Magnavox flat tv screen model 22 me 402 v1f7 closed cap help
Cant get sound an closed cap to stay on any channel thru charter cable
  • 1,238 Answers
Go to menu and find the close caption setting then OFF.
Posted on Jan 14, 2013
  • 13 Answers
SOURCE: 32 in Magnavox tv model 32MF231D/37
An earlier post of the smaller model of this with the same problem said to remove the metal cover over the power supply.
I have the 26MF231D and it worked great afterward (even though you can't mount it)
Here is how you remove the cover.
http://www.flickr.com/photos/88002248@N00/sets/72157611665895426/
Posted on Dec 26, 2008
SOURCE: Charter MOXI Remote doesn't work with Sony Bravia 42'' Flat Screen
Hold down the moxi and ok button until the remote flashes twice,then enter 9910. The remote will then blink twice again.Then go back and fourth pressing the mute button and the up arrow key(the one above the ok button)this will go thru all the codes,when your tv finally mutes,press ok that means you found the correct code.Hope this helps
Posted on Apr 12, 2009
  • 92 Answers
SOURCE: olivia 42'' flat screen and cant get any cabel channels
make sure that you're not using a cable box. then when you do the channel scan, make sure that you pick cable instead of antena.
Posted on Jun 18, 2009
  • 304 Answers
SOURCE: Samsung LCD tv no sound from one channel only, no
First try viewing regular programming and see if you have audio on both channels. If you do not then go to the user menu and make sure that the chim function is turned "on". Then turn off the tv and listen for the down chime coming from both speakers. If you only hear the chime from one speaker then the Aidio circuits are bad on the Main bd and needs to be replaced.
Posted on Jul 16, 2009
  • 8 Answers
SOURCE: magnavox 37" flat screen model no.37mf23id/37
Yes, he means 2200 microfarret (called uf from here on out). Another important concern when buying a replacement is the voltage. You need to get something that is at least 25v. I recommend a 35v or better. Another notable point is that this may not always fix the problem. As with mine, there was also a 1200uf (microfarret) 35v capacitor that was blown. You can tell this because they bulge at the top. I have both of these caps (2200uf 35v and 1200uf 35v) on order and they will be here tomorrow. If I do not post back here then they fixed the issue for me. I suspect that this will resolve the problem. Look for bulges on top of the caps. This is an indication that they are blown. Most all of you experiancing these symptoms will see the 2200uf cap bulging but you may also see others bulging too. If you do then you need to replace those too. No electrolitic capacitor should be bulging at the top so if its bulging its bad, and if its bad then your tv will definitely not work. Have fun.
Posted on Oct 13, 2009
Magnavox Remote Codes
0054,0059,0052. Try these codes. For more information http://electrohelponline.blogspot.com/
Nov 20, 2013 | Televison & Video
Can't get rid of "Please Run Channel Auto Scan" stays on tv screen
for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
Aug 05, 2012 | Dynex DX-LCD32-09 LCD TV
Picture but no sound magnavox HD tv
check to see in audio menu for set and sat or cable box if SAP is engaged as this will (Spanish) cause no sound on certain channels.
The problem or setting exists in the set and most boxes providing signal to the set.
Mar 12, 2012 | Magnavox Televison & Video
Dvd/vcr recorder magnavox model mwr20v6, i got probelm hooking up my dvd/vcr recorder to my cable converterbox an tv , because i broke the antenne/ out socket on the back of the unit, how can i get it to...
Hi,If I understood correctly you broke antenna out socket of Cable box..ok no problem,your TV and cable box should have other jacs/socket for this connection as well..
Take the A/V output of your cable box into TV possibly with RCA cables..than you can select the channel thru Cable box on TV ..(AV mode needs to be selected on TV )
** in order to listen and watch your
magnavox DVD 's "2xRCA audio" and "1x RCA Video" cables "OUT" should go to Tv or Cable box "IN" connections separately ..("IN" goes to "OUT" of other ..pls remember,Always reverse connected ) (audio will come thru Receiver and TV.)
Since you successfully connected your Receiver to play video on TV (one way only ) ,here is the second reverse action if you wish to listen or RECORD a program on your TV on
magnavox
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV or Cable box .( every TV -cable box has different type of Audio out jacks )
** to "iRCA nput or "Optic Cable input"
of your
magnavox (whichever you want ,based on the necessary cables on your hand )
There you go..Tv/Cable box video and sound are both on the
magnavox for recording..
Hope this helps!..if more help requires pls let me know.
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 15, 2011 | Televison & Video
We have just recently repositioned our Philips Model No. 42PFL7422D/37 Flat Screen TV and thought we had written down the proper wiring set up for connecting to Charter Communications etc. Is there any...
CHARTER BOX
3 CABLES
YELLOW - VIDEO
RED - R. AUDIO CHANNEL
WHITE - LEFT AUDIO CHANNEL
Hook them up to tv's INPUT of the same colors
Then turn tv to input or av channel.
Mar 31, 2010 | Philips 32PF7421D 32 in. LCD HDTV
Silver Charter Communications Remote Control
1174,0062,0004,0009,0183,1133,0226,0288,0456,0008,0068,0075,0141
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 28, 2009 | Philips PM3S Remote Control
Mar 26, 2009 | Sony Televison & Video
TV will not stay in Stretch Mode
I know of no solution for this, it is the normal operating mode of the system.
Jun 28, 2017 | Philips Magnavox 51MP392H Rear Projection...
No Cable Picture
Call the cable co. If your getting the cable setup screen from the tv...Its getting that signal from the box...The tv is fine.
Sep 14, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Closed caption on, but not working
do you have a cable box? is it a motarola box? is it HD box?
if the answer is yes to all of the above then leave the TV on and shut the power off on the cable box on the front of the box. then hit menu on the front of the box, an intrenal menu will come up. using the curser buttons (up/down) scroll to where it says "close caption : disable" use the curser buttons (left/ right) to highlight the disable the use the up/down curser to the "Enable" position now hit menu again then power to turn it back on.
you see close caption is not encoded thru Y, Pb, Pr cables nor is it thru HDMI and no set has decoding for closed caption thru this connection. so it has to be done thru the box.
Jan 21, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
