Question about Sanyo Televison & Video
How to operate the TV model LCD-32XZ10
What "source" needs to be entered to watch television? DTV,ATV,ATV1,ATV2,Cop1,COMP2.HDTV1,HDTV2,,HDTV3??????? Once you choose which source am I supposed to push one of the colored buttons, or the guide, or channels? We can't figure out the combination.
SOURCE: Digital Tv is stuck on a channel
I have found the solution at last :)
Put the TV in standby and press these buttons in order
Info, Menu, Mute and Power on.
You will then see a hidden menu, on line 12 select reset
Bingo :)
Posted on Dec 30, 2007
SOURCE: Mintek 26 lcd hdtv, model DTV 265D
Have Mintek DTV-265-D that is frozen. Any suggestion to correct this problem?
Posted on Feb 13, 2008
SOURCE: LCD TV LA40A650A1F. TV/DTV
samsung advised  atv/dtv selection by that button not available on australian series 6
Posted on Sep 23, 2008
SOURCE: mintek 26" lcd hdtv dtv 265-d
I have two Mintek 236 26" screen t.v.'s that I purchased from QVC. The first one went on the fritz just after a year and now the second one is only playing one channel and none of the manual buttons work. I can only turn the tv on and off. This seems like a common problem with thse tv's. I just found my owners manual. So here is the customer service numer...1-877-646-8358 m-f 8:30 am to 5:30 pm. I hope this is useful. In the future though I wont purchase another Mintek. Not worth the money.
Posted on Jan 24, 2009
SOURCE: how to tune my digital chanels in my bush lcd tv
i just saw a post which I believe will solve my problem (I connected to the wrong coax antenna plug). I haven't tried, but I'm pretty sure that is the problem.
Here's the post from akai_owner from 2007:
Look at the back of your TV. Make sure your cable is hooked up to connector on far right, NOT the far left. (For analog cable TV.)
Push "source" button on remote or side of TV to cycle through TV inputs. Wait one second between pushes. You want to stop just before the source that displays "AV" on TV screen. It should show a number, for the current channel number.
If you are using an analog cable box, try setting the TV channel to 3 or 4. If you use no cable box, try changing channels on TV to find an active one. If no luck, make sure your cable service is active (subscription active). Cable companies disconnect it between residents of an apartment/house.
Posted on Jan 30, 2009
What channel do I put my LG TV on to connect my Sony blueray player to watch netflix
channel is not the correct path
you need to be thinking What input source do I need on the tv
atv dtv - THIS IS FOR AN ANTENNA CABLE
hdmi1 hdmi2 hdmi3 av1 av2 these are input sources
look on remote for input or source button .
HDMI 1
Apr 18, 2016 | LG 42LC2D 42 in. LCD HDTV
How do I watch normal tv on my audiosonic television ?
That depends upon which source your "normal" TV is connected. If you have a cable box using a coax cable, then you will either select the DTV source if the cable box uses digital output or a digital over-the-air antenna, and ATV source if the box is using analog signals or if you are using an analog over-the-airwaves antenna. If you are using a cable box but have an HDMI cable connecting it to the set, then you need to choose HDMI1 or 2 as appropriate. If you have a box that uses the red-black-yellow RCA cables, then select the AV input. Remember that for ATV and DTV inputs from a cable box, you usually have to tune the set to either channel 3 or 4 and use the box to change the channels.
Jan 05, 2016 | Televison & Video
When I turn TV on it is always on atv and not dtv how do I set it to stay on dtv
If you have not already, try pressing the source button on the remote control and select the DTV option that you choose to use and this should then act as the default until you select an alternative.
Jul 20, 2014 | Toshiba 32AV500U 32 in. LCD HDTV
Does this model have a digital tuner or do I need to have a box to watch televison over the air?
Yes this tv dose have a digital tuner inside of it,all flats LCD and Plasma tvs are Digital tvs they all can get free DTV air broadcasting tv channels.All digital flats LCD and Plasma tvs are DTV set u just require a very good like a roof Antenna or a newly Digital design portable Antenna connected the tv incomming air broastcasting signal cable back of to the flats screen tvs at the axail input call ANT.Then go into the tv menu.Goto setup go down pick AIR than press the enter button for scanning for free DTV air broadcasting channels.After the tv finish scanning for channels than the tv will let ur tv to get all the free DTV broadcasting channels.
Sep 29, 2011 | Olevia LT32HVE 32 in. LCD Television
Could you please advise if our model Samsung TV. LE26R8 purchased in 2007 has the built in FREEVIEW tuner. Many thanks, Peter smart
Yes it does.
If you look on your remote there should be a dtv/atv button and a dtv menu button to tune it into dtv.
Oct 16, 2009 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Want to Know if my TV is a DTV
it most probably is DTV ready, try googeling some on the subject, but since its a LCD tv from 2006 its most likely to made with a digital tuner. Note : if you have cable or satelite ( dish networks, Direct Tv and so on ) you are allready watching digital TV and do not need a converter box.
Mar 05, 2009 | Sylvania 6620LCT 20 in. EDTV-Ready LCD...
Televison & Video Logo
44 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
