Question about Garden
Hitachi Ex35 overheating
Overheating excavator
5 Suggested Answers
emissionwiz
  • 80626 Answers
SOURCE: hitachi ex120-5 hydraulic excavator engine overheating
We have no solution as we have no info on commercial equip like this. Sorry
Posted on Feb 22, 2012
gopakumarg43
  • 75591 Answers
SOURCE: Have a Hitachi Plasma TV that works but powersupply is overheating.
There should be some sort of short circuit. Contact any experienced service technician. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Posted on Feb 22, 2013
  • 17328 Answers
SOURCE: overheating radiator
What is the make and model?
Posted on Mar 01, 2013
  • 51280 Answers
SOURCE: Why won't my excavator stop overheating?
industrial equipment that operates in dusty conditions has a problem with the dust collecting in the radiator fins and blocking the air flow or the fan or restricting the ability of the heat to transfer form the cores though the fins to the air
check if it has a viscous fan hub ( fan clutch) then replace it
check that area out first and clean with water if dusty
next check the hydraulic oil temperature. It it is cooled by an external transmission cooler , it may also be blocked by dust
Oil flowing too fast through a cooler will not transfer the heat to the air so it may need a small restricter in the line /fitting to slow down the flow of the oil
excessive oil will froth up and over heat
failing motors and drives will pass oil under pressure which contributes to over heating of the oil
if the oil is cooled by engine coolant through an heat exchanger that will add to a radiator that has less that sufficient capacity to do the job
from the forums I would suggest that you get the manufacturer service division involved and have the problem properly diagnosed and permanently fixed
Posted on Oct 15, 2015
If 75 landy Hitachi track hole. My swing motor,manifold union center is leaking. I would like to know how to fix it myself. Or how much it would cost to have someone to fix for me.
Hitachi Deere Excavator Center Joint / Rotary Manifold ...
? 10:00
https://www.youtube.com/watch?v=Vsd_Os6WFCw
Mar 12, 2013 - Uploaded by woodieswood
Hitachi Deere Excavator Center Joint / Rotary Manifold Rebuild ... my Hitachi landy swing brake keeps ...
Viewing a thread - Hitachi Excavator- Swing motor gearbox leak ...
talk.newagtalk.com/forums/thread-view.asp?tid=362837...flat...1
Jan 30, 2013 - 3 posts - ‎3 authors
Hitachi Excavator- Swing motor gearbox leak ... 10000 hrs that I am thinking the seal on the swing motor reduction gearbox went out. ... but a friend that works on construction equipment said to check the swivel manifold.
Dec 08, 2015 | Cars & Trucks
Search Results
    Solving Hydraulic System Overheating Problems
    www.machinerylubrication.com/Read/680/hydraulic-overheating
    Overheating ranks No. 2 in the list of most common problems with hydraulic equipment. Unlike leaks, which rank No. 1, the causes of overheating and its ...
    Cat 320 overheating - Heavy Equipment Forums
    www.heavyequipmentforums.com/showthread.php?2828...overheating
    Mar 28, 2007 - 15 posts - ‎10 authors Anyone here have a problem with a Cat 320 overheating? ... that many heatingproblems in excavators are caused by hydraulic problems. 5T Excavator KX161-3 overheating
    Apr 22, 2013
    john deere 270D excavator over heat
    Aug 1, 2011
    cat 305CR overheating issue
    Jul 23, 2011
    cat 312 overheating
    Jul 31, 2008
    More results from www.heavyequipmentforums.com
Oct 14, 2015 | Cars & Trucks
How do i go about finding a service manaul for my Hitachi EX60Mini Excavator? I was told it was a grey market machine by the dealer.
go DownloadAManual.net and there is a manual listed for hitachi ex60-3 excavator service manual download
The dealer may be saying that it is a japan machine made under licence in china and is not covered by the hitachi warranty properly and because of that dealers are reluctant to work on them as they are considered inferior product
Oct 13, 2015 | Hitachi Televison & Video
I have a 08 infiniti ex 35 journey with 75k,it had an overheating right now has a bubbles on the radiator at engine satrted ,white smoke in the morning associates to water occasionally. My question is ,if...
Yes a head normally can be milled (shaved) down and a new gasket installed to fix the engine. Be sure to fix WHY it overheated too. Of course change oil and coolant too!
Mar 23, 2015 | 2008 Infiniti EX35
Overheating radiator
you might try a new cap it may be bad
Feb 28, 2013 | Cars & Trucks
OverHeating PC60-6 1995 Excavator Issues
Save your hair, Silvano, it's not worth it.
When you did the head gasket, did you check the head for cracks? Sounds like the problem does originate in the engine. That's where the temp sensor is located. That's where it would get hot first.You might want to have the head magnafluxed to check for hairline cracks. Good luck.
Mar 30, 2012 | Cars & Trucks
Hitachi ex120-5 hydraulic excavator engine overheating
Feb 21, 2012 | Cars & Trucks
Our hitachi 50c20 is overheating and turning off. It also has a red tint on whole screen when playing. We replaced the bulb but still the same. It is located in a well ventilated area.
i dont know about the overheating problem, but as far as the red tint goes, it you go to the picture setting within the menu and reset it to default, it should take care of that.
Jul 03, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Show to overheat
I would think that the wire to the water sending unit has rubbed through to ground somewhere so its reading false.
Apr 15, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
