Autocad 2010 failed to run properly (0xc000007b). click on OK to terminate the application
Operating system 64bit
  • 27,725 Answers
You might have to uninstall the current version of autocad you have on your computer then restart your computer then run the jet clean utility. http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. Then delete cookies Here is a very simple guide on how to delete cookies manually from your computer.
Click on "tools" in your browser. This is usually located in the upper right corner of your browser. Click on Internet options. This will appear in the drop down box and is usually at the bottom. Under the "General" tab look for "Browsing History." Under this heading you can click "Delete" to have the computer delete all cookies for you automatically however to delete the cookies manually click on the "Settings" tab Click on the "View Files" tab under the "Temporary Internet Files and History Settings" box that pops up. When you do a second box will pop up with a list of cookie containing files. This may take a few seconds to load so be patient while waiting for the cookie files to load. Highlight any cookie file that you would like to delete. You can highlight more than one at a time by holding down the 'Ctrl" button on your keypad Delete the files that are highlighted by clicking on the "delete this item" located to the left in the same box. As soon as you do you will see the selected files disappear. When you are done just "X" off; this completes your task of manually deleting cookies. You might also do a disk clean up click start click on computer to open right click on your hard drive usually C: select properties in the general tab select disk clean up click ok you can view files to be deleted. Then reinstall it
Hope this helps.
Posted on Jan 15, 2013
See this:
http://www.trevisoassistenza.it/guide/17-impossibile-avviare-correttamente-l-applicazione-0xc000007b.html
It's in italian...
Posted on Jan 17, 2013
  • 28 Answers
SOURCE: 0xc000007b error
re install windows - your computer has crashed.
Posted on Apr 26, 2009
  • 76 Answers
SOURCE: 0xc000007b
Could be a virus called WORM_KLEZ.E
Do a virus scan.
If theres no visrus try using system restore back to when the error message wasnt there.
Make sure automatic updates are turned on.
Posted on Aug 20, 2009
  • 1082 Answers
SOURCE: When i open some applications windows shows the
These error messages may be caused by the WORM_KLEZ.E virus, or one of its variations.
Go to trendmicro.com and run their free online virus scan. It can take a couple of hours to run and you must be connected to the internet.
It that doesn't do it let me know.
Posted on Sep 11, 2010
  • 145 Answers
SOURCE: The application failed to initialize
wash disk,,,,wipe with lint free cloth,,, reinstall
Posted on Nov 25, 2010
  • 90 Answers
http://www.thinkdigit.com/forum/software-q/43776-0xc000007b-error-application-failed-initialize-properly-0xc000007b.html
go through this link
Posted on Dec 30, 2010
Error 0xc000007b
fix 0xc00007b error "the application was unable to start correctly"
there may be multiple reasons as to why you might receive 0xc00007b error when trying to run an application on a windows machine. 0xc000007b error usually comes from mixing up 32bit environment with 64bit one. For example 32bit application loads a 64bit dll causing 0xc000007b error.
Solution 1
In most cases it's .NET framework causing issues. This can easily fixed by re-installing latest .NET framework from [link]
Solution 2
Re-install the application that you are trying to run. It sounds simple but the application data files could be corrupt or missing. This could be caused by a installation that did not complete successfully or by a virus.
Solution 3
Running the application as an administrator could fix this error. Right click on the program shortcut or program .exe file, then click on Properties, and on the Compatibility tab. Check the Run this program as an administrator box, and click on OK
Solution 4
Restart your computer as some applications require restart after installation to function properly.
Solution 5
Run Windows update as it can provide application fixes and updates. Furthermore it installs missing drivers and updates the outdated ones like graphic card drivers. Windows 7 / 8 / 8.1 users need to search for "windows update". select all important and optional updates and click on the "install updates" button. If you use Windows XP navigate navigate to Windows Update by choosing Start > All Programs > Windows Update. When the scan is complete,Click the Review and Install Updates link. Finally press the "install now" button.
Windows 7 / 8 / 8.1
Windows XP
Solution 6
manually update the application if possible.
Solution 7
re-install Microsoft Visual C++ from [x32 link] or [x64 link]
Solution 8
re-install DirectX [link]
Solution 9
Many times hard disk problems can be repaired using the chkdsk command. If you are using windows 7 press the start button in bottom left corner of your screen. If you are using windows 8 / 8.1 press the windows key .Search for "cmd" and Right click it and select "Run as administrator". Windows XP users Click on start > run. In the Run box, type in "cmd" in the box.
Windows 7:
Windows 8 / 8.1
Windows XP
A CMD window should appear. In that window you can just type it as you see "chkdsk c: /f /r". If you have more then one drive or partition, you will need to tell it the disk (chkdsk d: /f /r).
If it is the primary windows disk c: it will ask you to schedule it for next boot. When you restart, it will do a chkdsk for you before even getting to the login screen.
Solution 10
This solution only works for a 64-bit system. It requires replacing files is system32 directory so be careful. Only attempt this solution if you are confident and if other solutions have failed. When Microsoft Visual C++ Redistributable Package is not properly configured it may cause 0xc00007b error. Firstly download the zip file [link] and decompress it. Reboot in safe mode and go to C:\Windows\System32. copy all files included in the zip package (mfc100.dll, mfc100u.dll, msvcr100.dll, msvcp100.dll and msvcr100_clr0400.dll) to C:\Windows\System32 replacing the current ones. After that reboot in normal mode.
If all the solutions above haven't worked i would consider backing up data and performing a clean install of windows.
Jan 11, 2016 | Dell Inspiron Computers & Internet
Assassin creed 4 0xc000007b error
Download Reginout to fix 0xc000007b error simply with some couple of clicks.
Jan 07, 2014 | Microsoft Windows 7 Home Premium 64BIT...
0xc000007b
0xc000007b is usually caused by a corrupt registry entry. The best thing you can do, to prevent your PC from getting more error messages or further registry corruption, is to fix this problem immediately, by following the easy instructions below. The potential risk, resulting from not repairing this error, could include system crashes, blue screens, and hardware failure.
  1. Download the 0xc000007b Repair Tool
  2. "This is a free download - You'll see a new window pop-up for confirmation."
  3. Click "Save File" and follow the simple installation instructions.
  4. Scan your computer with the Regcure application.
  5. Click the "Fix Errors" button to repair 0xc000007b.
Feb 18, 2011 | Microsoft Windows 7 Home Premium 64BIT...
When i open some applications windows shows the message 'the application failed to initialize properly (0xc000007b).click ok to terminate the application'
Jun 14, 2010 | Microsoft Windows XP Professional With...
0xc000007b
Do a virus scan.
Aug 20, 2009 | Microsoft Windows XP Professional With...
0xc000007b error
Apr 19, 2009 | Microsoft Windows XP Professional With...
Computers & Internet Logo
1,180 people viewed this question
David Payne
David Payne
