My Thermador bathroom wall heater switch broke. How do I turn it off?
2 Suggested Answers
SOURCE: I have a thermador bathroom ceiling heater fan.
Amazon.com: bathroom ceiling heater Broan Product Detail
If you have the old Thermador ceiling type of heater that must be mounted on the ceiling surface there aren't many choices. Only the Broan-Nutone 154 & 157 models. The 154 @ $37 didn't seem to last too long but it's 1/3 the price of the radiant 157 model at about $100+ dollars. The radiant model may last longer
Posted on Sep 19, 2010
What is the switch for by the bathroom sink
The hot water tank heater?
The pump in the well?
The pump in the Jacuzzi bath?
The baseboard heater, wall heater, towel rail?
We just have to guess these things :>)
Jan 01, 2016 | Home
Dimplex bathroom fan heater cord problem
take the cover off and clean the inside and were the cord is and use some wd 40 turn of the supply first and that should loosen it for you
Jan 06, 2014 | Dimplex Fx20ve 2kw Timer Wall Mounted...
Dimplex Fx20ve 2kw Timer Wall Mounted Bathroom Downflow Fan Heater Pull Cord is stuck
turn of the powere and take the cover off and clean the pull cord and the use a bit of lubricant to keep it free that should loosen it
Sep 24, 2013 | Dimplex Fx20ve 2kw Timer Wall Mounted...
Hi: I have an bathroom heater fan, Thermosafe model:3208,(new Zealand) one day i found out that i could not turn it on, it even not make the "clip" sound (this heater wasn't designed...
From your description, it sounds like the pull chain ON/OFF switch is broken.Admittedly, this is the first time I have ever heard of a pull chain switch being on an electric heater, But, I guess it is in the ceiling and not wired to a wall switch, it's the only way to turn it ON or OFF. I wouldn't think that replacing the pull chain switch would be that difficult or expensive to replace. Most home centers and hardware stores sell this type of switch for use in ceiling fans, The key would be removing the faulty switch and taking it with you to buy a new one. You want to be sure that the new switch matches the amperage and polarity of the old switch.
As far as the unit only being a year old and the switch failing so quickly ... it's in a warm moist environment 24 hours a day. It doesn't surprise me that the switch broke. You might want to consider replacing the pull chain switch with a hard wired wall switch. Certainly, it would cost more than replacing the pull chain switch, but you'd never have that problem again.
I hope this helped you, Mary. Please let me know.
Jul 14, 2011 | Heating & Cooling
Hi - I have an old Glen Dimplex CLX (I think is the name) wall heater. The switch for turning on the heater broke 2 days ago. It sounded like a fuse blew. How on earth can I get this fixed?!
You say the heater is 'old', so I assume that it's out of its 2 year warranty? Are you referring to the wall-switch or the switch on the heater itself?
The customer service department will be able to give you guidance on finding the problem and resolving it. If you call 0845 600 5111 and have your series number (top left of the unit) and model (CXL) to hand they will be able to help you.
P.S. Please don't try to take the heater apart or remove it from the wall unless you have experience in working on storage heaters, as the unit is VERY heavy!
Nov 16, 2010 | Dimplex DXLWP400 Electric Wall Mounted...
We used to have hot extremely hot water in both bathrooms. One day, the water became warm and ultimately cold in one of the bathrooms. Now, the water is also freezing in the bathroom where the water used...
Your check-valve has most likely failed at the switch.
The flow check valve works by opening when you turn the water tap. When it opens it closes a switch which turns on your heating elements. When this switch fails you will still have water flow, but no heat. Titan has parts for this but you will need to call their service Dept.
or call
Toll free support pesonnel hours (EST): Monday-Friday: 9:00am - 5:00pm
They also have an online support operator during normal business hours here
http://www.titanheater.com/livehelp/livehelp.php?department=2
Mar 24, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Need heat element for fasco wall mounted bathroom heater, the element is M shaped
try to found a local manufacture for heating elements, like http://rezistoterm.xhost.ro/ , give them the old heat element and the power of the bathroom heater (ex: 3000W and 220v, or 2000W and 110V) and they wil macke new oane and much chep like an original one.
Feb 14, 2010 | Fasco Heating & Cooling
I have a thermador bathroom ceiling heater fan. Where can I get a replacement?
Sep 02, 2009 | Heating & Cooling
My dimplex wall fan heater fx20 switch broke and i
www.torreelectrics.co.uk/acatalog/Dimplex_wall_fan_heaters_FX20.html try this site
Jul 28, 2009 | Heating & Cooling
Bathroom ceiling fan has stopped working
remove the switch and test it with a meter on ohms or remove the switch and disconnect the fan wires and connect the fan wires to an extention cord to test.
Phil
Jun 09, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Heating & Cooling Logo
383 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
