Question about Hammer Walkrunner Rpe Treadmill
No power from power pack to switch display , need wiring diagram as tried with meters and no success
Machine running suddenly stopped no signs of why it stopped no smell of burning noindication of faults just stopped dead suspecting dry joints thats why want a wiring diagram
    Top Expert:
  • Hammer Master
  • 12,223 Answers
See the diagram attached and troubleshooting and fix it.
God bless you
However this Sympton is because you do not LUBE the deck belt do it and rollers bearings too, this will fix it.No power from power pack to switch display , need  - 1_14_2013_9_11_01_pm.gif1_14_2013_No power from power pack to switch display , need  - 1_14_2013_9_12_03_pm.png_mi1_14_2013_9_12_03_pm.png
Posted on Jan 14, 2013
Treadmill (Nordictrack T9si) stopped suddenly... Power still being received by controller unit, but display doesn't stay lit so nothing functions
open up the control console and look for loose wires... if no loose wires are found, call CoreCentric Solutions and ask if they refurbish that control board... CoreCentric Solutions Reverse Logistics Core Collection and Recovery...
Jul 06, 2016 | Exercise & Fitness
Washing machines not functioning anymore,when i plug in to power shown error in display
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
By the way my advice is free cuz God is good!
All washing machines use a motor that is responsible for spinning and agitating during the cleaning cycle. Many top load brands use a reversing motor which means the motor spins in one direction for agitating and another for spinning and draining. If the motor does not start, but makes a humming or buzzing noise then it may be defective. To verify if the motor is at fault, remove the drive and /or pump belts and then try to start the motor again. On direct drive models, you will have to disengage the pump and the direct drive coupling to the transmission. If the motor starts, then the problem is with the transmission or the pump and can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced
Lastly CONTROL BOARD
If the control board does not provide the proper voltage to the drive motor, fill valve, drain motor or door lock then the washer may not start. The main control board on most washers is complicated and difficult to diagnose without proper test equipment and procedures. You can visually inspect the control for signs of electrical arcing or burned or damaged components on the board. You should use caution when replacing a control board as sometimes the burned components are caused by external component failures.
Jun 22, 2015 | Washing Machines
I have a whirlpool awo/d5706/s that I went to restart yesterday and now there's no power.
Jun 22, 2015 | Whirlpool Washing Machines
My washer doesn't start up at all. There's no display showing at all.
Jun 06, 2015 | Washing Machines
6 sense washing machine. Why did it stop working?
May 17, 2015 | Whirlpool Washing Machines
It just stopped working, how do I get it going again.
May 06, 2015 | Washing Machines
Help please. washing machine will go to start then just stops. Later it will display the following image in the pxt.
Apr 22, 2015 | Washing Machines
Invacare Zoom 220 mobility scooter will not run
Hi. When the machine is on, does it display a flashing light or LED on the display for a fault code? Is the free-wheel lever switch operating correctly?
You might have a sticky brush in the motor. Take the brushes out and check their condition. If the brush caps are not tight enough then the current arc's on to the side of the brush, and it jams in the brush holder.
Check the resistance through the motor before touching the brushes. Check motor and battery connectors for continuity and any sign of heat or melted plastic. Check operation and resistance of the brake unit. Most controllers in mobility scooters are quite reliable, so always eliminate all other possibilities before looking at the controller. Good luck. Neil.
May 17, 2010 | Health & Beauty
My maytag dryer won't heat up
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor 2 heavy red wires (check wiring diagram for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Aug 17, 2009 | Maytag Performa PAV2200
Engine Stalls when put in Gear, Suzuki GSX-R 1000 K3 (2003)
Most of the safety systems use a diode pack in the loom to stop clutch and side stand switch etc from back feeding each other. Maybe this has failed. If not could it be in the loom, a broken or shorted wire. Look for a tight bend in the route the loom runs and external damage to the tape.
Aug 05, 2009 | 2003 Suzuki GSX-R 1000
Hammer Walkrunner Rpe Treadmill Logo
211 people viewed this question
Top Hammer Exercise & Fitness Experts
Debbie
richie46
Electro Med Services...
Are you a Hammer Exercise and Fitnes Expert? Answer questions, earn points and help others
