Question about Home
Should I get a glass cutting board? - Home
    Problem Solver:
  • 8 Answers
I wouldn't suggest it. It can damage your knife. Also if the glass gets chipped, it can get into your food which is really dangerous.
Posted on Jan 14, 2013
How to cut a glass bottle neatly
I have used a flame and water.
Here is a video.
I hope this helps.
https://www.youtube.com/watch?v=WxKZ8hhcmvg
Mar 08, 2015 | Cutter Tools
How do ya cut plate glass and what tools are recommended?
Hi,If you want to cut glass left over form old project or somebody gave it to you for what ever reason the first thing you need to do is make sure that the glass is plate glass becouse if you try cutting tempered glass its going to blow in your face.
Usually tempered glass has a stamp somewhere in the corner which proves that is tempered and the company that tempered it. After you know for sure that your glass is plate glass you need:
1.Safety glasses
2.Glass gloves
3.Glass cutter
4.Straight edge
5.Cutting table or flat surface covered with felt or short hair carpet
6.Measuring tape
7.Clamps (to hold your straight edge while you score the surface)
The thing is you dont cut glass,you score it with the cutter and then brake it.Please let me know what kind of glass are you going to cut so I can be more specific.
Nov 19, 2014 | Building Materials
Easier way to cut glass wall tile
Easier than what? I use a diamond tile saw, and find that pretty easy.
Sep 11, 2014 | Saws
How do I cut up a large mirror?
Essentially the same as cutting glass. Get a glass cutter with a new sharp wheel. Practice on a piece of scrap glass the touch. Firm but not too heavy then make a smooth stroke along a straight edge to guide your cut.
Put a t' thick board under the line to be broken with the board to the left of your intended cut then make a push down on the glass to the right of the break line. If you have made a good continuous scribe line in the glass completely along your cut line it will snap cleanly into your desired two pieces. Repeat until you have the sizes you want. It will only break in straight lines in this method.
Us a torch to burn the edge corners to keep them from cutting you. Just heat it long enough to round the sharp edge.
Jul 02, 2014 | Home
Windows fixya
Go to your local Lowe's store with the size measurements of the window. they will cut you the size you need. Probably better to replace it with a plastic window. it's as clear as glass and will not shatter.
May 08, 2014 | Home
What kind of cutting board is the best?
I think plastic is the best. Wood harbors bacteria, glass ruins your knives. Plastic ones can be cleaned well and they even can go in the dishwasher.
Jan 14, 2013 | Home
R/H rear quarter window repalcement
tv is the wrong adhesive. you must use urethane with a primer. it is available at any QUALITY parts store (NAPA or Carquest comes to mind)
Material Item Specification Urethane Metal Primer Essex U-413
WSB-M2G234-C Urethane Glass Prep Essex U-401
WSB-M5B280-C Urethane Glass Primer Essex U-402
WSB-M2G314-B Urethane Adhesive Essex 400-HV
WSB-M2G316
Removal
All vehicles
ani_caut.gif WARNING: To prevent glass splinters from entering the eyes or cutting the hands, wear safety glasses and heavy gloves when cutting the glass from the vehicle.
  1. Remove the C-pillar trim panels. For additional information, refer to Section 501-05.
3-Door, 5-Door
  1. ani_caut.gif CAUTION: Make sure the cutting blades are changed where the cutting depth changes to avoid damage to the body and trim panels.
    NOTE: Some resistance may be encountered when cutting through the glass locating pegs in the lower corners of the glass.
    NOTE: Lubricate the existing urethane adhesive with water to aid the special tool while cutting.
    Using the special tool, place the flat side of the knife against the quarter glass window. Start at the top and work towards the corners cutting to the given maximum depths:
    1. 20 mm
    1. 60 mm
    1. 75 mm
    1. 90 mm
Wagon
    NOTE: Some resistance may be encountered when cutting through the glass locating pegs in the upper right and lower left corners of the glass.
    1. 20 mm
    1. 30 mm
    1. 50 mm
    1. 40 mm
4-Door
    1. 20 mm
    1. 25 mm
    1. 45 mm
    1. 50 mm
    1. 55 mm
    1. 70 mm
    1. 150 mm
All vehicles
  1. Remove the rear quarter window glass.
  1. Using a soft brush or vacuum, remove any dirt or foreign material from the pinch weld.
Installation
ani_caut.gif CAUTION: When installing urethane installed glass parts, the vehicle must not be driven until the urethane adhesive has cured. At temperatures above 21°C (70°F) and relative humidities above 50%, adequate cure time is typically 24 hours. (Refer to Essex drive away chart for the cure times as temperatures and humidity vary.) Inadequate or incorrect curing can adversely affect the retention of the quarter window glass.
  1. NOTE: Avoid scratching the pinch weld.
    Trim the remaining urethane adhesive. The urethane adhesive must be smooth and free of cuts and contamination after trimming. Avoid touching the urethane adhesive after preparation.
  1. Apply the urethane metal primer to any exposed or damaged metal on the pinch weld.
  1. If reinstalling the original rear quarter window glass, remove the excess urethane adhesive.
  1. Clean the rear quarter window glass with a non-alcohol based window cleaner.
  1. ani_caut.gif CAUTION: Wipe off the urethane glass prep immediately after each application because it flash dries.
    If installing a new rear quarter window glass, apply urethane glass prep twice around the glass surface to be urethaned.
  1. If installing a new rear quarter window glass, apply urethane glass primer to the same area that was prepped in the previous step. Allow 5 minutes to dry.
  1. Cut the urethane adhesive applicator tip to specification.
  1. Apply a bead of urethane adhesive on top of the existing urethane bead on the pinch weld. Make sure that all gaps in the urethane adhesive are smoothed into one continuous bead.
  1. Position the rear quarter window glass to the flange, and press the retaining tabs into the flange to engage.
  1. Install the rear quarter window glass.
  1. Check the rear quarter window glass installation for air or water leaks through the urethane seal.
  1. Install the C-pillar trim panels. For additional information, refer to Section 501-05.
May 29, 2009 | 2004 Ford Focus
Cobra 29 LTD CLASSIC C.B.
You should not cut the modulation diode, you should adjust the potentiometer VR-4 for full modulation. By cutting the diode, you risk over modulating. By turning up the pot, you can correct for an over modulation.
If you are still insistent on cutting the modulation limiter, it is D11, located directly in front of VR4 and C73. Looking at the radio from the front to back, it is in the right corner, apx 2 1/4" from the back and 2 3/8" from the right side.
Dean Pitts
Rollin CBs
Nov 17, 2008 | Radio Communications
Home Logo
1,134 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
