Question about Home
What size airpot should I buy? - Home
    New Friend:
  • 56 Answers
Just large enough to contain the amount of coffee you will need for about half an hour. After that, the coffee will lose its flavor and quality.
Posted on Jan 14, 2013
Tip
How to properly clean and care for your airpot
To clean your airpot you have to first make sure that it is turned off and unplugged. Pour out the water that is still in the airpot if there is some and allow it to cool down. Once it has cooled down you can begin to clean it.
You want to start with a since of the inner lining using hot water. Use a sponge to get loose debris off the lining and rinse again.
Fill the pot up again with hot water and few drops of mild dish soap, let this solution sit for 10-15 minutes. Using your sponge again scrub the inside of the pot then make sure to rinse both the sponge and the inside of the pot to get all the soap out.
If there are any mineral deposits in the pot you should fill it with hot water and about 2 Tbsp of white vinegar. Let it soak for about an hour an then rinse thoroughly you don't want the taste of vinegar in your water.
To clean the spout you pour some of the water and vinegar solution out the spout then rinse with fresh hot water.
Finally to clean the outside use a damp cloth to wipe it down and a dry one to wipe it dry. in the case that you have stains on the outside use a mild dish soap to clean, rinse with clean cloth and then use a dry one to wipe dry.
on Oct 06, 2013 | Home
Brewer stops @ halfway thru airpot, will not let me adjust brew level
take front panel off and on timer board is a little switch. move it from on to 1 then hold breww switch till you hear 3 clicks
Mar 31, 2014 | Bunn CDBCF 15 Coffee Maker
Airpot problems
Lube the moving parts with crisco shortning. See if it is leaking air. The crisco should seal and lube it. Also using crisco wont cause any issues with a lubricant that is toxic.
Jul 12, 2013 | Update International Psvl30bksf 3. Liter...
What is a a recommended 2 Liter Airpot?
Regalware 2 Liter Airpot
pretty cheap for $44.95
works really well. coffee stays hot for a long time.
http://www.akitchen.com/store/airpot-brewers.html
May 09, 2013 | Home
How much coffee per hour does the Bunn VPR-APS Pourover Airpot Coffee Brewer brew??
Bunn's pourover airpot coffee brewer brews 3.8 gallons of coffee per hour.
May 09, 2013 | Home
What is the best airpot available?
According to Amazon: http://www.amazon.com/32130-0000-3-0-Liter-Lever-Action-Airpot-Stainless/dp/B001BQEHM4
Jan 14, 2013 | Home
Not enough water in airpot
Remove the front panel there are instructions on resetting the level.
Feb 25, 2010 | Bunn GMB-PS Coffee Maker
Can you turn a CWTF15-APS Airpot Coffee Brewer to a pour thru
Yes, most Bunn CW models have the ablilty to be used as a pour over. There should be a lid on top.
www.kaldi.com
Jul 20, 2009 | Coffee Makers & Espresso Machines
Home Logo
498 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
