SLR Camera
Minolta X-370S 35mm SLR Camera Logo
158 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
