Question about Sewing Machines
If we quilt with janome harmony 2049 we need to drop feed dogs or not
When i do quilting free motion i cannot move my project
SewExpress
  • 41 Answers
SOURCE: fREE MOTION QUILTING
Hi Susan,
You're absolutely correct, you'll need to either drop the feed dogs (lever generally located near the bobbin case or on the outside base of machine) or cover the feed dogs with a plate (many machines have this included).
Then... you'll need to lower the presser foot - when you lower it, it should NOT touch the bed of the machine but sit slightly raised off the fabric surface. As you stitch the presser foot will lower onto the fabric to hold it taught as the needle penetrates.
Oddly enough it's easier to achieve smooth stitches when sewing at a faster speed, but begin by stitching fairly slowly until you get a feel for free-motion stitching. You'll be doing all the guiding and it may feel a bit strange and uncontrolled at first.
Position yourself at your machine so that when your hands on your fabric/bed of machine, your shoulders are relaxed (not all hunched up) and your elbows are slightly higher than the bed of the machine.
You'll want to stitch in a side-to-side or back and forth motion (as opposed to trying to turn the fabric.
Best of luck with this technique. Once you're comfortable with it, you're sure to enjoy the freedom of creating!
Happy sewing,
Kim & Linnette
Posted on Jul 31, 2008
SOURCE: frame quilting with janome 1600 db
am I right that the feed dogs do not drop on this machine?
Yes, this is correct....but you have to change the needle plate to a thicker one, so the feed dogs will be below the needle plate.
Posted on Feb 23, 2008
  • 22 Answers
SOURCE: I dropped the feed dog to do some free motion
Make sure you do not have lint "trap" that is keeping the feed dogs up. Clean it out with some canned air and look closely at the grooves to make sure they are not full of lint.
Posted on Nov 10, 2009
Zenqi
  • 208 Answers
SOURCE: Thread gets caught in feed dog while free motion quilting.
First, remove the thread and re-thread the machine. If the thread isn't in the take-up lever properly, erratic problems ensue.
Next, try removing the needle plate and bobbin case and inspecting both for any nicks or burrs. (your instruction book will guide you how) These can be very carefully polished off with 1500 grit sandpaper. Also check the hook for burrs.
Posted on Feb 21, 2010
bargainbox
  • 1388 Answers
SOURCE: I cannot get the feed dogs to come back up on my
Flick the switch to raise the feeddogs then rotate the handwheel one full revolution to re-engage the cam...voila
Posted on Mar 28, 2010
Can I do stippling on my 400xl
This is free motion quilting. There are a ton of web sites and videos available. You'll need a darning or free motion quilting foot for your machine. Drop the feed dogs. If you are certain you want to do free motion quilting, a Supreme Slider helps you move the fabric.
https://www.amazon.com/Supreme-Slider-Motion-Machine-Quilting/dp/B007XGITA2
Learn How to Free Motion Quilt Stippling
How to Free Motion Quilt on Regular Sewing Machine
Free Motion Quilting for Beginners 10 Tips
Free Motion Quilting Beginner Tutorial 1 of 4
Mar 07, 2017 | Sewing Machines
How do I set up my Janome 1600p-qc for free motion quilting?
You will need a darning foot or free motion quilting foot for your machine (these feet are shorter than the regular feet which allows space between the foot and the needle plate to manually manipulate your fabric). Then drop the feed dogs and, if your machine does not have that capability, there should be a cover plate included with your machine that snaps over the feed dogs. Install a brand new needle in your machine, set it for a straight stitch, and test the stitch. Sometimes, the upper tension needs to be loosened a bit so the bobbin thread does not poke through the top of the fabric.
Then...practice, practice, practice...
FWIW, I've found it helpful to use a "Supreme Slider" on the base of my machine. It is slick and allows the fabric to move easily. Special gloves are helpful too because your hand will become dry and begin to slip on the fabric. Using cheap rubber gardening gloves works for some people.
supreme slider Google Search
quilt gloves Google Search
Feb 11, 2017 | Janome Sewing Machines
How do I drop feed dogs on jem silver 662?
Here's a manual:
Instruction Manual Janome Jem Silver 662
The following is for a 660, but it doesn't mention anything about darning or free motion quilting:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwih_NGBzpjRAhXKh1QKHbKIAvwQFggoMAI&url=http%3A%2F%2Fjanome.com%2Fsiteassets%2Fsupport%2Fmanuals%2Fcompact-models%2Finst-book-jem-gold-660.pdf&usg=AFQjCNEwCPZs5n8s4wdgIHMGHbN-GvDe-w
You can also contact a Janome dealer. If the machine does not drop the feed dogs, there should be a special plate accessory to cover them in order to do darning or free motion quilting.
Perhaps this is the accessory you need:
http://www.sewingpartsonline.com/cover-plate-elna-janome-necchi-825018035.aspx
https://tv-sewingcenter.com/products/janome-quilting-attachment-kit-for-jem-series
Dec 28, 2016 | Sewing Machines
Janome 1600P DBX
You need to drop the feed dogs, install a darning or free motion quilting foot (make sure the presser foot is lowered). Because you will not be using the machine to move the fabric, the stitch length selection is of no importance. Make sure the stitch width is set to zero. You should test FMQ on a scrap quilt sandwich of the same makeup of your project, ie quilt fabric with batting sandwiched between. The upper tension should be set so that both threads meet in the middle of the quilt sandwich. Because it is FMQ, some extra adjustment may be needed.
Once the tension is where you want it, you can practice FMQ until you can move it smoothly in conjunction with the machine speed.
Practicing on a white board with erasable markers is a handy way to learn to move smoothly. The most difficult part of free motion quilting is learning to move the fabric smoothly. Do NOT lack for practice as that is the only way to improve. Those people who make it look simple have been doing it for years!
Free Motion Quilting for Beginners Part 1 Video from Sewing with Nancy
Oct 31, 2016 | Janome Sewing Machines
How do I avoid breaking a needle on a 26 foot beginning a free motion project after programing the foot choice and lowering the foot?
#26 is an embroidery foot. Why are you using an embroidery foot for free motion quilting? A #24 free motion embroidery foot will work but not the #26. Try using a darning foot that is just a smidgen shorter so there is space between it and the needleplate for you to freely move the fabric. (Adding a Supreme Slider sheet to the work surface of your machine helps make the fabric glide much smoother.) A standard presser foot is made to press the fabric against the feed dogs so the feed dogs will move the fabric. When free motion quilting, you would drop the feed dogs and move the material with your hands.
Depends which model Bernina you have (new or old style presser feet), which will work on your machine. There are also many generic darning/FMQ feet available that will work on your machine.
12 BERNINA presser feet Darning foot 9 (old style)
Quilting foot 29C (new style)
Bernina 530 53 Free Motion Quilting
Top 5 Tips for Successful Free Motion Quilting WeAllSew BERNINA USAs blog...
Seven Steps to Free Motion Quilting
Dec 31, 2015 | Sewing Machines
Which foot do I use for quilting
a quilting foot or buy one with a round hole in it great
Mar 09, 2015 | Sewing Machines
How do I lower the feed dogs foR free motion embroidery. I have a jANOME harmony 2039
Look on the back of the machine behind the bobbin area. See if there is a slide switch. If not, your manual will tell you how to drop the feed dogs. If you can't drop them, you may have gotten a neede plate that will cover the feed dogs so you can do free motion embroidery and quilting.
Sep 16, 2014 | Janome Harmony 2039 Mechanical Sewing...
Can't free motion quilt on Juki-T98QE
You need to be using a free motion foot or a darning foot, the regular presser foot is not for free motion.
May 29, 2010 | Juki TL-98Q
Frame quilting with janome 1600 db
Feb 13, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
