Spirit of St. Louis Turntable Art No. 541.809 stylus
So i have this turntable whose stylus seems to be broken. Is there anyway I can replace or salvage this instrument? The speaker seems to be picking some of the reverberations however the needle is rounded and slides off. Pic: http://imageshack.us/photo/my-images/502/20130113233457.jpg/
  • Audio Player... Master
  • 5,126 Answers
You need only find the cartridge model and then search the net for it. That should find the stylus for it. Or you can replace the cartridge with a different make as long as it will fit in the headshell of the arm.
Posted on Jan 14, 2013
SOURCE: new needle for sony ps-lx250h?
I have the same turntable and I just bought a replacement needle through the needledoctor.com. The needle is made by Audio Technica and the part number is ATN3600L.
Posted on Feb 27, 2008
djproaudio
  • 515 Answers
SOURCE: sl-dd33 turntable
If your needle just started to skip across the LP, then that means your stylus is damaged/worn and needs to be replaced. It's very hard to see the diamond tip on the stylus, and it might not even be there at all. So checking it might not yield any results. This is what happens when the needle is worn. It will skip across the record.
- OPTiC
Turntable Technician
www.1200s.com
Posted on Sep 08, 2008
arthurroger
  • 170 Answers
SOURCE: turntable arm slides across record, Am. D.J.-1500
See what type of cartridge is installed in the arm. Manufacturers use common cartridges in turntables, such as Stanton, Shure etc. Detach the head shell from the arm (it usually slips right off via a locking ring and four-pin mini plug) Look for the manufacturer and model number on the cartridge. No need to remove it from the head shell. On most modern cartridges, the stylus (as they are called, rather than the needle) simply slips off and on. No need to remove the entire cartridge (via screws) and re-align it. In fact, many DJs bring a set spare cartridges and styli on a gig, already mounted in head shells, and simply interchange them as needed. When you have the make and model of the cartridge, go to Radio Shack or use their website to order a new one...or  two. Or go to Google and enter "phono stylus" as your search term. You will find reasonably priced styli for nearly every cartridge imaginable. I operate 50 year-old turntables and am able to find replacement cartridges and styli on line. Ebay also has a number of listings, by make and model of the cartridge. When the new stylus arrives, observe how easily the old one comes out of the cartridge- usually pull and slide - and slide the new one in. Re-insert the head shell on the arm, tighten the locking ring, and you're good to spin!
Posted on Jan 08, 2009
  • 42 Answers
SOURCE: needle bent on Numark TTi Turntable
I have answered this
Posted on Jan 25, 2009
dunnbiker
  • 8546 Answers
SOURCE: difficulty balancing the tone arm on kd-1033 turntable.
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Direct Readout Stylus Pressure to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force on the Direct Readout Stylus Pressure control. Play records.
Posted on Apr 05, 2009
My record player (Spirit of St. Louis CD/Cassette/Turntable) still works, but the turntable seems off. The speakers are fine so it's probably a problem with the needle, or the timing belt.
It's defiantly the belt. You can do it yourself. What you need to do is make a note of how it fits NOW - before you remove it (take photo's if you can. This will make it easy to replace it. You will find access to the belt most likely under the turntable matt. Just lift or peel it up. If it is glued you can re-glue it when you have finished, with some Bostick type glue.
When you have removed it take the diameter of the belt in MM and the thickness and search for it on Google. You don't have to be 100% spot on with the diameter measurement.
If you have any problems fitting the belt there are plenty of demonstration video's for belt replacement on YouTube.
Aug 06, 2015 | Audio Players & Recorders
How do I turn my turn table on. POWER button is on. What other button do I push. I have phono, mono/st, cd, tape, tuner??
Phono button is turntable selector. May be the turntable switches on when you move the arm to the edge of the record.
Dec 17, 2014 | RCA Spirit Of St. Louis Radio/Cassette/CD...
Is there any universal remotes that will work with a spirit of st louis radio, cd player, and phonograph? son broke the remote.
There are, but it's..... hit and miss.
The remotes don't cover all remote devices.
You will need the serial # and the brand B-4 you shop for a remote.
Not available from the manufacturer?
Nov 12, 2014 | RCA Spirit Of St. Louis Radio/Cassette/CD...
Turntable playing too slow
there is a (v.r) for speed in side look for it and turn it a little
Mar 24, 2014 | Technics SL-BD20D Turntable
Need a needle for a spirit of st louis turntable cd cassette player. do not know what kinnd or model to buy
Do you have the old needle?
If so, you can match them up to charts provided by dealers.
If not, try to find out the make / model of the turntable chassis.
Providing some close up photos that would be a big help.
Mar 05, 2014 | RCA Spirit Of St. Louis Radio/Cassette/CD...
Record player does not move
more info needed - could be that the 'belt' driving the turntable has slipped or broke - what type of player is this?
Jul 18, 2009 | RCA Spirit Of St. Louis Radio/Cassette/CD...
Turntable won't turn
There is usually a cotter pin at the center of the platter around the spindle base. This can be removed with a screw driver using a twisting motion. There is a blades worth of space between the clip and the spindle base. Screw driver should be in vertical position. Sometimes the vinyl slip mat must be removed first. Watch that clip, cause it can go flyin. Once the clip is removed, the turntable should let go easily.
May 03, 2009 | RCA Spirit Of St. Louis Radio/Cassette/CD...
370 people viewed this question
 Grubhead
Grubhead
