Question about Xerox WorkCentre M15i Laser Printer
Xerox WorkCentre M15i squeals when printing and copying.
Xerox WorkCentre M15i: Machine squeals when printing and copying. I lubricated metal shafts in document feeder (saw posting on your site), but that didn't help. Sound seems to be coming from back right side of machine. Thanks for your help.
Do not only lubricate metal shafts, but promptly lubricate the "pulleys" on the right and left side.  the will look very similar to a wheek and pulley mechanism.  The squeal happens when one "bar" connects two "wheels" and one side moves faster than the other.
Posted on Jan 23, 2009
My M15i Xerox Workcentre is printing with a vertical line down the page
Solutions for : Vertical Black Lines on Copies When the Automatic Document Feeder and Document Glass are Used Solution : Clean the Drum
  1. Make sure there is paper loaded in the paper tray.
  2. Press the [Menu / Exit] button on the Control Panel.
  3. Press the [Up] or [Down] arrow button until 'Maintenance' is displayed on the Display Screen.
  4. Press the [Enter] button. 'Clean Drum' will be displayed.
  5. Press the [Enter] button. 'Cleaning Drum Please Wait' will be displayed and a sheet of paper will be printed. Toner (Dry Ink) particles on the Drum will be affixed to the paper.
  6. Repeat steps 1 - 5 until the page prints without any Toner particles.
Aug 13, 2011 | Xerox WorkCentre M15i Laser Printer
How do I get a meter reading of number of copies?
Here you go.
  1. Press the [Reports] button on the Control Panel
  2. Press the [Up] or [Down] arrow until 'Systems Data' is displayed on the Display Screen.
  3. Press the [Enter] button.
    The System Data list will be printed with the following information:
    • Total Page Counts: Total number of pages printed
    • CRU Prints: Number of pages printed using the current Toner (Dry Ink) Cartridge
    • Replaced Toner Counts: Number of new Toner Cartridges installed in the machine
    • Replaced Drum Counts: Number of new Drum Cartridges installed in the machine
    • Current Drum Page Counts: Number of pages printed using the current Drum Cartridge
    • Platen Scan Page Counts: Number of pages scanned using the Document Glass
    • ADF Scan Page Counts: Number of pages scanned using the Automatic Document Feeder (ADF)
Feb 10, 2010 | Xerox WorkCentre M15i Laser Printer
Xerox WorkCentre M15i will not turn on. We had the problem last week, let it rest for 2 hrs and it would work again. this time an overnight rest didn't work. It is like it isn't getting any power. We tried...
You have 4 bad capacitors on the Power Supply. Replace C24 and C25 (100 microfarad 35v) Replace C12 and C21 (33 microfarad 35 v). It would be a good idea to replace them with a better voltage rating, maybe 50 volt electrolytic capacitors.
Aug 11, 2009 | Xerox WorkCentre M15i Laser Printer
I wish to read the total copy count on Xerox WorkCentre M15i
You have to print out the meter report.
Apr 19, 2009 | Xerox WorkCentre M15i Laser Printer
We have a workcentre M15i connected to a vista computer. We want to print from a xp computer to the workcentre. The xp only sees the workcentre if the vista computer is turned on. How do we get the xp...
We put a usb cable from the xp computer to the workcentre. We left the Vista computer connected to the workcentre via parallel cable. Not the solution we were hoping for but it does enable us to print from both computers
Apr 14, 2009 | Xerox WorkCentre M15i Laser Printer
Workcentre M15i won't turn on after poss outlet short
turn it off
unplug it
wait a few minutes
plug back in
turn on
Feb 17, 2009 | Xerox WorkCentre M15i Laser Printer
Xerox M15 PCL6 error
I would go to the xerox website and try downloading the PCL5e driver. It works just as well and even better in most cases. I hope this helps.
Dec 07, 2008 | Xerox WorkCentre M15i Laser Printer
Paper Feed Wheels
Yes thats easy to fix.
Unplug the machine, unplug the connector fromt\ the document feeder to the scanner. One white molex connector with 2 thumb screws on back.
Lift the document feeder up and out, and lay it upside down on a table or work surface.
On the bottom side you will see a shiney white strip about 12 inches long and 2 inches wide, it has 2 holes, one on each end to access a couple of screws. Just remove it from one side, just held on with two sided tape. Then roll it back. Under there you will see I think 4 maybe 5 small black plastic rollers. They are held in with one screw attached to a small metal bracket. Remove the screws and plates for all the rollers, remove the rollers and take them off the shafts. Clean and very lightly lubricate those small metal shafts, and reinstall the rollers, etc. The white strip will stick back to the side you peeled it off of.
Those rollers are where the noise is coming from.
Jul 25, 2008 | Xerox WorkCentre M15i Laser Printer
Printer is very slow
In machine settings there is a setting for the USB port , it has a fast and slow setting.
The M15 technically is not a intended to be a network printer.
You can look into hooking it up to a pocket pro device which is a small print server.
There are other products that you can use to set up that, way.
Apr 24, 2008 | Xerox WorkCentre M15i Laser Printer
Xerox WorkCentre M15i Laser Printer Logo
247 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
