Question about Peavey Music
What causes power tubes to over heat in peavey valveking 100
I have a peavey valveking 212 that the 6L6's suddenly started over heating in. Thanks. Any ideas
4 Suggested Answers
SOURCE: My son has a Peavey valveking 212 keeps blowing
Check w dealer about warranty - I thought it was 2 years? Great amps when they're working! I love my tone on it! :)
Posted on Jan 18, 2011
  • 5603 Answers
SOURCE: my peavey valveking vk 112 is making a whistling
A high frequency feedback can be very hard to isolate without test equipment... you MIGHT have a "microphonic" tube that picks up from the speaker and feeds back... Tap the small tubes with a pencil and see if any of them "ring"... gentle taps of course... If one seems sensitive, swap like numbered ones around to see if you can find a happy place for them. Electrically there could be a bad ground inside causing these.
I notice you have 4 tubes in the output... REMEMBER when you used matched pairs... the members of the pairs do NOT go side by side all the way down the string...
Put each tube of a matched pair at the ends of the string of four, and the other pair as the middle two...
Posted on Feb 12, 2011
KeithOB
  • 59 Answers
SOURCE: what ohm selection and which
that depends on your cabinet(s). if you have an 8 ohm cabinet you want to use your 8 ohm out. if its a 16 ohm cabinet you want the 16 ohm out.. etc.. etc. etc.. owners manuals will tell you these specs
Posted on Sep 01, 2011
Peavey problems
cracked solder joints, how old is it, they have 5 year warranties..
Aug 02, 2014 | Peavey ValveKing 100w All Tube 212 Combo...
Peavey problems
Numerous possible issues with your description. I would start with the tubes, and check if not one or more has faulted.
Jul 19, 2014 | Peavey Valveking 112 - Tube Guitar...
My reverb on my valveking head 100w is not working
first change tube 12at
if not help check the tank reberb (one spring is broken)
Jun 14, 2014 | Peavey ValveKing 100w All Tube Head Guitar...
Valveking 212 combo shows lamp lights but power tubes are not lighting no sound
no filament power then, filament fuse open..blown winding on transformer, regulator bad..You an ET with shop full of tools...then we can get to work...
Dec 31, 2013 | Peavey ValveKing 100w All Tube 212 Combo...
Peavey Valveking head strange feedback.
Sounds like one of your tubes going bad and becoming microphonic...
Google "Microphonic Tube" for additional info.
Oct 25, 2012 | Peavey Valveking Vk100 Guitar Head
Where can I order a new tube cage for my VK212?
I haven't found the part in question, but try contacting Peavey directly at: http://www.peavey.com/support/contactinfo/
Mar 07, 2011 | Peavey ValveKing 100w All Tube 212 Combo...
My peavey valveking vk 112 is making a whistling noise I changed the 2 main tubes and it is still doing it what coud be the problem and how can i fix it
Feb 12, 2011 | Peavey ValveKing 100w All Tube 212 Combo...
I have a Peavey ValveKing 112. It seems like it just takes forever for the tubes to warm up. For like the first hour that it's turned on the clean channel seems fine, but the second channel doesn't work....
Buy ONE new 12AX7 and try it in location V1 and if it doesn't help, try it in V2. This tube has TWO heaters in it and if one is intermittent that could cause your problem. The vibration MIGHT be "fixing" a briken heater after some time.
There are MANY components that could cause this, so you might have to take it in for repair if it isn't a simple tube problem. Since it works on the clean channel, V3 should be OK.
Feb 11, 2011 | Peavey Valveking 112 - Tube Guitar...
Music Logo
48 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
