Question about Canon Cameras
How can I clean out the inside of my lense?
Every time I look throught the viewfinder I see a speck of dirt. I have cleaned the camera and the outside of the lense but it seems that the dirt is inside the lense. Is it possible to clean it?
  • ARCHANA Jan 15, 2013
    bangalore canon service contact 9035871324
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 33 Answers
Dont worry about dust too much unless it actually affects your image sensor.check it by pointing to a white wall or sky with f put to it maximum like 32/22 , focus and take pictures.. if its problem with the lens then it will make prominent dark speckles on the image.. but if you get dark speckles even at lower f - stops like 1.4/3.5/5.6 then its dust in the sensor.
dont try cleaning your sensor yourself as you may spoil it and finally have to refer a service center of the brand .
Posted on Feb 06, 2013
  • Debrup Chatterjee Dec 02, 2013
    Hi there , there is another possiblity, view finder dust is also visible if there is dust on the glass of the viewfinder, when you open the lens from the body and look in the mirror you can see some spots in it, clean the mirror and check.. if it is still there then check just above there is another glass like thing above with transluscent window , which is actually the prism for focal points.. just clean it gently and the dust will go.. you dont need to clean the sensor mostly // from my experience it mosly a problem with the outside compartment so you dont need to move the mirror up to reach the sensor..
  • 4 Answers
There are plenty of places on the web where you can buy a lens cleaning kit. These usually contain some form of air blower that can be used for removing dust.
Just be very careful, other wise you will end up with a scratch on your lens
Posted on Jan 14, 2013
  • 4 Answers
Your best bet is to take it to a professional and have them look at it. Otherwise you run the risk of damaging the lense permanently
3 Suggested Answers
  • 37 Answers
SOURCE: cleaning out dirt and dust inside nikon fg camera
FG's are pretty tough old cameras. You can use a cloth and a lenspen brush, but be very careful of the shutter curtain...its delicate and if you damage it you might as well get another FG ($30 or so on Ebay). My first Nikon was an FG-20...still works like new.
Posted on Nov 03, 2007
SOURCE: dirt on the inside of the front lense
Hello, I very much doubt that a small piece of dirt on the lens is a problem. It is more likely that your sensor needs to be cleaned. Sensor dirt is more visible at small (f11 to f32) apertures. I expect that you are shooting bright snow with a small aperture & this is why you are seeing the problem. To check, try the following.
Set camera to Av, ISO 100.
take some photos of the sky, a blank wall, or some other featureless surface, as follows:
1 - Set aperture to highest possible f - number.
2 - set aperture to lowest f-number.
3 - repeat 1 with a different lens
4 - repeat 2 with a different lens.
I expect that you will see photo 1 and photo 3 will have identical smudges of dirt on them. Photos 2 and 4 should have no smudges. If this is the case, your problem is dirt on the camera sensor. The only way to fix it is to clean your sensor.
Posted on Jan 08, 2009
Looking through viewfinder i see dirt & black specks
It depends where the dirt is. Following the light path, look at the rear surface of the lens. A dirty rear lens surface will have the most affect on picture quality or what you see in the viewfinder of any position in the light path. Like all optical cleaning procedures, hold the lens with the rear lens surface facing the ground so gravity will work with you. Start by blowing clean air on it using canned air or a blower such as a Rocket blower or ear syringe. If that is sufficient, do not continue the sequence. This holds true at the conclusion of each step because the more aggressive your cleaning becomes, the more risk there is of damage. If it is still dirty, gently brush it with a sable or camel hair brush. If that is not sufficient, gently wipe it with a dry lens photograph lens tissue (do not use coated tissues) or a microfiber cloth. Finally, as a last resort, dampen a corner of a lens tissue or microfiber cloth (do not put the wet solution directly on the lens) and gently wipe with a circular motion. Finish by wiping with a dry section of the tissue or cloth. Although the front surface of the lens is not as important, repeat the process for the front surface.
If you still see the dirt in the viewfinder, are two possible remaining locations; the bottom surface of the prism located above the mirror or the mirror.
Clean the prism first and avoid cleaning the mirror if possible, or any contact with the mirror. The prism can be cleaned following the sequence outlined above. If that doesn't work, the problem is the mirror.
CAUTION! The mirror is front surfaced and is very susceptible to scratches and other damage unlike a conventional mirror which is rear surfaced with the glass protecting the coating. Aggressive cleaning should be avoided.
Carefully follow step 1 of the lens cleaning procedure (air) and step 2 (brushing) if necessary. As far as the third and fourth steps, I would not use them myself because of the risk of mirror coating damage. It would be better to take your camera to a qualified repairman.
remove the lens and look above the mirror at the bottom of the viewfinder prism. If it is dirty, clean it as you would clean a lens surface. The next place to look is the mirror.
CAUTION! The mirror, unlike the mirror over your bathroom sink, is front surfaced and there is no glass between you and the delicate and easily damaged coating. Hold the camera with the mirror facing down so that gravity will work in your favor. If that does not work, I would stop and take it to a camera repairman because you do not want to risk scratching the surface by using lens tissue or cleaner.
Feb 05, 2013 | Nikon F100 35mm SLR Camera
My wife has a Canon 60D DSLR camera. When she looks through the view finder, it looks like the lens has a speck of dust on it as she can see it in the viewfinder. She has swapped lenses and the spec is...
Take a couple of pictures, over a dark background, if you can see the spec of dust on them, the problem might be in the mirror. Now, if the dust does not appear on the pictures, it's either on the viewfinder, or somewhere else out of the way of the sensor.
You should never try to clean the sensor by hand, always ask a profesional to do that for you.
Mar 10, 2011 | Canon EOS 60D Digital Camera
Pentax SMC D 16-45 Lens How to clean inside? Pictures are showing spots and all the outside lens have been cleaned along with the inside of the camera itself. Can not see the spots when taking pics only...
Your lens would need to be absolutely filthy with enormous dirt specks to cause the fault you describe. Dust, fingerprints, and regular minor debris simply doesn't show in the final image. In any case, you cannot clean inside the lens without dismantling it and that is a job for experienced specialists only.
Your fault is a dirty image sensor. You can buy sensor cleaning kits, but if you're inexperienced with them or trying to clean the sensor in a dusty environment you'll just make matters worse. Many camera shops offer sensor cleaning while you wait at relatively low cost. The reason you don't see the dirt when taking the picture is either because you're looking through the optical viewfinder or because the LCD screen simply doesn't magnify the image enough to show the marks which are present in the image.
You can prevent the dirt from reoccurring by never leaving the camera with the lens throat open for more than strictly necessary, and by always trying to keep the open lens throat pointing slightly down when swapping lenses.
I hope that I've helped, please take a moment to rate my answer.
Sep 16, 2010 | Pentax *ist DL Digital Camera
Clean dust inside the lenz
Don't. Unless there are some really big specks of dirt inside the lens then they will have no effect at all on picture taking. To prevent the problem getting worse always store your lens with it's front and rear caps on and inside a lens bag. Also make sure that your camera bag is clean and isn't shedding fibres from the inner linings.
Dismantling your lens to clean it is really a job best left to a professional who will then additionally check and clean/lubricate the moving parts inside the lens.
Jul 03, 2009 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
A dirt on a A200 viewfinder from inside (not the mirror)
Never touch the mirror... it will leave a mark. Is it underneath the viewfinder ? If it's not in the viewfinder, how do you know you have dirt. If there is dirt on the sensor, that's a decent pro job. Special ways to get to the sensor and cleaning is a very tricky job.
Jun 30, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
My Casio digital camera QV-R41 lcd viewfinder does not work
Turn the dail to a different position and try again.
Does your lense open up 100%. If not , clean the outside (around) the lense and turn on and off a few times.
If you feel the lense does not retract 100% or does not open up 100%, push it or pull the lense NOT too hard a few times.
Good luck!!!!!!!!
Jun 12, 2009 | Casio Exilim EX-S600 Digital Camera
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
Lens won't in on camera and makes clicking sound.
When you dropped your camera, some dirt got on the outside of the lense or some mechanical part of the lense broke or dislocated. If some of the mechnical part of the lense is damaged, you need to open up the lense from the camera and inspect the parts. Look for loose parts, then clean it and put it back.
I had the same problem with my sony Cyber-shop, but it was not dropped. somehow one or more small piece of dirt got on the outside of the lense. Here is what I did and the problem was fixed for good.
While turning the camera off, I pressed on the lense (up and down motion) softly. After a few times, the lense retracted 95% of the normal retracted position. I then, pressed the lense a little harder in untill it was fully retracted. It has been working okay since then.
You should always keep the outside of the lense clean and do not drop it.
Good luck
Oct 11, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Does dust specks inside lens cause blur in the pictures?
If you have a SLR camera you can take your lense off and clean it.. I do not reccoment canned air because if you do not use it the right way liquid will come out. At best buy they have cleaning kits, and in their kit they have a little brush that you can squeeze regular air and brush off anything on the lense or around the lense, If you have a SLR camera you might have a built in cleaning option... SLR means Single Lense Reflex and this means your lense can come off/interchangable..
Jun 12, 2008 | Canon PowerShot G2 Digital Camera
Black particles on focusingscreen
If the specks are just on your viewfinder focussing screen, they won't be on your pics. If they're on both your pics and focussing screen, you need to find someone else to clean your camera. Cleaning either your CCD sensor or your screen yourself can leave scratches. Changing lenses often can suck dust into the inside if the body is dusty. Try another repair shop for thorough cleaning - it shouldn't cost more than $50.
Dec 17, 2006 | Nikon D70 Digital Camera with 18-50mm Lens
Cameras Logo
829 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
