Question about Black & Decker 18V Cordless Drill/Driver
I carnt open keyless chuck on cordless drill KC121F
Unable to remember how to open and close may be stuck
3 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: Black and Decker Cordless Drill Chuck stuck in full open position
I'd put penetrating oil in it and tap the chuck with a plastic hammer. That should free it up.
Best rgrds, W/D
Posted on Aug 18, 2009
wireguy212
  • 1627 Answers
SOURCE: I have a Black & Decker 18V cordless drill
Look at the three jaws in the chuck,if on is further out than the others the you need to tap ti back into place with a small punch and a hammer.If this does not work then you need to replace the chuck,remove the screw at the bottom of the chuck[where you put the bit],then you will need to to clamp vise grip on the chuck and with it pointed away from you hit the vise grips with a hammer with a sharp blow downward and it should come off.Hope this helps.
Posted on Jun 12, 2010
How do I remove the keyless chuck on my 14.4 cordless B&D drill
The chuck is held onto the shaft with a Philips screw. Open the chuck, insert the screwdriver and turn CLOCKWISE to loosen the screw. The chuck will still be connected to the outer thread on the shaft. Slide the drill direction slider to the middle position to lock the motor. Put an Allen key in and close the chuck around it. You will now be able to use that to twist the chuck off.
Sep 14, 2016 | Drills
Milwaukee1/2 magnum hammer drill keyless chuck stuck closed
yes call 1-800-sawdust that's the Milwaukee factory number. They can tell you what the spindle and thread sizes are so you can order a keyed chuck. They should even be able to tell you what chuck they have that will fit it.
Jan 12, 2013 | Drills
Ryobi 18v drill keyless chuck stuck
Try holding the bit in a vice and gently tap the chuck off of the bit and see it it releases the pressure on the jaws.
Jun 20, 2012 | Ryobi 18v Cordless Drill - P206 18 Volt V
12 volt black and decker keyless chuck will not close. Model CD120G
Try giving the inside a spray with WD40 then try closing the chuck. Check that there is not a left handed screw in the center of the chuck that has become partialy unscrewed. The chuck can jam open and just need a strong gril to release it. If the outer sleve of the chuck is turning but nothiing happens then you will need to get the chuck replaced.
Jun 10, 2012 | Black & Decker 18V Cordless Drill/Driver
I cannot open a Dewalt 954 cordless drill chuck. My socket adapter is stuck in the chuck. It is a borrowed tool and I need to return it in the same shape that i received it. Help. No TWO men can exert...
if it is a keyless chuck soak the inside of the chuck with oil. charge the battery so you have max power. put a cloth around the chuck and use a pair of channel locks to hold the chuck and put the drill in reverse. good luck
Aug 21, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I have a Black & Decker 18V cordless drill with keyless chuck. The spot where the drill bit fits is in the open position stuck and won't turn in either position. What am I missing how to unlock it?
Jun 12, 2010 | Black & Decker CD9602SB 9.6 Volt Cordless...
Keyless chuck is stuck open
That can happen if the jaws inside the chuck, usually 3 triangular pieces get jammed together. With chuck facing down tap chuck several times to loosen jaws. If that doesn't work spray a small amount of WD-40 into chuck and try again
Feb 23, 2010 | Garden
Best rgrds, W/D
Aug 18, 2009 | Black & Decker Drills
Cordless Drill, Keyless Chuck stuck in full open position.
if chuck is wide open ,look down inside there should be an allen screw or bolt at the bottom of the chuck it should undo anti clocwise and the chuck comes off
Aug 18, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Black & Decker 18V Cordless Drill/Driver Logo
23 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
