Question about Sanyo Xacti DSC-S1 / VPC-S1 Digital Camera
Lens stuck and displaying System Error"
For no obvious reason after using the camera fine & taking some pictures, switched off & the lens did not retract. Now when switched on, after a few seconds get an error displayed "System Error" and does nothing else. I can use in play mode to look at photos, but in camera mode the lens will not move. Have tried with brand new batteries, tried leaving off without batteries for a few days, but still the same. Help appreciated.
Same thing happened to mine - i read this and thought that I would have to chuck it and buy a new one. However, after the above poster suggested it could have been caused by a knock, I thought I'd at least try to solve it by another hard knock. I gave it a shake and banged it twice against the palm of my hand and, low and behold, it works again. I havent had the probelm since. Maybe the mechanism just got stuck and need the jolt to re-align itself?
Posted on Oct 09, 2007
    Genius:
  • 2,985 Answers
The Lens mechanism has become damaged some how a bit of grit a knock- whatever. There is no self ix option- with out running the risk of further damage. Go onto the Sanyo tech support team and see what they say A repair can be as costly as replacing the camera - be prepared for this
Posted on Jul 10, 2007
6ya staff
SOURCE:
L18 lens error
From Nikon site...
Why does my camera show "lens error" on the screen?
Having a "Lens error" message display on the camera's LCD display indicates a problem with the camera lens mechanism. This situation generally requires that the camera be sent to a Nikon Service Department for repair. Before doing this however, be sure to check these situations below:
One possible reason for this error is if the camera is switched on and the lens unit is prevented from extending. The camera will struggle for a second to extend the lens, then report the problem. Inspect the lens for any obvious obstruction, then turn the camera off, then on again. Usually, simply switching the camera Off then On again is enough to correct this problem.
Remove and recharge the battery. Retest.
If this does not help, then we regret the camera must be sent to our Nikon Service department as there are no user serviceable parts on Nikon Coolpix cameras.
Additionally, this link could helpfull: fixing-lens-error-on-digital-camera.html
Hope helps (remember to rate and commet this answer).
May 12, 2011 | Nikon COOLPIX L18 Digital Camera
Digimaster Happycam 5010 Problem: The shutter that protects the lens is stuck fully open. The camera is stuck with lens fully extended. ERROR 2 appears on the screen. The LED near the top left of the...
That is probably a lens error, or a problem with the main pcb inside the camera.
Only easy fix is checking if the problem disappears by removing batteries and putting them back.
Oct 12, 2008 | Cameras
Lens error
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the batteries. (obvious I know).
2. The camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
Apr 29, 2010 | Canon PowerShot A460 Digital Camera
After inserting lens it keeps saying lens not attached
I would help to know the error message, but here is what I can tell you.
Having a "Lens error " message display on the camera's LCD display indicates a problem with the camera lens mechanism. This situation generally requires that the camera be sent to a Nikon Service Department for repair. Before doing this however, be sure to check these situations below:
  1. One possible reason for this error is if the camera is switched on and the lens unit is prevented from extending. The camera will struggle for a second to extend the lens, then report the problem. Inspect the lens for any obvious obstruction, then turn the camera off, then on again. Usually, simply switching the camera Off then On again is enough to correct this problem.
  2. Remove and recharge and/or replace the battery. If the error does not clear up right away, leave the battery out of the camera overnight, and try again the next day.
Oct 31, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
My digital Sony camera fell down Lens got stuck
    As in short answer you have to replace the optical lens assymbly.Because due to heavy jurk its motor called sledge motor stsrt malfunctioning and it can not be changed component level. For this please contact any SONY SERVICE CENTRE nearby to you.
Hope you will understand.
Thanks for using FIXYA!
Apr 28, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
My camera is taking black pictures
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Apr 16, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Fuji Zoom Error Message
Hello
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Jan 13, 2009 | Fuji Finepix J50 Digital Camera
Lens is stuck open says lens error nikon coolpix l6
when the camera is turned on it displays "lens error". I can't take a picture and i can't access my pictures on the camera.
Apr 29, 2008 | Nikon COOLPIX L18 Digital Camera
Lens error
This is the lens focus gears. They are either knocked out of alignment, or debris has jammed them. The good news is it can be fixed....Casio most likely won't help. Hint...google my user name.
Dec 24, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Lens is stuck out
push up on the inner lens housing,
Dec 24, 2006 | Kodak EasyShare LS753 Digital Camera
Sanyo Xacti DSC-S1 / VPC-S1 Digital Camera Logo
148 people viewed this question
Top Sanyo Cameras Experts
teddyboy
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
