Question about Exercise & Fitness
I have a sears proform 585 treadmill.
I have lost my manual. Is there any lubrication required? Does the belt require any lubrication?
  • rich63edie Jan 23, 2009
    Need to know what the manual says.
  • Anonymous Mar 30, 2014
    How do I know which type of lubricant to use for the treadmill belt?
My treadmill proform 585QS has a belt that keeps sliding
Posted on Apr 11, 2010
    Brigadier General:
  • 5,158 Answers
If it is a plastic belt do not put any oil near it as that degrades it
Posted on Jan 23, 2009
Healthstream GS1165T treadmill, where do I have to lubricate it, i have lost the manual
see the video and proceed according. lube the rollers bearing front+back +drive belt motor test , and replace the belt if necessary.\\God bles you
Jul 05, 2013 | Exercise & Fitness
I have problemwith my PROform 585 treadmill and recently it is stop working ,as soon as I put the machine on it makes 3 bbeps noise and its stays like that for ever ,could not get it start it at all a
1) lUBE THE deck belt vs deck, this produce shut down for to protect the treadmill in your electronic system
2) lUBE The rollers bearing very well.
3) Measure the input voltage motor , if there are voltage, the motor need repair.
4)Measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the diagram attached.
Jun 14, 2012 | Proform 585 CS Treadmill
Need a manual for a proform 585 cs
Dear Sir:
Please go the nexts web:
www.fitness.manualsonline.com y/o www. proform.com
give you model, and download for free inmediately.
sincerely. God bless you.
erensto cuadra
managua, nicaragua.
Feb 15, 2012 | Proform 585 CS Treadmill
Need lubrication for proform 785 belt
Some ProForm treadmills require lubrication every six months or so, depending on the usage amount. Lift the walking belt and feel on the underside of the belt. If it is dry, you should lubricate it. ProForm recommends you use 100-percent, non-petroleum silicone spray to lubricate the walking belt. Do not use wax or other lubricants, such as WD-40 or a Teflon-based spray
Aug 24, 2011 | Proform 785 Treadmill
My proform crosswalk 590 circuit breaker keep turn off after run for five mins
Have you lubricated the walking belt & deck?? Are the deck and/or belt worn out and require replacing??
Check the deck for damage and wear, check the belt (feel the outer edge and then the center. Is the center fuzzy??)
If the deck and belt are good, lubricate them and try again.
Is the belt to tight??
Are you using an extension cord??
The machine is drawing too much current, usually deck & belt or defective motor will cause your breaker to go..
Dec 14, 2010 | Proform Exercise & Fitness
My treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in2_bing.gif and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
May 08, 2010 | Proform Crosswalk 500 Treadmill
The walking belt on my Proform 620 weight loss treadmill is very slick, almost dangerous
You can usually find the screws to tighten the belt at the back of the machine - but be careful not to tighten too much. A quarter turn may be all that is needed. A gentle tug will get the belt back into alignment if it is askew. Remember that if you have trouble tightening or realigning the belt, you should seek advice from the manufacturer or the fitness store where you bought your treadmill exercise equipment.
Most new treadmill machines do not require belt lubrication, and therefore you should only lubricate your belt if the manufacturer specifically recommends it. Most of the manufacturers who do recommend regular lubrication sell kits with instructions and all the equipment you need to make quick work of the task.
Post further comments for more help or information.....
Good Luck!!
Thanks
Dec 04, 2009 | Proform XP Weight Loss 620 Treadmill
Pro form service manual?
Please type in your model number on this page to get the free downloadable manual:
http://www.iconservice.com/proform/manuals.html
Hope this is helpful
Sep 11, 2009 | Proform Sport 1000 Folding Treadmill...
Treadmil stops or slows down upon walking.
Check both belts to be sure they are adjusted and not slipping.Check the underside of the walk belt to see if it feels frayed in the center as compared to the edges, the center always wears more than the edges a really worn belt must be replaced. if it is nor worn there is a wax lubricant for proform treadmills that can be purchased at retail stores that sell treadmills.Sears, dicks sporting goods and also treadmilldoctor.com are good places to buy it.
Jul 30, 2009 | Proform CrossTrainer Treadmill
Exercise & Fitness Logo
1,907 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
