Question about Gestetner Office Equipment & Supplies
Gestetner Dsm616 sc500
I have a problem.... my gestetner Dsm616... got error sc 500... please help me :(
Bubbabear64
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
SOURCE: Error code sc 500
check the developer gear...txt me at 09275514418
Posted on Oct 27, 2008
  • 86 Answers
SOURCE: Gestetner 3218 Aficio 180 Fuctional Problem SC 543
Enter SP mode - Clear button (yellow key), 1 0 7 and hold and press stop button (orange key).
Enter SP5-810 (SC code reset) and select “1”.
Then hold down the “Photo mode” key and the enter key(hash) at the same time for at least 3 seconds (it is not necessary to turn the main switch off andon). If the machine beeps 5 times, the reset was successful. If it only beeps twice, the reset failed, and you need to repair the machine.
Possible causes are the fusing thermistor in the fuser unit, or the power supply unit defective.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
SOURCE: Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
Posted on Feb 16, 2009
  • 3 Answers
SOURCE: eror sc 500
remove all paper from the trays then turn machine off wait a few second then turn back on should reset then reload paper
Posted on Apr 11, 2010
What is SC500 error on Ricoh Aficio 2020D?
gear assy not turning can be many things. Main motor/devlp unit /fuser/ transfer roller
Aug 14, 2014 | Ricoh Aficio 2020 All-In-One Laser Printer
Error sc500
SC 500 Abnormal manual feed drive motor speed.
Dec 16, 2013 | Ricoh Office Equipment & Supplies
Functional problems. sc500
Main motor lock, something is bound up
Nov 17, 2013 | Gestetner Office Equipment & Supplies
Nashuatec dsm616 sc 544
more than likely to be paper wrapped round the hot roller - remove the fuser and split it - then clean the thermistors - should sort it
Oct 21, 2013 | Gestetner Office Equipment & Supplies
Eror sc 500
Apr 08, 2010 | Ricoh Aficio MP 2000 Black and White...
Aficio 2019d error code sc 500
iam asking for help to solve an error code SC500 on my photocopier machine DSm622
Mar 16, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Gestetner DSM616 no network config
Sounds like you don't have a print or print/scan option in stalled. All machines come with network port but only works if option is intalled. You can check if you have the option installed, maybe just not activated. At the back just abouve the network port there is a cover that covers 2 sd card slots. If the is no sd card installed you will not be able to print to the machine. If the is a sd card installed contact me again and i will help with activation
Mar 24, 2009 | Gestetner DSm616 Printer
Gestetner DSM616
Turn the machine on, and press clear modes, 1, 0 ,7, and press and hold the clear stop key. It will beep, and a menu will appear. Select copy SP (1), and then select data log (#7) scroll until you get to 7807 (sc/jam counter reset). select it, and press execute. exit all the way out, and recycle the power. If it comes to ready, it should be ok. If it happens again after that, there is a fuser problem of some sort.
Mar 05, 2008 | Gestetner DSm616 Printer
145 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Bernard D'Souza
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
