Gear4music pm-12 ha instruction manual - Audio Players & Recorders
Date shows AM, should be PM. How to change, nothing in manual ?
You mean time is only coming in AM. The clocks are usually 12-Hour display. So it should automatically turn to PM once you go past 12 hours. I am assuming you have the manual and you are correct it does not show separate setup for AM or PM. You simply keep increasing the hour until it passes 12:00 and it should go to 1pm. Similarly once you go past 00 hours (midnight) it will switch to AM.
Hope this helps.
Manual for reference (won't help you if you already have it)
http://www.acurite.com/media/manuals/02010_02014_02015-instructions.pdf
Apr 28, 2014 | Acu-Rite Measuring Tools & Sensors
Westek Indoor 1 Outlet Digital Timer TEO2DHB instructions
Question is unclear:
Do you want instruction manual, or want somebody to read the instruction manual and explain it?
1) Open following link for instruction manual:
http://waterheatertimer.org/pdf/TE02DHB-manual.pdf
2) For explanation of instructions:
-add a comment and ask specific question saying what part of instruction is confusing. For example 12 hour or 24 hour format is letting you choose 12 hour am-pm format or 24-hour 'military time' format where hours of the day and night are numbered 1 through 24.
-and you can also take advantage of fixya live support, and expert can speak with you over phone while you program timer.
Sep 25, 2011 | Hardware & Accessories
The link on FixYa to the HB65R Intermatic timer Manual seems to be broken. Do you still have it?
Fixya does not have HB65 manual posted.
Open following link to identify timer and download manual in English.
If this is not your timer, add a comment with clear description of timer, or in-focus photo of timer posted on flicker, so I can locate possible manual.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#HB65R
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
Jul 19, 2011 | Garden
The watch has an alarm that goes off at 10:17 pm, 12:00 am, 12:05 am, 12:10 am, 12:15 am, 12:20 am, 12:25 am, and 12:30 am. It wakes up the entire house. I don't know how to turn this alarm feature off. It...
Go to the casio web site "www.casio.com/support"
select "manuals"
Select "watches"
Select "watch manuals archives"
Enter details of you watch and download instructions.
Jan 06, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Sir i write a cd i get this error somu 4C85-1000-0805-6481-407K-8KE9-**** Windows XP 6.0 IA32 WinAspi: - NT-SPTI used Nero Version: 7.10.1.0 Internal Version: 7, 10, 1, 0 (Nero Express) Recorder: ...
turn off buffer underrun protect in neros settings. It gives back the wrong info to nero causing it to crash. Contact nero about the issue. there may be a patch on the nero site to fix it.
Aug 30, 2009 | Acer Aspire 4720 Notebook
Sharp Actius AL27 strange DVD burning problem - The drive will burn a DVD+RW at 4x. A cheap (Imation) DVD+R burns OK, but a good 16X DVD+R (Verbatim) tries to burn at 2x and fails a few minutes in. This...
man it's not a condition that if the DVD Bulck writeen on it 16X that ur DVD writer will burn on this speed.
always don't try to burn ur DVD on maximum, always use the previous speed or the last previous one
ok good luck
Jun 17, 2009 | Sharp Actius AL27 Notebook
Burn fail or cd skip
Kind of sounds that way. They are pretty inexpensive now days, and simple to install.
Good luck
Mar 17, 2009 | Gateway M680X PC Notebook
Intermatic hb65r residual outdoor timer
Here is the instruction manual for your model:
HB65R Timer
Hope this helps!
Also consult this website for sunrise, sunset information for your area:
Sunrise sunset calendar
Dec 05, 2008 | Hardware & Accessories
Burn error
You unit is faulty.. replace the unit with a new one. The CD Write Laser has probably "Burnt Out" or perhaps the "Quadrant Detector" has faulted.. either way a new unit is only way solve ya problem ... sry :(
Sep 03, 2007 | HP Media Center m7250n (ED842AA) PC...
YAMAHA CRW8424 gives Track following error..
PROBLEM DEFINITION: Basically, it is a hardware error that occurs when a drive is not capable of following a data track on a CD-R or CDRW or on the other hand, poor power flow may cause the problem SOLUTION: 1. Try use another disc, a disc with a different band. 2. If one doesn't work, you may have to open your system and use a different power connector, making sure no other devices are using the power connector in the same strand. 3. Lastly, if neither the above doesn't work, you may have to send your drive in for servicing as the head may be dirty or misaligned.
Aug 05, 2007 | Yamaha CRW 8424 Burner
63 people viewed this question
 Grubhead
Grubhead
