Question about HP Officejet Pro L7680 All-In-One Printer
Took apart the roller to clean and now can't put back together...
When I put back the only way I can see fit...the door will not close. I'm very frustrated right now and had to step away before I break it.
  • 679 Answers
The rubber rollers in the back where you open up the machine to release the paper and in the front where you can see another set of rollers that pull the paper through.
please try the solution.. if the solution not works then let me know.
Thanks
Posted on Jan 23, 2009
    Brigadier General:
  • 8,619 Answers
Hi
After opening the cover of the printer please insert the cartridge in down position (green colour) while holding the extra handle on the upper side and put it down and try to fix it in the space provided for the cartridge.
Thanks
Rylee
  • 10,594 Answers
Can you please post here 1-2 snaps of roller and its position to understand the problem.
I took my car seat apart to wash it and I don't know how to put it back together
We would advise you contact the manufacturer of the carseat as the likelihood is that the unit will need to be sent to specialist engineers to inspect and put back together correctly. Due to safety implications of the harness being incorrectly fitted it may not be possible to do this yourself.
Dec 19, 2012 | Baby Gear
I took apart my dryer to investigate a noise. While it was apart I noticed arcing at the terminals. L1 had completely melted. I purchased a new terminal block and installed it. Everything went back...
Hi herbert hurt...
The noise you are hearing could be your drum rollers.
They could need cleaning and lubrication or replacement.
If they need lubrication they will make a squeeling noise, if they have flat spots on them they will make a thumping type of noise.
If that is you noise then take the dryer apart and lube,clean, or replace the drum rollers
Please take time to rate me
Aug 17, 2011 | Vacuums
Pulled of doorknob, all the peices fell out and now i cant put it back together
If this is an inside door from an old house, just take another one apart very slowly to see how the pieces fit. If this is an an outside door from a newer house, you might want to just buy a new lockset and follow the directions carefully. I assume you took it apart because it wasn't working anyway.
Jan 04, 2010 | Top Knobs M826 Door Pull
Put back togather
Well I did it. It's not exactly easy to describe. I accidently took mine apart trying to clean the roller ball and out popped the 2 springs. I sort of put it back together in "reverse". In other words, I put it together without the scroll device and then looked through the hole. By doing this, I figured it out -- when you know it's simple but to describe it without pictures is almost impossible. Mine works fine now but I don't know how to help you.
Jan 13, 2008 | Logitech Cordless TrackMan Optical...
Need help putting GE oven door back together again
they're called towers. They go on the 2 long screws once you've put the screws through - so they go between the two panels. They are used to space the 2 panels so that they line up flush when they are back together.
Jan 09, 2008 | Kitchen Ranges
Indesit dishwasher
I had the same problem, so I took the door apart as explaned above, found it was gunged up with residue from the washihg cycles. Gave it a good clean, while the part was disconected of course, and hay presto! the door works like new again.
Jan 06, 2008 | Indesit 24 in. D63 Free-standing...
Hoover Wind Tunnel
what probably happened is you swapped end over end when you replaced the beater brush. anyway go to thehooverstore, find your machine and you'll see an exloded diagram of your machine.
Aug 18, 2007 | Hoover Company Wind Tunnel U53019 Upright...
HP Officejet Pro L7680 All-In-One Printer Logo
Seeker5211
Seeker5211
