Question about Lexmark X5150 All-In-One InkJet Printer
Any colour print is flooded with blue ink
Every time I try to print anything with colour in it the coloured part of the print is flooded with blue ink. Black text is fine.
I have hooked up another X5150 using the same cartriges and the same thing happens.
The cartriges had been fine until this suddenly started happening.
  • 24 Answers
Sounds like a bad cartridge and it will be about empty by now anyway.
You can clean the contacts on the cartrdge gently with a pencil eraser.
If it does this with a new cartridge you should uninstall and reload your device with the latest drivers from the website.
Lexmark is notorious for poor driver support.
Good luck! Jidza
Posted on Jan 23, 2009
I want to print in white ink on black paper. I have a Canon MX310 printer
Inkjet printer inks are dye-based, and that's the reason.
Perhaps this will help explain things. You know those little boxes of food colouring you can buy in the supermarket - the ones that have four little bottles of colour - red, blue, yellow and green. Within reason you can combine these to turn white icing into most colours. Use nothing and the icing is still white or use everything and the icing will go a black-brown colour. Use a couple of drops of red and blue and you'll get purple.
But if you start with black icing, there's nothing you can add that will make it anything but black.
It's the same with your inkjet printer - because white is obtained by not having any ink print on the white paper. But of course that only works when the paper is white. Naturally you'll get different results on all colours of paper, decreasing as the paper gets darker in colour. Print blue on yellow paper and you should get green printing.
The only way to print in white is to do what commercial printers do - use opaque inks and include a white ink in the process. And as far as I know there's no commercial ink that will do that with an inkjet printer.
I can hear lots of you muttering "Rubbish. Of course you can print light colours on dark paper." Well all I can say is, have fun experimenting, but you won't be able to do it.
About the only way to achieve the sort of result you may be after is to print the job then trim it and paste it in place. For instance, if you want to print onto a black or dark-coloured T-shirt then print onto white transfer material, trim the print to size and iron it in place.
Dec 29, 2010 | Office Equipment & Supplies
I have installed a new black and colour ink cartridge but it is only printing in black and blue- why is this?
Your printer head might be blook. For the reason all the colour of ink does not come out through the printer head nozzels. In this condition you should try to come out ink through ink nozzels. procedure
1. print a nozzel cheak. and see what colour does'nt come out.
2. Now open photoshop and take a a4 page and fill it with six colour and print it 5/6 time in a photo paper. If print does not improve call me again. I will give you second tecnique.
Thank you.
Sep 15, 2010 | Epson Stylus C46 InkJet Printer
It is printing everything with a green tint and I had not changed any settings. I have also gone out and bought two new ink cartridges thinking maybe the new one I had was defective. There is no change...
I have personally encountered similar problem in my work. There is no problem with your printer.
Sometimes when either of the inks overflow at the nozzle, it gets absorbed to an extent into another ink compartment. So that colour affected now prints another colour; the colour that has crept into its compartment, Sometimes it is serious at other times is not. If not serious, usually, after a few solid colour prints the colour affected returns to normal.
I do not know how much of a technical person you are, but I will give you the solution to returning your colours from green the right colour. Bring out your colour cartridge. Peel off the seal covering top of the ink cartridge. You will see the holes through which in is fed into it. Get a clean handkerchief, fold it and place over the top of the cartridge. Hold it over a bowl or something. Now place your mouth over the top with the handkerchief in between and blow hard. Ink will discharged at the nozzle. Clean off the ink. (At the nozzle do not rub only dab). Now press a piece of folded tissue to the nozzle firmly. It should be blotted with ink:- red, blue, yellow. If any colour is missing you may need to repeat the procedure. Once you get the three colours back, the issue is resolved.
Dec 21, 2009 | Kodak ESP 5 Printer
After replacing cartridge in dell 810 the colours printing wrong
If you haven´t used your inkjet printer for a while it may just be dry ink clogging some of the nozzles in the print head.
To check if yours is clogged...
Remove the ink cartridges
Holding the cartridge upright and press down gently onto a paper towel.
The colour cartridge
you should see YELLOW, MAGENTA (red) and CYAN (blue)
But if any colours are missing? The inks have probably just clogged up? and you will need to buy a new one or if you know you still have ink then you can easily unclog it with a
Magic Inkjet Flush Kit (Which you can find on Ebay)
If you have others colours coming out then the colours have mixed...
Sometimes caused when people put tape onto the inks to keep them moist but instead the colours mix through capilary action.
If so... leave print head sitting on a paper towel for a few mins until the correct colours appear.
Read more about ink clogs here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
To prevent an ink clog it is best if you print something regularly about every 10 days to keep the tiny print head nozzles / jets open. Otherwise the ink in the print head will thicken. Then it´s like trying to pass a camel through the eye of a needle.
So to preven inkjet ink from clogging print something every 10 days if you dont have anything to print, use something like these test prints
Good Luck!
Hope this helps you!
Tinteiros (Ebay)
Oct 28, 2009 | Dell 810 All-In-One InkJet Printer
Fuzzy ink
probably dirty or broken print head. suggest you replace it or get new blue cartridge if your machine has seperate colour cartridges.
Jun 17, 2009 | Brother MFC-5440CN All-In-One InkJet...
Refilled ink cartridges problem colour
this is not a printer problem, you have a problem with colour cartridge! u can fix this in 2 diferent way: 1. replace the colour cartridge with new one, or gently clean the nozzle cartridge with a wet tissue until the cyan colour mark a line on the tissue just like the others colours: yellow and magenta. maybe must repeat this several times.
Sep 13, 2008 | Canon PIXMA MP150 All-In-One InkJet...
download the utility ssc service from the site and use the power cleaning option
Aug 14, 2008 | Epson Stylus Color 640 InkJet Printer
Only prints black & blue
I have a similar problem - i can print all colours apart from red.
I've tried cleaning, deep-cleaning, and even bottom plate cleaning but of none if this improves anything.
Tried cleaning the print heads and nozzles with cotton buds, but this dont do anything. Even tried re-seating the cartridges but this does nothing either
Mar 21, 2008 | Canon PIXMA iP2000 InkJet Printer
Red ink not printing
the channels for the ink to flow are really minute [small] if ink dries up in them it can take some time to soften it up before anything will flow. try deep cleaning the printhead.
Jan 07, 2007 | Brother DCP-110C All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
74 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
