Question about Philips HDD1630 MP3 Player
My philips mp3 help
When i go to turn on my mp3,it turns on and the philips pops up.seconds later it says low battery but if i try and charge it, it doesn't charge.
  • 3 more comments
  • menothim Dec 22, 2007
    same pluged in its fully charged unpluged out of charge
  • Anonymous Dec 23, 2007
    I have the same problem. It will not charge. Have one cable that is USB and other for charging. Don't know if it is the charger itself. USB does read, but charging will not work.
  • Anonymous Apr 04, 2008
    i turn on my mp3 and phillips pops up and it stays on phillips and then it starts making this clicking noise and it wont do anything except tick help!
  • Anonymous Aug 12, 2008
    mine wont charge at all will not even turn on
  • rayray011982 Aug 12, 2008
    mine wont charge at all it wont even turn on does anyone know where to get a new battery for it
When hooked up to usb/charger hold the + volume button and then hold the power button
Posted on Aug 03, 2008
Restet it to factour settings you dont lose anything but it will now charge
Posted on Dec 29, 2007
Same thing happened to me and i charged and it said to connect it to ur computer and it might work
Posted on Jul 10, 2007
SOURCE:
Philips SA5125/37 mp3 player
Try removing batteries and provide more details.
Aug 01, 2008 | Philips SA5125/37 MP3 Player
My mp3 isnt charging right
Make sure the hold/lock is not engaged
Try another USB port
Reset the player
If that fails:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
If still nothing:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Mar 25, 2009 | Philips SA3025/37 Flash MP3 Player
My battery died ,it won't turn on and the computer can't see it
It could be a hardware issue requiring replacement, but here are the things you can try to narrow it down:
1. Make sure the hold/lock is not engaged
2. Reset the player
3. Run an Updated using the latest version of the Philips Device Manager from Philips website
4. Run a Repair in Philips Device Manager
Triple Reset for Philips’ GoGear:
-Tha Mp3 Doctor
Mar 10, 2009 | Philips GOGEAR SA6045 MP3 Player
Turining my mp3 player on
You need to upgrade the firmware
-Tha Mp3 Doctor
Nov 28, 2008 | Philips GOGEAR SA6045 MP3 Player
Help
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Aug 03, 2008 | Philips GOGEAR SA6045 MP3 Player
Phillips MP3 Go Gear
Does not play well with Windows Media Player 11.
-Tha Mp3 Doctor
Apr 25, 2008 | Philips GoGear SA178 MP3 Player
Go Gear Trouble
Try this:
Make sure the GoGear is disconnected from the computer
Turn the goGear off
Reconnect the goGear to the computer while holding in the volume + button
Continue holding the volume + button for 20-30 seconds until a "Found New Hardware Wizard" window pops up
If this does not work, the GoGear is toast, call 1-888-PHILIPS and see if you are still in warranty
Apr 13, 2008 | Philips GoGear HDD6330 MP3 Player
MY PHILIPS MP3 WONT TURN ON !!!!!!!GRRRRR I NEED HELPPPPPP!!!!PLIZZ
WARNING: this process will erase all songs off the GoGear.
Disconnect the GoGear from computer.
Turn the GoGear off.
Hold in the volume + button.
Reconnect the GoGear while holding in the volume + button.
Continue holding the volume + button.
After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now).
Good To Go (Gear)!
-Tha Mp3 Doctor
Apr 04, 2008 | Philips SA5125/37 MP3 Player
Mp3 philips hdd082/17 not charging and not connected when connected to usb
Good To Go (Gear)!
-Tha Mp3 Doctor
Mar 24, 2008 | Philips HDD082 MP3 Player
Philips HDD1630 MP3 Player Logo
194 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
