Question about Canon EOS 600D Rebel T3i Digital Camera
Built in flash could not raised up
Making clicking sound too
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 30 Answers
I have the Canon Rebel t1i (500d) and I had the same problem (built in flash not working). I tried a number of remedies I found on forums etc but none worked. I then tried this with the camera pointing away from me as if taking a picture. In the external flash housing is a metal sprung plate which surrounds the five circular pins (one big, four small at the rear). If you get a small straight headed screwdriver and lift the front of this plate and at the same time pull it back towards you it will come out altogether. (In picture 2 I show this plate removed and sitting in front of the mount only so you can see it removed, it was brought out backwards so towards me from the camera).
I then removed the four small screws being careful not to drop them and took off the mount for the external flash and then tried the flash it opened straight away. I then cleaned all the area of the mount and the two plates and replaced them all ensuring I fitted them exactly as before. I then checked the camera again and presto working fine. I hope this helps everyone with the problem.
I hope this remedy works it did for me.
Posted on Jan 15, 2013
Pride ultra making noises during ride
If you turn to the right and the speed of the clicking sound goes faster then your left wheel has the problem. The shaft key is a little loose and is shifting while running. If you turn to the right and the speed of the clicking sound goes slower then the right wheel has the problem. Sometimes a stick will become lodged underneath making contact with the wheel or rim making a clicking noise. These noises can drive me nuts. Scooter Doctor App
Jun 01, 2016 | Pride Health & Beauty
My 2004 t&c 3.8 is making a weird sound like a
There are many possibilities that can cause car to make noise.
It's actually from where the noise is coming from. Front end or rear end. From engine area or from inside the steering or from brakes.
There is N-number of possibilities for the car to make wierd noise or any other kind of noise.
For step by step troubleshooting this problem, I suggest you to refer the help links mentioned below. Its a complete solution with proper explanation to identify the cause of problem: ------
Click the link below: -----
Car makes clicking noise?
http://howtobyme.blogspot.com/2011/11/car-makes-clicking-noise.html
Car makes whining noise like driving on rough pavement?
http://howtobyme.blogspot.com/2011/12/car-makes-whining-noise-like-driving-on.html
Chirping Noise From Car?
http://technoanswers.blogspot.com/2011/11/chirping-noise-from-car.html
What are the possibilities for Clicking noise in car?
http://technoanswers.blogspot.com/2011/11/what-are-possibilities-for-clicking.html
Squealing at start up on car?
http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html
Chirping sound coming from engine?
http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
Vehicle making Clunk Thump Thud noise?
http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Heater makes clicking noise under dash on Ford Explorer?
http://technoanswers.blogspot.in/2012/01/heater-makes-clicking-noise-under-dash.html
Clicking noise under dash and front defroster not working?
http://technoanswers.blogspot.com/2012/01/clicking-noise-under-dash-and-front.html
Car Brakes Making Noise?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Alternator making noise?
http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
Car Alternator Bearing Makes Grinding noise?
http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html
Engine makes noise and Cooling Fan belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Vehicle Makes Clicking Sound While Taking turns?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-makes-clicking-sound-while.html
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
Why is my samsung clp making a clicking noise?
Is the printer making a clicking sound when it is printing? Or is it just making a clicking sound but there are no light and the printer appears to be dead except making a clicking sound?
I know of a cause for either case.
Case 1. It is clicking when printing. Sometimes the toner cartridges are not seated properly in the imaging unit, and causes the gear on the cartridge to slip making a clicking sound as the gear is being turned. Try pulling out the cartridges and try turning the gear. It should turn smoothly without binding. If it binds, there is not much you can do about it except replace it when it goes empty. Reinsert the cartridge and check that it inserted completely into the imaging unit.
Case 2. Printer is dead, not printing except making a clicking sound. This is due to the power supply board failure. Usually the failure is due to a blown filter capacitor on the power supply board. The power supply is located on the right side of the printer. Remove the right side panel to get access to the board. The board can be either repaired or replaced. Hope this helps you.
Feb 22, 2011 | Samsung CLP 300 Laser Printer
52" tv making clicking sounds
Does the blue light just stay steady or does it blink? Also please tell me the make and model of the tv. Sounds like a problem due to capacitor plague but I would like to be sure.
Sai.
Dec 12, 2010 | Philips Televison & Video
My mothers beko fridge freezer making bubbling sound
Sounds like the evaporator fan is doing its job. Nothing to worry about. Good hearing is a blessing all fridges make different sounds some click loud while others gurgle loud. Some pop and snap. Till I got my hearing aids I didn't know mine ran so loud and clicked.
Dec 15, 2009 | Refrigerators
ENGINE MAKING CLICKING SOUND SOUNDS LIKE LOOSE
PISTON RING NOISE.IT WILL MAKE A CLICKING NOISE LIKE A BAD TAPPET.
Oct 18, 2009 | 1997 Dodge Caravan
Optima movie time DV10 not recognizing disc and making clicking sound
I have the very same issue. The dvd player makes a clicking sounds, spins, then stops...no disc. I have tried cleaning it and have also tried new dvds.
Mar 01, 2008 | Optoma MovieTime DV10 Multimedia Projector
Canon EOS 600D Rebel T3i Digital Camera Logo
103 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
