Question about Sony MDS-E12 Mini Disc Player
I have two rack mountable minidisc players can any one in the world fix these things(frustrated).An MDS-E 12 & an MDS -E 10.One just fell over backward from the ground in a wooden rack. The other electric power surge.Both turn on but will not play the disc TOC error appears & the disc ejects I'll send it to Japan if I have to.
  • heromitch1 Feb 18, 2009
    I'm located in Fort Myers, Florida
  • 4,234 Answers
I have repaired a number of these over the years, the main problem is usually the loading mechanism or the optics. Neither is cheap. Where are you located?
Dan
Posted on Feb 17, 2009
  • ABRsvcs Feb 18, 2009
    Both the loading carriage and the optics assemblies are sensitive to damage. Unfortunately some parts may no longer be available or if they are, they are not cheap. I do have some parts for these, but without seeing them, I'm not sure what they will need. The one that had the power surge is less likely to be fixable. Hopefully I am not violating any codes of conduct here, but contact me offline at the email address below and I'll try to assist further.
    Thanks,
    Dan
    Email: dansabrservices at yahoo dot com
Mds-je480 how do you set player to auto stop after each track
You can't. http://www.minidisc.org/manuals/sony/sony_mdsje480_manual.pdf
Apr 19, 2014 | Sony MDS-JE520 Mini Disc Player
MDS-JE480 minidisc autopause
MDS-JE480 has the option A. PAUSE.La solution there is.WITH ANY REMOTE CONTROL FOR THE SONY MINIDISC ,THAT HAS THE BUTTON' A. PAUSE' .NO WITH THE REMOTE CONTROL OF THE MDS-JE480,640,530,S40,41 ..... WITH ALL THOSE 'large' FOR MODELS MDS-S38,39,JE500,510,520,JB700,730,920,930,980 ......
Apr 30, 2008 | Audio Players & Recorders
My sony md player wont read HI mini discs
The 480 is not designed to read HI MDs. If I remember right, it can read them as regular discs.
You can always purchase a HI-MD recorder, if that is important to you.
Apr 30, 2012 | Sony 5 Pack Hi-Minidisc 1gb w/Case...
Which the price of this product minidisc sony mds je480
Accoding to Minidisc.org the unit sold for about $130 USD New, check eBay to see what they are selling for recently.
Apr 17, 2011 | Sony MDS-JE480 Mini Disc Player
MDS-JE520 player makes chattering sounds==do you repair? Please send details--Thanks-- BOB
The only repair place I know of in the USA is ProDigital of Philadelphia who repairs digital broadcast equipment and Minidiscs subject to parts availability.
520s are mostly worn out at this late date try to find a 630 which does all of the same things better and is a newer unit.
Jan 22, 2011 | Sony MDS-JE520 Mini Disc Player
Sony MDS-JE520 Mini Disc Machine no operation, standby led is illuminated, but pressing on/off button it does not respond
This is from my own experiance. I inadvertedly bent the cover of my deck and had the same error.
The minidisc is blocked in the loading mechanism. Too much weight on top of the deck can bend the cover and the metal support which is above the loading sledge. The slider is then blocked. When you connect the power you can hear a motor trying to move for as short instant.
Disconnect the deck from the power supply.
Take of the cover and check if the support is bent. carefully bend it upwards, if so. Reconnect power and check if the deck powers up..
That's my solution which worked for me.
BTW I second Obertellis advice to find a MDS-JE780 (or MDS-JB980) they are the most complete decks ever made by Sony
Jul 25, 2010 | Sony MDS-JE520 Mini Disc Player
Looking for Sony minidisc player MDS JE480 parts
Best bet is an online auction like ( e Bay).
Jan 26, 2010 | Audio Players & Recorders
MDS 503 STUCK IN STANDY MODE?
Is it an MDS-JE530? Do you have a minidisc in it? If yes, then unplug the unit. Slide the little switch from TIMER "OFF" to "PLAY", then plug the unit back in. After 10 seconds, it should turn on and start playing the minidisc. Let me know if that works or if we need to try something else, okay?
Dec 30, 2009 | Sony MDS-JE520 Mini Disc Player
Can you use headphones with the mds je480 minidisc player?
probably need to use a plgu which goes two rca female to stereo mini jack, Used it for pc setups in video editing, works quite well even stepped up to 63mm
Jun 29, 2009 | Sony MDS-JE480 Mini Disc Player
Sony MDS-E12 Mini Disc Player Logo
242 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
