Question about Dell Dimension 8400 PC Desktop
Unable to re-install Canon MP600 printer after hard-drive re-format
I just had my pc's hard-drive re-formatted after a crash and was assured all necessary drivers were downloaded from Dell's support website, but am unable to re-install either my Canon MP600 multi-function printer or the Dell 720 printer that came with the pc. Apparently, my pc is unable to locate either device no matter what USB port I use and thus will not download the printer's driver either from each printer's cd or the Canon and Dell websites. Is it possible then that my pc is missing the USB driver, and if so, does anyone know which download on the Dell website is the correct one (there appears to be over 70 drivers and downloads)? I called Dell tech support, but they weren't overly helpful, probably because I have an expired warranty. Any help and advice would be greatly appreciated. Thanks to all!
The drivers can be found on http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PRN_INKJET_720&os=WW1&osl=en&catid=&impid= or else try http://tinyurl.com/2r3g7t ,this should help u installing the drivers
Posted on Jul 13, 2007
    Scholar:
  • 36 Answers
If the drivers are unavailable from the manufacturer check http://driverguide.com for downloads. Usually you can find drivers there that are no longer available from the mfg. If you have a backup of the files you can install the drivers manually from the following locations. Click on the unknown device, or click update driver and point the search to the following locations from your backup. windows\inf windows\options\cabs windows\system32\drivers If you took your computer to a local shop I would check to make sure the idiots didn't disconnect your usb ports if they are not integrated into the board. Hack
Posted on Jul 09, 2007
SOURCE:
How to format canon ir 2870 hard disc
The copier might have it's own facility for formatting the hard drive but the best way to format any drive is to remove it and fit it as a slave drive to a desktop or laptop PC and use the computer to format the drive with the requirement that if the software it contains in 64 bit the PC will also need to be running 64 bit software.
Sep 17, 2016 | Canon IR2870 COPIER FOR 220 VOLTS ONLY
External drive crashed
Formatting the drive, depending upon the type of format, is destructive of data. There are specialized recovery programs that can sometimes save the old FAT tables, but chances are you are out of luck. Many times these external drives fail because they are not built to handle the heat and shock/vibration that comes with being encased and mobile. Often it is not the drive itself that fails, rather the SATA/USB controller in the enclosure. I have seen many individuals pull their "failed" drives out of the enclosure, install it internally, and find all the data is still there.
Jan 11, 2015 | Hitachi Computers & Internet
I am unable to re-instal canon pixma mp600 on my windows 7 it suddenly stopped working it now has fout RPC unable to connect when I try to re-instal the disc says that it is not compatable for windows 7
You can download "Drivers & Software" for Win7 (32bit & 64Bit) @ http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#DriversAndSoftware
Select your OS ie Win7(32bit) or Win7(64bit).
Disconnect the printer from the PC, and delete the printer you have installed & remove all the software previously installed on the PC. Reinstall the download "Drivers & Software".
Hope it helps.
Hope it helps.
Jul 14, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Cannot copy items to flash drive because not enough space but flash drive has been emptied of all contents
Have you formatted the flash drive?
Go to My Computer and right click the flash drive (make sure you select the correct drive, as all data will be deleted)
Choose Format and that will completely remove all data.
Mar 30, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Display hardware or drive broken
format your laptops's harddrive and install the operating system. When computer crashes very often, it is better to format it and install the operating system. Don't opt for quick format. This will help you to detect bad sectors. If there is bad sector, you have to replace the hard disk.
Jan 30, 2009 | Acer Aspire 5920-6727 Notebook
Hello i have installed AVG anti virus n it makes my pc system crash!!!!!!! Just i tried to format my pc but failed it says missing operating system and no longer boot. I assured my BIOS and set Boot CD but...
It sounds like your pc is trying to boot from the formatted hard drive. Go into your BIOS and make sure both the hard drive and CD drive are detected. Make sure your CD drive is set as the first boot drive and disable all other drives for booting.
Nov 30, 2008 | Computers & Internet
Bad disk
agri-man
low-lable format can solve ur problem.
at first create windows98 startup disk from any win98 pc or use windows98 bootable cd. and download disk manage 9.54 for samsung hard disk. and copy it in a cd. then boot ur pc with windows98 bootable disc or startup disk. then inseart disk manager cd go to cd rom drive give "dm" commnad. run low lable format form advance --->utility ----->maintanance------> low lable format. after complete low lable format (it can take saveral time) then creat partition and format each partion.
Jun 25, 2008 | Samsung (SP0411N) 40 GB Hard Drive
MP600 Canner quit working
It sounds like a folder on your hard drive got renamed or moved/deleted. Open your Applications folder and look for a folder named Canon Utilities. Open the MP Navigator 3.0 file. Click on the Preferences button in the lower right corner. Click on the "Color Button" (or "Black Button") tab, and select the "Save to PC" option for "Event:". Verify that the folder indicated next to "Save in:" exists (this is the 'path specified' that the advisory message is referring to). If not, change it to a location that exists on your computer.
Jun 18, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Hard drive installation
You need to format the drive first before you can use it. If you are using windows xp, right click on the drive E and then click on Format. You can put a check mark on the box next to quick format if you like it faster and then click on start.
Please leave me a comment after you did what I said.
Feb 23, 2008 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Dell Dimension 8400 PC Desktop Logo
101 people viewed this question
Ekse
Clive
Clive
