Rolling Picture on Citizen DVD model jdvd3820
When turned on, the picture is constantly rolling. My resseller told me I have to reset the unit. Can you help me with this problem?
  • 25 more comments
  • serge_line Jan 23, 2009
    Cleaning VCR head does not resolve problem. The rolling effect starts even without any disk in the player.
    The problem seems to be like tracking on a VHS player.
    There is no tracking setting options on this unit.
    I also tried to change cables between DVD and TV without any success.
    Thank you Guru, I think you have the solution, but I would need instructions how to ckeck the color system for my dvd player.I can't find my owners manual.
    I realy think it's about colour settings like explained by Guru.
    Since my TV is hold and cannot change settings, I think I need to reset my DVD player and need instructions for that.
    Since display is rolling I cannot set up the color setting on DVD.
    Citizen Model # jdvd3820
    Thanks Guru, I will try on another TV and let you know later.
    Thanks Mr Mark.
  • serge_line Jan 24, 2009
    As indicated before the model # is jdvd3820
    tanks but I need to obtain owner's manual to obtain the procedure to restart the unit.
    thanks
    Thanks
    Since screen doesn't stop rolling, I can't select any region. There must be a way to stop the screen in order to select a region.
    Nothing happens with this procedure.
    I'm using standard rca plugs cable, would s-video cable be more appropriate? I have always used rca cable before and never had problems untill today.
    Thanks but my problem is more about settings on the unit
    thanks cleaning was already done.
    For Guru;
    I tried the unit on another TV set and the problem is the same
    thanks for the info Mohamed,
    I give up for tonight.
    It seems that user manual for this product is not available.
    Only DVD player has the prog/ component video out
    Thanks
  • serge_line Jan 25, 2009
    Thank you all for your suggestions.
    I will get it repaired by a technician from my resseller.
    It seems that he knows this type of DVD very well.
    Thank you all for your support,
    Brigadier General:
  • 5,158 Answers
Does that tv use an analog converter... you may need to purchase a digital receiver box for that tv
Robert
Posted on Jan 24, 2009
  • 535 Answers
U have to need set eht volatege
  • sandip panchal
    sandip panchal Jan 24, 2009
    try to play another dvd its working fine then its ur dvd manufactering problem its happens many time
  • 19,396 Answers
  • Ginko
    Ginko Jan 25, 2009
    Test that the DVD is working by hooking it up on a different TV, if the DVD does not work on a different TV, no use in wasting time on this.In that case , just send it for repairs.
    President:
  • 1,952 Answers
Try spraying the motor and the control with a switch cleaner. Make sure that the cleaner contains a lubricant as well. Also, check the gears on the motor. It is possible that the motor driver IC is starting to go and can not provide the power for consistant movement as well.
  • mohammed marika thambi
    mohammed marika thambi Jan 24, 2009
    lets try a complete reset. The owner's manual should have instructions
    on how to force a reset. If not, try unplugging the unit for a couple
    of hours. If the reset doesn't work, I'd start looking in the power
    supply area.
    video processing circuitry is faulty
    can diagnose this remotely, but when you change the mode, circuits are
    enabled that normally are not engaged. These circuits are digital
    processing circuits and may be effecting the data lines that control
    the entire set.
  • 10,515 Answers
    President:
  • 2,559 Answers
Sounds like you are using the S-video cable for the connection,If so, try and use a composite cable instead,(it's the yellow one with standard rca plugs)If that does it,you just need a new S-video cable.
  • Randy Hough
    Randy Hough Jan 24, 2009
    Here are a few options
    Option 1
    Your DVD Players can play PAL and NTSC and leaves the NTSC at the 30 f/s and just adjust the picture size to PAL, unfortunatly if you TV cant handle a 30 f/s ( 60 cycles/sec) then the result is the scrolling your seeing. Solution(change to the correct format)
    To do this,Open the tray
    Press "setup" button on the remote,a menu will appear
    Press the cursor button ">" on the remote to choose "Preference page"
    Press the numer keys "1 3 7 9" from the remote,
    The tv will then show the region code menu.
    Press the cursor button on the remote to choose your favorite.
    Option 2
    Your DVD player is a Progressive Scan capable DVD player. It is possible that your DVD player is sending its video in a progressive scan format and your TV may only be compatible with an interlaced format. When this happens you can see a rolling picture, a side by side picture and even no picture depending on the TV.
    If it is a progressive scan player, just make sure that the Progressive function is turned off.
    To do this,Open tray and press menu,setting,and turn off progressive scan.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Pls try:
  • open the try;
  • press "SETUP" button on the remote;
  • a MENU will display;
  • press on </> (left/right) on remote to display "PREFERENCES PAGE";
  • press 1, 3, 7 ,9 on the remote;
  • display will show MENU;
  • press on </> (left/right) on remote to display REGION 1.
Postback results. Good luck and thank you for using FixYa.
  • Louie  Role
    Louie Role Jan 24, 2009
    try the unit with a multi system TV set to auto to at least program the MENU/Region.
  • 11,896 Answers
THE UP AND DOWN ARROWS FOR CHANEL CHANGING IS ALSO YOUR TRACKING CONTROL!!!!!!!!!!
  • 1 more comment
  • Nate Stansfield
    Nate Stansfield Jan 24, 2009
    HERE IS YOUR MANUAL. COPY AND PASTE IN YOUR BROWSER
    http://gaurang.org/pub/dvd_player.pdf
  • Nate Stansfield
    SORRY, THAT MANUAL IS FOR SOMETHING ELSE. COULD NOT FIND YOUR MANUAL JUST YET I WILL KEEP LOOKING. BUT HOWEVER, I DID FIND THE INSTRUCTIONS ON HOW TO RESET THE DVD PLAYER
    The solution is bizarre, but it's straight from the manual. Press the
    open/close button on the DVD player so that the disc tray comes out.
    Then, press the '0' button on the remote until the correct display
    comes up.
  • Nate Stansfield
    If your dvd player is hooked up via RCA jacks, I would suggest try s-video cables. If this does not fix the problem, try swithching aspect ratio in dvd menu. If you have tried different display settings and your player still doesn't work, then the problem is due to the video output board on the player has to be fixed by an electronical repair shop.
  • 350 Answers
Please Continue the Explanation.....
    Sergeant:
  • 221 Answers
Keep the unit ON AND THEN press the volume up and down button together.on the fron pannel of the unit and aFTER THAT on remote control also do the same thing to make it also function.
other wise it also
sounds like the update may have changed your video settings. Go to the settings tab and change your video settings to match your television
    Scholar:
  • 97 Answers
unplug all the cables and press and hold the ON or power button for 2 min and release.......
Posted on Jan 23, 2009
    President:
  • 1,214 Answers
Please provide the exact model number of the unit.
  • Mark Egan Jan 23, 2009
    That Model number does not come up on Citizens website.
    Can you confirm the model number? The manual will be the most help to you.
  • 153 Answers
Resetting dvd player u need to hav the manual for tat it would be very much useful else not check tat u hav a button benith the dvd player r behind it press it tat wil do
  • 818 Answers
Sounds like the update may have changed your video settings. Go to the settings tab and change your video settings to match your television, it will be 480p, 720p,1080i or 1080p I believe.
  • 10,594 Answers
This looks vertical deflection frequency difference like TV is set on NTSC (60Hz) and DVD Player is generating PAL (50Hz) video out signal.
Please check color system of both units (TV and Player) and should be set on either NTSC or PAL.
  • 4 more comments
  • Shahid Electronics
    Shahid Electronics Jan 23, 2009
    You can set color system at AUTO in your TV to resolve the problem.
    I need to know country name where you live.
    Instruction manual is not available for your Citizen DVD Player.
    You can check color setting option in DVD Player Menu.
    please let me know have you checked dvd player menu for color options? without your comments or feedback how can I know or suggest any thing more.
    Thanks for update.
    You can try dvd player on another TV, its 2nd option.
    Shahid Electronics Jan 24, 2009
    OK, Tried player on another TV and problem is same.
    This shows that most probably video out buffer transistor in player is damaged / not giving proper composite video output signal 1V p-p
    Here you have another option, hook dvd player through Component Video Out (red-green-blue) if TV and dvd player has this connections facility.
    Comment posted on Jan 24, 2009
    Hook the player to another TV having component input to make sure that DVD player color settings are OK and to verify that Composite Video out (yellow) has some problem as written above.
    Thanks.
    Novelist:
  • 101 Answers
Have you tried changing out the cables that you are using yet? It sounds like a problem with the video feed with the cable. The feed is just getting messed up on the way to the tv. I used to run into this problem all the time when I owned my home entertainment company. Cables just go bad sometimes. Let me know how that works for you.
    Scholar:
  • 140 Answers
The driver for everything the offer are posted here
You can also get the manuals from the same site.
  • 679 Answers
There might be problem is in the VCR head.
So, please clean VCR player Head by a soft cloth or cotton, and let me know the result for further assistance.
Thanks
  • rockfixya
    rockfixya Jan 23, 2009
    using another S-Video cable may help isolate the interference, and thinks that will help you..
Rolling picture on dvd
Check the picture settings.
Dec 18, 2012 | Televison & Video
Picture on tv rolls when dvd player is on.
Radio Frequency Interference (RFI) being generated by you rDVD Player.
That, or you have the DVDs settings on PAL instead of NTSC.
Mar 13, 2009 | Prosonic PD-007 DVD Player
DVD player - b+w rolling picture
it mey be change invideo out put has been changes i.e. ntse or pal mode to changes that mode on remote threr is p/n switch
Mar 03, 2009 | Televison & Video
Picture rolling when I first turn on my tv
A rolling picture or loss of vertical sync can be caused by several components including a bad signal board or jack panel assy. You will not be able to resolve this yourself. contact a Mitsubishi authorized service center.
michtech
Feb 14, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Rolling picture
What is brand your DVD and model
Do you have component input on your TV, use it you may see the picture
Cheers
Dec 10, 2008 | Apex Digital Televison & Video
I bought a dvd player cobusa model dvd-224. the box stated that it can play Pal and NTSC dvd discs.How does one setup for pal region 5 disc? When I setup for pal I get a rolling black and white picture...
Check to be sure that the setup is correct. The picture you are describing is what happens when you play PAL into an NTSC unit. I don't think you are in PAL mode.
Dan
Jun 27, 2008 | Televison & Video
Rolling picture
sounds like the update may have changed your video settings. Go to the settings tab and change your video settings to match your television, it will be 480p, 720p,1080i or 1080p I believe.
Apr 19, 2008 | Microsoft Xbox 360 Console
Picture rolls
Same as sherpi here, player was fine, and all of sudden started rolling and never stops. Rolls with or without a disc in it...seems to play the discs fine, but never quits rolling.
Mar 08, 2008 | Spectroniq PD-1100 DVD Player
The picture on the VCR keeps rolling. How do I remedy this? I have a Sylvania cca-132a2 model.
i know this may seem old-school, but try turning the vertical hold knob. it used to solve all vcr problems with rolling picture.
Jul 07, 2007 | Sylvania (SRDD495) DVD Player/VCR
Picture keeps rolling
The picture rolling is simply because the PAL decoder can't lock up to the 60Hz vertical sync pulses, even if your DVD player is set to NTSC-PAL conversion and there is no vertical hold adjustment (either external or internal) on this model set to achieve this. There is a possible alternative only if your DVD player has RGB output (not component). The JVC for example has direct RGB drive capability via the SCART input on the back panel. If you get a suitable lead you could try getting a picture this way as it bypasses the decoding and sync sep circuits in the PAL decoder chip.
Oct 03, 2005 | Panasonic DVD-F87 Multi-disc DVD Player
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
