Question about Samsung Tocco F480 - Pay Monthly Cellular Phone
I cant end a call using the red power key?
I can make call and recieve them however when it comes to ending the call the red key (power key) doesnt work? When the phones battery is removed and the red power key is pressed it does power the phone on??
Try and hold the end button for 12 seconds
Posted on Jan 23, 2009
HI I HV A HUWAEI M931 AND IT WAS WORKING PERFECT AND ALL OF SUDDEN IT DOESNT POWER ON AND I JUST GET A FLASHING RED...
Make sure the battery is full charger or remove it and use the power cable only .if the power work the problem is the battery. Press the power button 3 time then hold it until il power off. Turn back on. Open it and make sure the conection from the LCD is right pug it to the main circuit look for standby and weikup key combination on the manual.
Nov 23, 2013 | Huawei Cell Phones
Tip
How to reset Kyocera Zio m6000
Soft reset
Dial: ##4357*
Select view
Scroll down to select reset.
6 digit code: 000000
Click Ok
Should reboot.
Dial *228
Hard reset
1. Power down the phone
2. Hold down the volume up, end key, trackball and send key simultaneously.
3. Phone boots. After it vibrates you let go.
To reset Kyocera Zio try the following:
1. Remove battery and put it back after two minutes
2. Press and hold down the home button key while turning on the phone.
3. If by chance the phone starts , do Menu Button > Settings > SD Card USB MASS > Factory Data Reset
If it does not work, try:
Hard reset 2.
1. Power off the phone.
a. Press and hold red END key for 2 seconds >> Phone Options >> select Power Off >> Phone will shut down >> Ok
a)
2. Remove battery for 15 seconds & replace battery.
3. Power up the phone.
a. Press and hold red END key for 2 seconds and wait until the device powers up completely.
b)
4. Power off the phone.
Procedure, cont.
5. Press and continue to hold the Volume Up button using your left thumb.
6. While still holding the Volume Up key, use your right hand to depress the green Send key, the white Track ball and the red End key (sequential order).
7. Continue to hold all 4 until keys completely down until the handset vibrates twice then let go of the keys & track ball.
a. Formatting Data and Cache appears
1. If you do not see the above (Formatting Data and Cache) redo steps 1 through 7.
2. If you get a Fast Boot, Self Test or Blue screen redo steps 1 through 7.
3. Allow the phone to completely reboot. This may take a few moments.
4. The phone has now been re-set to factory default settings. Please proceed through standard set up and activation procedures.
If still no luck, call Kyocera directlyand report the problem.
on Sep 03, 2010 | Cell Phones
How to reset sanzo zio phone
WARNING: This process will clear all user settings and downloaded apps. Data on the SD Memory Card and My Backup will be retained. Prior to following the steps below, ensure the phone is powered off.
a)
b)
Procedure, cont.
8. Allow the phone to completely reboot. This may take a few moments.
9. The phone has now been re-set to factory default settings. Please proceed through standard set up and activation procedures.
Dec 02, 2011 | Sanyo Cell Phones
How to reset cricket zio
a)
b)
Procedure, cont.
NOTE: If you receive a self-test screen or blue screen, the hard reset was done incorrectly. Please try again, from step 1.
Dec 02, 2011 | Cell Phones
My kyocera sanyo cricket phone screen is locked how to unlock it
Hard Reset.
1. Turn off the phone
Phone is completely reset as if it came out of the box. You'll need to *228 and reload ALL of your data.
or WARNING: This process will clear all user settings and downloaded apps. Data on the SD Memory Card and My Backup will be retained. Prior to following the steps below, ensure the phone is powered off.
a)
b)
Procedure,
Sep 12, 2011 | Kyocera Zio M6000 Cricket
My phone isnt picking up the sense to touchscreen, everyone in my family has tried to unlock my phone but the touchscreen doesnt pick up a sense, and its just frozen it will power off and turn back on...
A friend of mine had this same problem with an LG Ally. Eventually he had to remove the battery from the phone and replace it before the screen would respond. Some other things to try if that doesn't work:
  • Remove any screen protector you may have put on the phone. It is rare, but sometimes these can interfere with touchscreens of certain types
  • Reset the phone to the factory defaults (steps below):
  1. Turn the power off.
  2. Press and hold: Home Key + Power Key + Up or Down Volume Key.
  3. Turn the power on, while keeping the three keys pressed.
  4. When the LG logo is shown, release the keys.
  • Failing the above, I would return the phone to the retailer from which it was purchased. It's possible that the touchscreen is simply flawed.
Mar 07, 2011 | LG Ally Cell Phone
I need to hard reset my sonyo zio
Zio Hard Reset From Cricket corporate
a)
b)
Procedure, cont.
Nov 17, 2010 | Google Android
My phone hanging often so pl say the way to reset
These are the steps:
  • Switch-off the phone (Remove the battery and re-insert it, if necessary).
  • Now Press and HOLD the GREEN (Call) key, RED (Call end) key and the Camera-capture key SIMULTANEOUSLY.
  • While still pressing the above three keys press the power On/Off key, hold them until phone boots up.
  • If these do not work out USE THIS CODE: *#7780#
Nov 08, 2010 | Nokia 5800 XpressMusic Smartphone
G1 got wet-end button acts like it's stuck & back key doesnt work
call and get it replaced. DONT TELL them about the water. simply state it doesnt make calls and get them to send you a waranty replacement. It is free, but remember to tell them there is no damage to the phone, as long as the white dot is still white and the phone doesnt look physically damaged you are good to go
Aug 24, 2009 | HTC G1 Smartphone
Phone does not boot up completely
you either have a small lesion in your power reciever or have a particle stuck in your phone. try using a air duster to clean it if it doesnt work the take it in but it will be cheaper to get a new one
Jan 05, 2008 | Samsung SGH-d407 Cellular Phone
Samsung Tocco F480 - Pay Monthly Cellular Phone Logo
98 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
