LG fault code - Washing Machines
  • Washing Mach... Master
  • 17,129 Answers
Please check this link for support on LG machines
LG support
Fault codes
Posted on Jan 14, 2013
I need a troubleshooting manual for an LG intellowasher 7kg wd-1274FHB which is displaying an SE error code.
LG error code SE LG washing machines displaying error code SE are indicating a "motor fault" although the technical information also says it could be a main PCB fault. They recommend to, "try the motor first". It's vague and not too helpful, especially for a DIY repairer so you really need an engineer to try and sort this one. You can't possibly justify "trying the motor first" if you interpret that as buying and fitting a new motor, they are very expensive. You need to at least know how to test a motor for faults and check its connections and carbon brushes (if fitted) if you want to try and diagnose the cause
Nov 23, 2016 | LG Washing Machines
Hi i have a lg washing machine wft8061dd,can u please tell me why PE appear when it turn on
Water level sensor fault This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch. It is rare to see this error code on LG washers.
On non-display panel models this fault code can be shown by the lights for fuzzy, heating and speedy or super, normal and hold being lit or flashing.
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
Jun 13, 2016 | LG Washing Machines
My LG dishwasher when I turn it on it drains the water, then it fills it up with water, about 1 min. later gives me the code E1 and drains the water again...
LG Dishwasher Displaying Fault Code E1 LDF7810BB/01 LEAKAGE ERROR // Excessive pump motor RPM due to water leakage
The manufacturer has assigned this error or fault code to indicate that when the drain pump is running it is not experiencing the back pressure it expects. This is usually an indication that there is a water leak in the drain system. Check all hoses and connections. Check under the dishwasher for any major leak. If all checks out, be certain there is a proper loop in the drain hose to prevent siphoning. Finally, if the problem persists, the drain pump itself might be defective.
Sep 25, 2015 | LG Dishwashers
The display is showing se during the spin cyccle???
Hello there and than you for choosing fixya
LG error code SE LG washing machine error code SE indicates a "motor fault" although the code also says it could be a main PCB fault. They recommend to, "try the motor first". It's vague and you really need an engineer to try and sort this one. You can't possibly justify "trying the motor first" if you are a DIYer unless you at least know how to test a motor for faults and check its connections.
Jan 25, 2011 | LG Washing Machines
I am using lg LSP430 (tata walky) & its locked by fault....i tried 0000 but did not worked.i dont know the changed lock code also.
May 16, 2010 | Cell Phones
Error code se
can you check the temperature sensor , i know thats not the same fault , the fault to the sensor is be but check the sensor , at the bottom of the tub between the heather connections
Jun 18, 2009 | LG WM-2277HW Front Load Washer
Ch 5 error code
ch5 error code, means that there is a
communication error (serial comunication) between the outdoor and the indoor unit.
Only for LG-airconditioners.
Jan 02, 2009 | LG Art Cool LA121HNP Split System Air...
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
