Question about Jenn-Air JMV9169B Convection/Microwave Oven
Crack on Top of Exterior Door - Interior stained
I am having problems cleaning the inside after broiling. I have followed all instructions in the book and it is still unsightly. -
And now I just found a crack in the door! It is from the top of the glass frame, yet not extended to the handle of the door. This is microwave is about a year old and my husband and I are the only ones that use it..
    Genius:
  • 1,199 Answers
I would STOP useing at once!! Stray microwaves seeping through the crack can be very harmfull to humans and pets! I would call the maker and complain! this is not normal for this to happen unless dropped! (door can be replaced!)
Please rate this response!
Posted on Jan 23, 2009
Exterior of oven , top and both sides gets very hot to touch, when cooking +- 10 minutes or more the last couple of days; no Error ( E41/42/45 or 47 are being displayed. Fan is normal, functions: OK
There could be food or oil buildup around the door frame which will absorb some of the radiant and microwave energy whilst cooking. Give it all a good clean and see if that helps. If everything else is working properly, it may be a problem with the cooling fan. Microwave ovens have a "stirrer fan" inside the roof or rear of the cooking area to disperse the microwaves and some convection / microwave ovens also have a cooling fan which assists in dissipating heat within the cabinet.
Jan 04, 2016 | Microwave Ovens
Microwave on counter burned paper or food between the door and the frame of the microwave. what can i use to remove the residue?
Follow the cleaning and maintenance instructions in your manual.
As long as the door closes correctly and seals, the microwave can be used. There are some good cleaners and methods available to remove the stain.
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=how%20to%20remove%20burn%20stains%20from%20microwave
Mar 11, 2015 | Microwave Ovens
Clean inside glass door jenn-air jmc8130dd
follow your instruction manual, download from www.fitness.manualsonline.com or www. retrevo.com
God bless you
Dec 09, 2013 | Jenn-Air JMC8130DD Microwave Oven
How do I clean the stainless steel interior of my electrolux icon microwave
Hello - Interior cleaning after convection, mix or broil cooking:
Spatters may occur because of moisture and grease. Wash immediately after use with hot, soapy water. Rinse and polish dry. Harder to remove spatters may occur if oven is not thoroughly cleaned or if there is long time/high temperature cooking. If so, you may wish to purchase an oven cleaner pad with liquid cleaner within it-not a soap filled steel pad-for use on stainlessor porcelain surfaces. Follow manufacturer's directions carefully and be especially cautious not to get any of the liquid cleaner in the perforations on the wall or ceiling or any door surfaces. Rinse thoroughly and polish dry. After cleaning the interior thoroughly, residual grease may be removed from the interior ducts and heater by simply operating the oven on 450 F for 20 minutes without food. Ventilate the room if necessary.
Interior cleaning after microwave cooking:
Cleaning is easy because no heat is generated to the interior surfaces; therefore, there is no baking and setting of spills or spattering. To clean the interior surfaces, wipe with a soft cloth and warm water. DO NOT USE ABRASIVE OR HARSH CLEANERS OR SCOURING PADS. For heavier soil, use baking soda or a mild soap; rinse thoroughly with hot water. NEVER SPRAY OVEN CLEANERS DIRECTLY ONTO ANY PART OF THE CONVECTION MICROWAVE OVEN.
Nov 09, 2012 | Electrolux E30MO65GSS Convection Microwave...
Where are the fuses located on a samsung electric range oven FTQ3521WW model #
Hello
Fuses can be located behind the microwave door or behind a panel either on the interior wall or an exterior panel. Often the fuse will be behind a panel located under the louver vents on top of the microwave
Oct 04, 2011 | Microwave Ovens
Hello
Fuses can be located behind the microwave door or behind a panel either on the interior wall or an exterior panel. Often the fuse will be behind a panel located under the louver vents on top of the microwave.
Ss25 microwave no power fuse in plug ok, where is internal fuse.
Hello
Kenmore Over the Range Microwave
If you think the window is stained, you ought to see the rest of the inside! Wife is probably right. (wink, wink, nod, nod)
Actually, you can take the cover off, remove the front panel without much effort and clean everything and get a lot more life out of it. Microwaves usually die because of heat related problems caused by buildup of yuck on the guts.
Hope Ya Make your Wife Happy!
Jan 24, 2008 | Microwave Ovens
Deep hard core cleaning
From GEAppliances.com: Microwave - Cleaning Recommendations To minimize the possibility of electric shock, unplug the microwave from the power supply before attempting any maintenance or cleaning. Spills and spatters clean up easily with a damp, soapy paper towel or sponge. It is best to clean soil as soon as it appears. Baking soda and water may also be used. If the food has cooked onto the interior, heat one cup of water on full power for three minutes. The heat and steam help to soften the food. After the three minutes, allow five additional minutes stand time then clean as usual. A non-abrasive scrubbing pad cleaner works well for stubborn stains. You may use mild dish washing liquid or cleaners specifically listed for cleaning interiors of microwave ovens such as MicroBryte® (wx10x3030) or Microwave Oven Magic®. We do not recommend using other detergent based cleaners because they can cause the plastic parts to crack. You may purchase microwave interior cleaner by calling our parts department at 1-800-626-2002, on-line from GE Parts or from your local grocer. For stainless steel interiors of microwave/convection models, we recommend a plastic, soap-filled scouring pad. Rubbing gently with this pad will help remove soil. For the door surfaces (both interior and exterior) We recommend you use only mild, non-abrasive soaps, or detergents applied with a sponge, or soft cloth. For the control panel Wipe with a soft, damp cloth. Dry immediately with a soft cloth. Do not spray any solution directly onto the controls Important: Commercial Oven Cleaners, abrasive cleaners, or cleaners containing ammonia or bleach (can make the plastic brittle) should not be used on any part of the microwave. -- From me - Maybe local restaurants in your area would have some tips? Otherwise, try a Google search for keywords: cleaning stainless steel oven
Aug 05, 2007 | GE Advantium 120 Convection/Microwave Oven
Jenn-Air JMV9169B Convection/Microwave Oven Logo
131 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
