Question about Home
Are tin openers the same thing as can openers?
    Problem Solver:
  • 22 Answers
The term can opeber is used in North America and in Australia, while the term tin opener is used in Britain.
Posted on Jan 14, 2013
Door Will Not Open
G,day mate mine was like that i used a tin opener that sorted the mother out cobb
May 11, 2013 | Cars & Trucks
The instructions are missing from the Green Science Tin Can robot kit we just purchased. Can you send a pdf of them?
go to www.4m-ind.com then click on instructions, then enter tin can robot in product search. then open the PDF.
Aug 10, 2011 | Toysmith Green Science Tin Can Robot Kit
My Xbox froze then it displayed three red ring around the green power indicator.
ur EX-box to be could be really broken or an easy fix try turning on ur xbox with two q-tips in the holes were the fan is and stopp both fans untill u overheat ur xbox till the three lights turn to 2 light on the left had side the wait 1 min if that the unplugg and let it cool down to room temp the boot it bak up
if that dont work try opening ur xbox and take off the two metal heatsinks inside and use some isophyrol (bad spellin ) clean all that gunk off untill its like a mirror then buy some artic silver thermal paste stuff and put a grain of rice sive squirt on it and spead it over the mirror parts of chips under heatsink put it all back together try again boot it still.... nothing...try removing xclamp and replacing them with bolts
okay try this try takin every single thing off the board dvd , fans, heatsinks ,hardrive just so ur left with ur board now go preheat oven to 230 uk 475 usa and now get some tin foil and cover all the capacitators with the tin foil ther the black lookin battery things and cover any plastic parts aswell now put on bakin tray FLAT and cook for 10 mins this is in my opinion lat hope
Nov 26, 2010 | Microsoft Xbox 360 Console
DeLonghi Alfredo Healthy Grill Manual
Is something needed to go on bottom when take grill off there is a round thing attached but also have an oval tin black thing with holes in and clips at side what is this ?
Sep 08, 2010 | Vacuums
Oven door will not remain fully closed
Noiselab is not correct for all cases. As Buzz says, if the springs are strong then the foil fix works and works really well. Refer to attached photo for guidance in conjunction with instructions below. Note my possibly simpler answer at bottom.
I cut some short narrow strips (about 4mm x 20 mm) from a tin can and folded them over into a flattened "U". You can back off the large Phillips head screw on the frame of the oven where the door hinges are inserted and sit the tin over the little plate that is held by these screws and then tighten so that one end of the "U" sits between the oven chassis and the adjustment plate. If it still doesn't quite close add more tin as required. Refer photo for terminology.
Now the simpler solution which I didn't try but which would probably work after I contemplated the problem in retrospect is this. The reason I didn't think of this was that I thought the hinge went into a tube or slot. Later I realised it is just a simple cantilever design which is why the tin foil solution works (ie lifting the middle support of the cantilever produces a corresponding closure of the door). When I inspected the large Phillips head screws to insert the tin foil these were completely loose. Try this first then. Slide the adjustment plate up as high as the tolerance of the Phillips screw allows and then tighten it off hard. This will raise the bottom edge of the plate just as the tin foil method does. If not enough then proceed to the tin foil method.
Jul 09, 2010 | AGA ILVE M-90F-MP Dual Fuel Range
Water running slow out of fridge
i had that problem
so when we called the repair guy
he went in back uncloged some hose part that pulled out,also he cleaned dust inbetween the tin plates under the front bottom ,sort of look like the tin things around a pipe in oil baseboard heating systems
Jul 19, 2009 | Refrigerators
How do I remove tin foil baked on brand new oven?
Unfortunately you can't remove that foil, you will end up doing more damage to the liner. the only thing you can do is replace the liner. And it's a big job, if the manufacture makes a replacment part for your unit, and if they do it will be costly.
Good luck....
Jan 09, 2009 | Kitchen Ranges
Tin foil stuck to bottom of new ge monogram oven
I had the same thing just occur. GE is now telling me the only fix is to buy a new range. Great. $10K for a range that I use once.
Jan 04, 2009 | GE Monogram ZDP48L4GHSS Dual Fuel...
Yes, we were a couple of dummys when we received our brand new LG stove, with convection oven,glass top and very fancy, and we put tin foil to cover the bottom of the stove and of course yesterday when I...
I really don't know what to tell you. During the clean cycyle the metal probably melted and is permantly sealed to the bottom. You are lucky the oven still works. Sometimes using foil will destroy sensors or other things. NEVER use foil in ANY oven!!!!! The only exception is to partially cover the shelf underneath something you know is going to make a mess. Even then don't cover more than about 60% of the rack.(Never do this in a convection oven as the fan will blow the foil ) Also NEVER!!! allow foil to come in contact with a hot burner. It will melt to the smooth top or coil.
Jul 07, 2008 | LG Kitchen Ranges
How do you open the duoglider
you open it with your tin opener and some sprouts
Apr 30, 2008 | Graco DuoGlider 7924 Twin Seat Stroller
Home Logo
507 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
