Question about Whirlpool Duet GHW9150P Front Load Washer
Something in washer drum
There is something in the drum of my front load washer, we can't access it through the rubber in the front. How should we get this out?
  • 54 Answers
The casing around your drum is locked in place.(got to take machine and casing to get to drum) if something is in there depending on the size it will make its way down the drain filter area.. to get to the filter.. you open the front bottom plate..(3 or 2 screws) you will need a few towels before you twist open the filter cap.. help that will work .. good luck . mike
Posted on Jan 23, 2009
How do I remove and refit the door seal? I'm managed to remove the clip at the front but something I cannot see is attaching the rubber seal at the back.
There is another retaining band , clip, or spring holding the seal to the front of the drum, you need to remove this to remove the sea,double the seal back inside the drum to expose the retainer.
Aug 20, 2010 | Zanussi F1045W Front Load Washer
Drum stopped turning mid cycle, think something is stuck, have opened up backbut cant access drum
If there is no removeable cover on washer, then you have to remove therear half of the cabinet to gain access to the drum etc.
Jan 17, 2010 | Zanussi ZWF1430W Front Load Washer
Rubbing noise on front load washer drum
dont they have 4 shocks?
the drum is imbalanced i would wager
Aug 18, 2009 | Frigidaire ATF6000ES Front Load Washer
Motor has load poping noise on front end load washer
If it is a front loader, reach just inside in the drum. Pull the rubber boot up and fell to see if something has gotten between the drum and the rubber boot, maybe a lighter.
Aug 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drum on LG front load washer does not turn.
something is caught in between the two tubs.and that is no fun! call the there is no belt on most lgs.
Aug 07, 2009 | LG Washing Machines
Smell in Front Loading GE Washer GCVH6260F
more likely due to using liquid detergent - change to powder
Dec 01, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Front Loader rubber boot completely out of shape
You can replace the rubber door seal yourself if you are logically minded and are handy with tools. Isolate the washer from the mains supply. Remove the top fixing screws at the back of the washer. Slide the top of the washer to the rear of the washer and remove. Now you will be able to see the outer drum and the securing band to the drum. This needs loosening and moving clear of the outer drum so you can disconnect the seal from the drum. When you open the door, you will find see that the door seal connects to the washer outer body. You should see a holding catch probably made of plastic. This has to be removed and take care not to break anything. When re fitting the seal,you will find on the front inner edge a small hole, this must be in the 6 o'clock position. Working from the door access, feed the new seal on the outer drum and secure it with the retaining band that you removed earlier, at this stage do not fully tighten as you may need to readjust the seal later on. Now working at the door, feed on the door seal and position the small hole at 6 o'clock. If you find that the seal is twisting, then you will have to readjust the the seal on the inner outer drum. When everything is lined up, tighten the inner securing band then the outer retaining band by the door. Recheck that the small hole on the door inner lip is at 6 o'clock and both the door an outer drum securing bands are tight. This done, check for leaks by part filling the washer and then putting the washer on an emptying cycle. If all is well, then isolate the power to the washer and refit the the top of the washer and secure with the screws you removed earlier. On no account put your hands or tools inside the washer when it is on and connected to the power supply.
I have not yet replaced a door seal on your model of washer, but I have done quite a few and the process is the same. I hope you can follow these instructions and if you come across a snag, think about it and i am sure you will find the solution. You can always get to me at FixYa.
Oct 27, 2008 | GE Energy Star WCVH6260F Front Load Washer
Scratching noise
the only way you can do it is to fish under the rubber flap in front.
other wise you have to remove the top access panel, bottom access panel , remove the panel control
then the front door and panel
now you have access.
it really isn't that hard. just sounds difficult.
May 05, 2008 | GE WBVH6240F Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
156 people viewed this question
Dan Webster
Dan Webster
Sal De
