Question about RCA P52960 52" Rear Projection Television
I have a 10 year old 52 inch
The color went all red for about a month , now i have no red color at all , seems to have good blue and yellow , no red tries to flicked in once and awhile,,any help thanks alot
    Scholar:
  • 150 Answers
This might be a bad focus block/g2 block sometimes they go bad, they arent real easy to change out, but can be done.
Posted on Jul 09, 2007
SOURCE:
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
It seems that I am watching my TV in 3D.
im joel a simple electroncis tech. try to adjust the settings but it does'nt work the i think 3 color inside ( red,blue,green) is one or two of them is deffective.so the best solution try to go the expert tech nothing else
Apr 12, 2010 | RCA P52926 52" Rear Projection Television
Colors are overlapping
Is it bowed top and bottow? One fix and a common problem with this set is there is a fuse right next to the flyback the seems to open because of broken solder joints. There is 3 off them and the middle one seems to blow all the time. Check the fuse with a meter and see if its open. If it is, follow the next set of directions.
To fix this, you will need to resolder the flyback and several other components. Then jump the fuse or replace it. I have personally done both but I don't like to jump the fuse because it defeats its purpose as a fuse.
You will need a T-20 and a T-10 screw driver to take the back off. The flyback with be on the left hand side of the set with a red wire coming off the top of it and the fuses will be located an inch or so to the right of the flyback. If you have schematics, sorry I don't know the designations of the components. Another problem, I have seen is on the right hand side of the set. There is a ribbon cable about 2 inches wide. The topside board(Convergence board). That connector is also known to go bad as well. Replace the connector.
Dec 15, 2009 | RCA D52W136D 52 in. TV/DVD Combo
I have a toshiba 65hm167 no red color on the screen
Your TV is a DLP one lamp does it all, not like the old projection TVs with the Red, Green & Blue CRTs. Your TV may have a bad light engine or lose cable connections.
Good luck
N Sabre
Nov 08, 2009 | Toshiba 65HM167 65" Projection Television
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
52 inch sony rear projection
thats an lcd rear projection and that type of repair is better left to a professional but if you would like a service manual with free online tech support you can get one at the link I posted
http://servicemanuals.vstore.ca/
Apr 26, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KDF-E50A10 50 inch LCD
your optical block requiers replacing.not a cheap job.around £600.00
Oct 03, 2007 | Sony KDF-E50A10 50 in. LCD HDTV
Hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
RCA P52960 52" Rear Projection Television Logo
51 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
