Question about Xerox Phaser 6180N Laser Printer
Toner not sticking to paper
When I print a page which requires a large amount of toner it does not stick tot he paper it simply rubs off and gets all messy on the page. Often leads to a jam at the fuser. I have done a total of only 30,000 pages.
  • Xerox Master
  • 32,281 Answers
If the toner rubs off the paper then the fuser unit is probably faulty. The fuser heats the toner/paper and fuses the toner to the paper.
Posted on Jan 14, 2013
  • 208 Answers
SOURCE: Paper jam 2 fuser
1. Faulty/blocked fuser exit sensor or faulty/blocked POB sensor. The printer thinks paper is present at one of these sensors when there should not be paper present. Verify that the fuser exit sensor is not stuck Verify operation of the POB sensor If both sensors are working correctly, the most likely cause is the POB sensor is being blocked by the transfer unit. This can happen if the sensor is out of position, or if the transfer unit's white plastic baffle is out of position. Try bending the POB sensor bracket outward slightly to clear the baffle and retest
Posted on Dec 20, 2007
SOURCE: Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Posted on Nov 04, 2007
  • 208 Answers
SOURCE: Paper jam at fuser
If both sensors are working correctly, the most likely cause is the POB sensor is being blocked by the transfer unit. This can happen if the sensor is out of position, or if the transfer unit's white plastic baffle is out of position. Try bending the POB sensor bracket outward slightly to clear the baffle and retest.
Posted on Dec 19, 2007
  • 2072 Answers
SOURCE: Phaser 7300N paper jam
What code is comming up with the jam? That would help me narrow it down for you.
Posted on Apr 05, 2008
  • 32 Answers
SOURCE: Xerox Phaser 8560 Color not correct
the problem is not with the printer but it is with the ink that might be damaged, this is located inside the printer
Posted on Dec 01, 2009
What is the amount of magnetic Powder to be developed in the Fuser Section?
None. It is electrostatic attraction.
It varies from each type of laser printer.
Most printers will specify a total number of pages printed from a laser toner cartridge rather than give an actual amount of toner per page. Which I feel would be more likely to be an average value.
Due to the amount of toner being used per page varying on the number of actual pixels that are required - a black dot or a color dot. If a colour dot is required Three toner colors may be involved to get the color required. Where there is a white dot no toner is required.
It really depends on what image is being rendered onto the paper on each different page image print onto the paper.
Color photos use more toner as more of the page is color than when using black and white !
Jul 02, 2015 | Office Equipment & Supplies
I get a ghost image when printing
2 things can cause this problem.Since I can not see the problem all I can do is tell both problems.If the image is black like toner in both places then you probably have a defective fusing assembly with coating worn off.It acts like a Teflon skillet with teflon worn off. The eggs stick to where the coating is missing.So with that said if coating is missing from fuser then toner sticks and comes off on the page on the next revolution.The other problem is with the drum/toner cartridge.The drum is not cleaning after the print is put on the page causing the image to repeat on the page.
Apr 12, 2014 | Samsung ML2525W Laser Printer
HP m410n laserjet pro banding gray vertical lines
the two places to look is transfer roller and the fuser unnit.
i think there is a problem with the transfer roller it is under the toner and it needs to be spring loaded. The paper passes between the toner an the transfer roller to charge the paper en let the toner stick to the paper and if it doesn't make correct contact then it wont work
Dec 26, 2013 | HP LaserJet Office Equipment & Supplies
Replaced toner cartridge 3 times (HP brand) but still get dark pages and the roller on toner cartridge is totally black with carbon. Is it something other than the 3 toner cartridges??
The cartridges are in a unit called a print drum. When the printer is printing, the drum is scanned with a laser which electrically charges certain parts of it. Then when it spins past the toner, the toner is statically attracted to the drum, and sticks to it only in certain areas. When the (statically charged) paper is run by the drum, the drum is wiped by another laser, removing its static charge, and the toner flies off of it and onto the paper, where it is then baked by a heat lamp.
During normal useage, not all of the toner comes off of the drum, there is a little waste. After a certain amount of time, the drum will need to be replaced. You can contact the same place you purchased the toner to get a new drum, and that will most likely solve your problem.
Jun 15, 2011 | HP LaserJet 4 plus Printer
I have a hp 4L laser printer when printing some of the [rint on the page is fine but there are areas that are faded bafly unable to read this does this even with a new toner-what can I doto fix this...
If its a laser printer you prob have a fusing issue. Its the part that actually heats the toner with fuser agent (light coat of oil) to make it stick to the paper and not smear. Either your fuser module is in need of replacing or you have something rubbing on the portion where the toner meets the paper. Chances are its the fuser module.
Feb 01, 2011 | HP LaserJet 4L Printer
Toner low
The toner is dry ink that sticks to the paper, and then gets melted into the paper. When the cartridge that holds the toner starts to run out, then the "low toner" condition occurs.
Keep using the printer until the toner-cartridge is empty, and your printed pages come out as "blank". Then, replace (or refill).
Aug 21, 2010 | Office Equipment & Supplies
Ghost printing
You have a worn image drum. The drum is the part of the printer that the print image is created on before it transfers the toner to the paper. This part is coated with a very thin layer of Teflon so the toner does not stick. When it gets worn the toner starts to stick and that produces the shadow or ghost image approximately 3 inches down the page because the diameter of the drum roller is 3 inches. You will need to get the part DR-350, Office Depot has them as well as many places on the internet.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
May 14, 2010 | Brother MFC-7820N Laser Printer
Black smudge streaks on rightside of printed/copied material
Can only be two things the drum or the fuser. More than likely drum they last about 4 toners i think.
Learn the art of getting a page to stop halfway threw printing, you want to stop the page after the drum has put a image on the paper but before paper has gone threw the fuser (hotbit).
Once you have mastered the position correctly by stopping the printing by opening the door and removing drum/toner cartridge, to reveal the paper that is printed but can be rubbed off, we will know if marks are coming from the drum (you will see them) or from the fuser, if print is fine.
Dec 17, 2007 | Brother MFC 7420 All-In-One Laser Printer
Large grey streak down center of page
It is the fuser at rear giving you grief! The upper heat roller has a teflon coating that wears away allowing toner to stick to roller and smudgin prints as they pass threw it. The fix is to replace fuser assembly, take to brother dealer to fix.
You can prove it to yourself by timing the print to stop mid way threw machine then remove print cartridge and look at paper, you should see a image is good untill it hits the fuser,( pre fused image "rubs off" paper.) If you have changed drum and toner thats all it can be. They all do it in time.
Fuser is hot bit at rear, pull out drum and look in the back with a small torch you will see upper heat roller is worn, guestimation $90 for fuser plus labour to fit.
Nov 16, 2007 | Brother IntelliFax-2820 Laser Fax
Xerox Phaser 6180N Laser Printer Logo
742 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
