Question about Bon-Aire WH160C 12V Air Compressor
Bon-Aire WH160C 12V Air Compressor manual
Made apop noise now does't pumpas much air.
How big is the oil tank.
There is no oil tank. The oil is in the crankcase of the compressor
Apr 10, 2013 | Bel Aire Compressors Bel Aire 5 Hp Air...
Will not regulate humidity correctly. I set it at 60% and it is still running when the humidity in room reads 45%. I have confirmed this with a separate humidity gauge.
It may just be the fan running and not the compressor. Some unit's are designed that way, so that air is constantly moving and when the humidity level rises above what you have it set on, the compressor will automatically turn ON and remove that moisture. Wants it's back to where you have its set, the compressor will turn OFF. Check your Owner's Manual to see if your model has that feature.
Hope this helped you and thanks for choosing FixYa.
Aug 06, 2011 | Comfort-Aire BHD-501 Dehumidifier
I have a Comfort aire RAD 101-5 window AC. It works fine until it gets really hot outside and then sounds like it's bogging down and the compressor shuts off.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 14, 2011 | Heating & Cooling
My dehumidifier model BHD-501-D is icing up. The fan and compressor are running, do I need a new thermostat?
You may, but more than likely, the air intake filer needs to be cleaned and the compressor coils wiped down and cleaned. After cleaning the coils, a light coat of WD40 helps to preserve them.
Before attempting any cleaning or service work, turn the unit OFF and unplug it from the wall outlet and allow it to thoroughly thaw. Keep in mind, a dehumidifier will freeze up, if the room temperature is below 40 degrees. Also, where you have it installed may be a problem. Particuarly, a basement. Where the air temperature is colder at floor level.
In case you have misplaced your Owners Manual, I have included a link to it that you can download & print for future reference. Be advised, your Model Number is not for a Sunbeam Dehumidifier, it's for a Comfort Aire dehumidifier that's manufactured by Heat Controller Inc.
http://www.sylvane.com/images/prodphoto/co758/comfort-aire-product-manual-501-651-D.pdf
I hope this helps you solve the problem. Please let me know. Thanks.
May 07, 2011 | Sunbeam 30Pint Dehumidifier
I live in a very small one room studio,and have a comfort aire window unit...air and heat.The heat works real well,but in the spring and summer,I would set the unit on the coldest setting.I can hear the...
Lets look at the output of the system first. Take your square footage of the area you are trying to condition and times it by 15. We try to get 15 Btu's per square foot of air conditioning. If your area is say 10 by 15, you have 150 square feet; times it by 15 = 2250 Btu unit is required. If you have a 5,000 Btu unit, it should be more than enough to cool the room. If this is correct, the problem may be because you have the unit set for Dry. In Dry mode, the compressor will cycle less frequently than if on Cool. If in fact the unit is on Cool, you may need to lower the temperature setting to fool the sensor from turning off the compressor prematurly. If you still can't cool the area, your unit has an issue with either refrigeration or air circulation and will need to be serviced.
Apr 09, 2011 | Comfort-Aire Heating & Cooling
How do I get an instruction manual?
Try Googling: instruction manual Campbell Hausfeld CC2300 12V RCH Air Compressor
Dec 15, 2010 | Campbell Hausfeld CC2300 12V RCH Air...
B zone is only cooling to 49 degrees and leds at L3 and L4 are blinking at 1 second intervals at circuit card on outdoor condensing unit. Is there a service manual available for download?
Hi
The L3 and L4 lights are blinking means that the filter is dirty and obstructed. You’ll need to clean the filter. Also Inspect whether the evaporator air is blocked, remove the blockage. Check the air intake and outlet ducts of the condenser side are obstructed. Check both of the ducts. Check whether the unit is set on dehumidifying mode. Set at cooling mode, Set at low fan speed Re-set the fan speed at high speed and check.
However, if this doesn't help then it might have happened that the compressor is not runing and the connection to the compressor is cut. Please check the wiring diagram on Pg 22 in this manual---
Comfort-Aire Air Conditioner Manual & wiring diagram
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Aug 02, 2010 | Comfort-Aire HMC18AD-1 Air Conditioner
Jenn-Aire Refrigerator Shutting Down
sounds as if the control board has gone bad unless you have an extended warranty that you purchased extra this will probably not be covered, but check with jenn-aire to be sure. I dont think I would worry about a 3rd compressor being bad but I would unplug the unit to prevent any further damage to it. good luck peyton
Jan 30, 2009 | Jenn-Air JCD2295KE Side by Side...
Bon-Aire WH160C 12V Air Compressor Logo
52 people viewed this question
Top Bon-Aire Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Bon-Aire Air Tool and Compressor Expert? Answer questions, earn points and help others
