Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
SimpleTech 80 GB Portable HD Won't Read
My 80 GB SimpleTech Farina Portable HD apparently got jostled in my carry-on bag on a recent airplane flight and now computer will not recognize. The red light is on continuously, the blue light is flashing, and the PC beeps when it detects the USB external device, but the drive doesn't show up in Windows Explorer. Have tried with several different cables and three different PC's, with same results. If I tilt the drive back and forth, I can hear the internals move around a little. The USB connection at the drive also seems a little loose
I've got my entire MP3 collection on there, as well as photos, some business files, etc. I sure would like to recover, but all the data recovery places on the internet want $500+. Would appreciate any help/suggestions. I just bought a new 320 GB portable Maxtor HD (for the same price I originally paid for the 80 GB SimpleTech), so I'm not so concerned with losing the drive, just the data on it. I've learned my lesson and also bought a case for my new one!
I've tried to get help from the SimpleTech website on this, but they have not responded. I think the drive's about 1-1/2 to 2 years old, but I can't find a receipt, so doubt SimpleTech would repair/replace anyway.
  • beej1953 Jan 23, 2009
    Thanks for the suggestions, but my drive case doesn't have any screws (or stickers hiding them), just a small seam on each end and red plastic panels on each side. Guess I could try popping it open at the seams with a small screwdriver, but I'm worried about damaging the hard disk itself.
It sounds like a problem with the board inside the case,- the actual hard drive is probably OK. Opening the case will void any warranty but there may not be much left anyway. There should be 4 screws in the bottom of the drive,- front 2 may be hidden under a sticker. Try installing the drive in your new case or an empty drive bay inside your computer. I have had external hard drive cases fail before and the actual hard drive was ok.
Posted on Jan 23, 2009
  • Bignick613 Jan 24, 2009
    You should not damage the hard drive by popping open the case,- the sensitice areas ate at the back (where teh connections are and sometimes small pressure equalization holes (often covered with rubber or plastic stickers) on the top of the drive. Many drives also have a circuit board on the bottom. As long as you are careful prying open the case you shold be able to get the drive out without damage. but the tabs on the case may get broken in the process. If it does not work anyway then you have nothing to lose. The only problem will be if the drive is a different type than your other portable case or your computer's motherboard will accept. If you get this far and get stuck ther are lots of computer shops or others with the ability to can transfer your files to your other portable drive for a reasonable cost, perhaps $20-$30.
    Hope this helps.
My SimpleTech 120GB drive has mysteriously become read only. Is there a remedy for this?
USB - unplug then plug back in. then right click open check properties make sure you set "security" to read & wite & modify or FULL ACCESS.
Feb 03, 2015 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
Items prohibited on airplane
Not permitted to be carried as a passenger, in passenger carry on baggage, on a commercial ticketed flight. No knives or similar metal objects permitted unless loaded in hold baggage not accessible to persons during the flight.
May 29, 2014 | Sport & Outdoor - Others
Remove flight mode
Turn on / off Airplane mode
Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls.
To turn on airplane mode, follow these steps:
  1. From the Home screen, select Go to.
  2. Scroll to and select Profiles.
  3. Scroll to and select Flight.
  4. Select Activate.
To turn off airplane mode, follow these steps:
  3. Scroll to and select Normal (or a profile other than Flight.)
  4. Select Activate.
Jan 04, 2014 | Nokia Lands Phones
I have a SimpleTech portable drive ( Model 96200, 60G) when i try to read from it, Windows XP informs me that it cannot access the drive due to an "inpage error" I have attempted to run chkdsk,...
I was really hoping someone would post an answer for you . I have the same model and it has recently stopped working on my Vista computer. I suspect a recent MS update or something. How do drivers suddenly not be found any more?
Nov 18, 2010 | SimpleTech SimpleDrive 160 GB External USB...
Simpletech 250 GB Pininfarina was knocked on the floor
oped it, maybe loose cables or connections. or the worst case, a faulty hd. ticking sound means bad drive, cannot read disks. retrieve data? the better chance will be a recover technician, dont try anything else, will turn a worst problem.
Jun 02, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
I backed up my entire computer on my SimpleTech Pinin Farina external hard drive and now I can't figure out how to find a file on it that I need. I see all the backup files, but I can't figure out how to...
Backup software compresses the files and encodes them to an image file made up of a series of sequenced files. The same software you used to do the backup should have the restore options needed to locate desired files. SimpleTech website shows Fabrik to be the name of the backup software.
If you utilized, there's also an online backup site used to store files. Following link is the users guide:
http://www.simpletech.com/support/guides/user-guides/60000-00168-001.pdf
Oct 22, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
LaCie drive won't turn on (blue light doesn't go on)
I doubt your hard drive is dead, even if your HD was dead the blue light would go one. It has to be the internal controller.. Your best bet is to get a HD enclosure and put your old drive in there. I've burned through 3 Lacie cases, all with similar problems..
Ciza
Sep 27, 2008 | LaCie (300770) 250 GB Hard Drive
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
369 people viewed this question
Top SimpleTech Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Gareth Cockram
Gareth Cockram
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
