Question about Drills
Ryobi HBD-480R Battery - Drills
Ryobi blower flashing green red when charging Won't charge
I have run RYOBI printing presses for the last 30 years and I bought a RYOBI rechargeable drill and rechargeable garden tool. I am disgusted by how cheap they were and how the batteries just gave up. I have heard about bumping a battery by running a good battery thru it. It was suppose recondition the battery, however I got two ruined battery for that.
Jan 04, 2018 | Ryobi Drills
I have a P115 Ryobi Intelliport charger , will it charge the new lithium 18 V battery?
Ryobi P115 is an 18V battery charger. However, Ryobi Manual did not mention the current rating of P115. if the current rating of Ryobi P115 is 50% higher than your 18V Lithium Battery it will charge. but if it's less than or equal, it will not.
Nov 29, 2017 | Ryobi Drills
How do i open repeters with my ft-480r
You must have the tone codes to use then. Contact the local Ham radio club.
Feb 22, 2015 | Radio Communications
Open my local repter w. r
I think you are asking to use the local repeaters to extend your range. To do this, you need the local tone codes. Ham repeaters are not "public", so local clubs or even individuals own them. They restrict use and will give you their codes with proof of a valid FCC License. A License is fairly easy to obtain, but you must have one.
Feb 22, 2015 | Yaesu FT-480R Technical Manual
Why does ryobi 18V cordless not charge
Please check the LED status of your charger. If both of the charger'sLED flashing, but it can charge a good battery. Than the battery is defective, you may replace a new Ryobi P206 Battery http://www.batteryshops.co.uk/tags_products/ryobi-p206-12-18v-2-speed-drill-driver-battery_6854.html
May 11, 2014 | Ryobi 18v Cordless Drill - P206 18 Volt V
MY SONY HBD-DZ810 HOME THEATER IS CONSTANTLY SHOWING PUSH POWER PROTECTOR
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
You may also refer to the following link for additional troubleshooting steps.
PROTECT and PUSH POWER flash alternately on the amplifier screen
Dec 20, 2012 | Sony DAV-HDX500 System
Yaesu FT-480R has no receive or transmitt
Hi Bob,
Great radio that you have there...
To get the best advice and info, do the following: join yahoo group specific to your radio Make/Model, the expert team there will be only to happy to assist, you can also download manuals, schematics and other goodies for your radio. All this is free.
I certainly hope I have been helpful to you.
Cheers,
Peter
Aug 28, 2012 | Yaesu FT-480R Technical Manual
Drills Logo
129 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
