Question about Cell Phones
My xolo x900 is not getting network i have to switch off and on phone again n agian then it shows the signal for sumtym den goes what to do
Plese help me mine is airtel network i am not able to catch signal it showes for sumtym n goes what to doooo?
    Master:
  • Cell Phones Master
  • 520 Answers
Hello Dear:::
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Posted on Jan 14, 2013
  • boopathi
    boopathi Aug 26, 2014
    get new mobile xolo 2 months later my mobile not work mobile data pls help to solve this pblm
    New Friend:
This is a very common problem with xolo x900. it is a serious board issue contact customer care. if your phone is not under warranty it can cost around 10 or 12k.
Posted on Feb 26, 2014
  • Dhruv goel
    Dhruv goel Feb 26, 2014
    this is a very common problem with xolo x900. it is a serious board issue contact customer care. if your phone is not under warranty it can cost around 10 or 12k.
SOURCE: Unlock kg110 airtel network
SIR,
I TRY KG110 AIRTEL PROSES CODE 2945#*5110# BUT BUT NET WORK& UNLOCK OPTION DONOT SHOW ,
SO REQUEST SOLVEB MY PROBLEM
Posted on Jul 15, 2008
  • 239 Answers
SOURCE: Nokia 1100 Signal drops
call the customer care and tell them..
it seems in some area's the tower ill be fault..
hope,it solves the problem...
or if it is not solved it should be antenna error...
Posted on Apr 17, 2010
luki189
  • 179 Answers
SOURCE: nokia 3100 network signals disappear
You must change PA(Power Amplifier) IC on your phone.5-6second signal than gone is a sign of PA IC not work any more.You know that PA is an IC where phone use to transmit.I hope it help.
Posted on Jun 03, 2010
SOURCE: network problem using airtel sim in Iphone 3g
My problem is quite similar... My iphone works in some parts of delhi and it shows no service for other parts of delhi... If i use idea sim on my iphone, it works absolutely fine... and if i use my airtel sim on any other phone then also things appear ok..
any ideas?
Posted on Aug 20, 2010
  • 204 Answers
SOURCE: I have samsung c5010 phone.After
Hi virendra....
First you need to get a valid IMEI no... for your phone then all problem is solved.....
You take IMEI numbers from any SAMSUNG centers or any Genuine IMEI dealers....
I hope this helps have a nice day
Posted on Feb 02, 2011
No network signal in my samsung sgh-g600. how to solve it?
kiran make sure if your device has a network tower, and try to switch off and switch on again. if problem persist try to search network manually by network settings, if problem persist try to do hard reset by *2767*3855#, if after this problem persist show some official repairer to fix it.
Sep 15, 2012 | Samsung SGH-G600 Cellular Phone
Once agian i am getting calls form this two no number 8148680417and 9790554393 plese send the details on rajesh_dece70@yahoo.com
sir, the details can only be provided by the service providers so kindly reach through customer care
Dec 21, 2010 | Lands Phones
I have an airtel sim and it was functioning properly even 2 mins ago and suddenly there is no network coverage and when i had switched on my phone again i get a message sim card registration failed.what to...
Hey no problem jus remove d sim from its socket n den keep it again n den try maximum u ll get it.....i mean ur sim vl b recognized bt coming 2 d matter network der vl b som technical problem........
Oct 05, 2010 | Kitchen Ranges
I have the same problem like above plese help me..
if it da same prob..lyk above..
den do as i did..
switch it off 4 a week nd later..put da code..which u used b4..
it vil work..
try it...
my cel is all 5n nw...
Aug 18, 2009 | Nokia 5200 Cellular Phone
Only get signal now and agian
check your phone's compatibility(signal) with your service provider's signal..generally be sure you are using a gsm connection for gsm phone...try resetting your phone as per the references in the instruction book
May 22, 2009 | Sanyo SCP-7050 Cellular Phone
T-Mobile Sidekick ID Unlock
1.your sim needs a password
2.turn off ur sidekick 3
3.place ur cingular card in
4.turn on sidekick 3
5.itz gunna ask you for a special code ignore it
6. go to settings den sim center
7. if ur sim lock is disabled jus enable it
8.den change ur sin pin to wateva you want
9.once u change it you will signals bars go up
10.go 2 settings network options
11. press scan scan select manually
12. select ur network
13. and datz it your sim iz workin on sidekick 3
if u turn it off u will have 2 do da same process again
Nov 09, 2008 | T-Mobile Sidekick
Cell Phones Logo
539 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
