Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
How do I calibrate the printhead
Just installed the new printhead and ink cartridges now I need to calibrate the printhead.
    Sergeant:
  • Kodak Expert
  • 285 Answers
You should et a message, if you dont push menu and look for printhead alignment or something like that
Posted on Jan 28, 2009
5 Suggested Answers
otacon
  • 1944 Answers
SOURCE: black is not printing
When you did a clean did you choose the highest level of clean? Does this problem also occur when you print only black documents...such as text only word documents? Also, the new cartridge that you used...is it original and also has it passed it's expiry date?
Posted on Jan 14, 2008
  • 119 Answers
SOURCE: I have clean the printheads calibrated printer and
http://www.kodak.com/go/itg
Given your situation, you will follow the troubleshooting through the steps and it will provide instructions on what you need to do to get a replacement printhead for your light prints.
Posted on Jul 14, 2009
  • 295 Answers
SOURCE: Just installed new printhead and new black and
When you install new printhead in the printer, you will get a message" New printhead detected ,load papers in paper tray and press start. If u do not get this message,that means you have not installed printhead properly. Visit www.kodak.com/go/printheadsupport and click on 3 rd link installing or replacing a printhead to see how to install printhead correctly
Posted on Dec 03, 2009
Testimonial: "Thank you for speedy reply. I will try your solution.RAU"
  • 22 Answers
SOURCE: Tells me ink needs replaced even after putting in new ink.
check your new ink catridge and look for a mini green electronic chip if that is damaged the printer shouldn`t recognize the catridge
Posted on May 16, 2010
How to remove the ink cartilidge
How do I install a new printhead in my all-in-one printer? To replace the printhead in your all-in-one printer:
  1. Make sure the printer is on.
  2. Lift the printer access door and wait for the carriage to move to the access position.
    NOTE: For ESP 3250 and ESP 5250 all-in-one printers:
    • On the printer control panel, press Home.
    • Select Maintenance, then press OK.
    • Select Install Ink Cartridges, then press OK.
      If "Install Ink Cartridges" is not an available selection, upgrade the firmware.
  3. Remove any paper that may be loaded in the printer.
  4. Remove the black and color ink cartridges and set them aside.
  5. Remove the existing printhead:
    • For ESP Series Printers, unlatch the printhead by lifting the latch in the center of the carriage.
    • For 5000 Series Printers, unlatch the printhead by pressing the button in the upper-left corner of the carriage.
  6. Lift the printhead out of the carriage.
  7. Remove the new printhead from its bag.
    CAUTION: Do not touch the copper contacts on the printhead, as this may damage it.
  8. Remove the plastic protective shields.
  9. Place the new printhead into the carriage.
  10. Push firmly against the target label of the printhead until you hear a loud snap.
  11. Insert the color ink cartridge into the printhead and press down until you hear it click into place.
  12. Insert the black ink cartridge into the printhead and press down until you hear it click into place.
  13. Close the printer access door.
    The printer detects the new printhead. Follow the instructions on the LCD to calibrate your printer.
    NOTE: ESP 3 all-in-one printers do not require calibration.
IMPORTANT: Be sure to use KODAK Ink Cartridges. Your KODAK All-in-One Printer is designed to work with KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of either non-Kodak brand ink cartridges or refilled ink cartridges. You can purchase KODAK Ink Cartridges from the KODAK Store.
Feb 09, 2011 | Kodak ESP5 AllInOne InkJet Printer
May 16, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Just installed new printhead and new black and colored ink cartridges. I do not have a calibration calibration sheet any longer. This is for Kodak easyshare 5300 printer.RAU
Dec 03, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How do i remove old printhead and install new one
Replacing the printhead If your printhead is damaged or broken, you may replace it yourself.
  1. Make sure your printer is turned on.
  2. Open the printer access door by lifting from the recessed hand-holds on the sides of the unit. autourg00977009id2130369.jpg
    The printhead moves to an accessible position for handling the ink cartridges. The ink cartridges are seated in the printhead.
  3. Pinch the latch on the ink cartridge with your thumb and forefinger and lift it out of the print head. Remove both ink cartridges.
    caution.gif CAUTION:
    Insert the ink cartridges into the newly installed printhead as soon as possible to prevent any drying of the ink.
  4. Unlatch the printhead by lifting the rectangular latch on the top of the printhead.
  5. Remove the old printhead from the carriage .
  6. Remove the new printhead from its bag.
    Do not touch copper contacts on the printhead, as this may damage it.
  7. Remove and discard the black plastic casing and the orange protective cap.
  8. Place the new printhead into the carriage.
  9. Push firmly against the target label on the printhead until you hear it click into place.
  10. Re install the ink cartridges. As needed, see Replacing ink cartridges.
  11. Close the printer access door. The printer should now complete a printhead calibration to ensure that it is ready to for normal operation.
Nov 23, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
An E appears on the small screen
I found something in the manuals A flashing "E" means that the printhead is not installed or not installed correctly.
The solution for the problem is:
Remove any ink cartridges that may be installed. Remove the printhead and then re-install the printhead. Re-install the ink cartridges and close the lid. A new calibration sheet will print.
Oct 10, 2009 | Office Equipment & Supplies
Kodak 5300 shows "color ink cartridge needs replacing",even with new cartridge,and new printhead..Ink level display shows color cartridge empty,and its brand new..
Try this one
Take out the inks and printhead
Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
Close the cartridge door once the cord is unplugged
Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
Thanks Josh - Kodak Tech Support
Sep 23, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5500 will not print with black ink
Here are the things you will be asked to try if you call support. They may fix the problems as well. Taking the printhead out and putting it back in is the big helper.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
(If this is a 5100, do it in the home center ->? in the top right ->Maintainence ->Clean Printhead.)
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Aug 17, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer won't print
Close the printer.
Jul 10, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
5300 kodak eazyshare printer
Well, here is the proper way of fixing or troubleshooting that paper jam error in your printer
Open the printer access door and remove both of the ink cartridge, then remove also the printhead, after that close the printer access door, without those parts. Then it will show a message in the printer screen, "Printhead is missing or has come loose" or "Printhead Not Detected" Install the printhead, just the printhead without the ink cartridges. After that close the printer access door. Then it will show you a message"Ink cartridges is not installed,install ink cartridges". then open again the printer access door, then install the black ink cartridge without the color ink cartridge. then close the printer access door, then message must be " Color ink cartridge is not installed, install color ink cartridge" then install the color ink cartridge." the message must be,"New printhead is detected calibration require, load paper and press start"
Thats the way of overiding the paper jam error message of your kodak all in one printer
hope this will help you guys
by: E.brown
Happy Printing(", )
Kodak AIO tech support 1-800-421-6699
Jun 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Prnter kodak easyshare 5100
just to check, is what specific lights is blinking is it the check color or just check black inks??
-to make sure w/ this one is it blinking too fast or slow and what is the color?? check if the on and off is also blinking
-check black ink and check color cartridges blinking fast means no printhead installed
-check black ink and check color cartridges blinking slow, no cartridges installed
-check black ink and check color cartridges blinking w/ on and off ready to calibrate
(in ready to calibrate if doing nothing, just press cancel and
-press photo and cancel on printer, if not doing anything
-remove printhead( the one that holds the cartridges) turn printer on and off, put printhead back to printer w/ cartridges, and check the lights that is blinking
-press photo and cancel again
-if not doing anything, contact manufacturer
-goodluck
Mar 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
61 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
