Question about Saitek P2500 Rumble Force Pad (J62) Game Pad
Is theirI have windows 8 can I make P 2500 Rumble force pad work?
Is their a App that I can down load from web site to make it work?
  • christian klipfel Jan 18, 2013
    I WONT TO INSTALL MY P 2500 RUMBLE GAME PAD ON MY WINDOWS 8 COMPUTER MY P 2500 GAME PAD IS MADE FOR WINDOWS X.P,ME, & WINDOWS 2000 I'M WON-TING TO KNOW IF THEIR IS A FIX FOR THIS PROBLEM TO INSTILL THE P 2500 GAME PAD ON MY NEW WINDOWS 8 PC ?
Shuting down my old Gmail account..
for android phone, click on the gmail app icon to open app. (if you don't already have the app, download it from the google play web site).
In the accounts section of "settings", open the "Google" account. Touch the email name listed, and in the window that appears, at the bottom you'll see a button that says "remove account". Click on that.
Then click on add account to add your new gmail account
Mar 07, 2014 | Google Gmail
Cant work on windows vista
You can download the Vista driver for the P2600 at http://www.saitekusa.com/down/drivers.php
Please rate this solution. Thanks.
Feb 04, 2010 | Saitek P2500 Rumble Force Pad (J62) Game...
It hooks up to my labtop computer but it won't play in any of my games
you need to install drivers for it and go to the web site that sells it and you can download them for free. then you have to calibrate all buttons with the instructions give after you have loaded the drivers for the game pad.
Feb 01, 2010 | Saitek Cyborg Rumble Pad Game Pad
I went to leave work this evening and my car had a terrible rumble when I applied the brakes. Not a squeak or grind, but a low loud rumble. what could it be? 2003 alero with only 35000 miles
You could have lost a brake pad. You need to take the tires off and look at the brake shoes and pads. Try and determine when you drive if the noise is coming from the front or the back. Will narrow it down some.
Dec 08, 2009 | 2003 Oldsmobile Alero
My Saitek game pad will not work with Call of
the game doesn't supports any controller except xbox 360 controller
Aug 01, 2009 | Techland Call of Juarez for Windows
No driver
You should be able to add it from (or make one from) Control Panel > Game Controllers.
Please vote if this helps!
nLinked
Computer Support Services
Jun 07, 2009 | Gemini Sound Products Axis GGE900 Game Pad
Setting up rumble pad
Ok well here is what i did for using the direction pad to play flatout, a pc racing game, using the Wireless rumblepad 2 controller. First open up profiler, click on d-pad, select assignment, then click new POV assignment. Put a check on FPS style movement. Then click edit, then click new keystroke. Hit record and then on the keyboard hit the up, down, left and right keys. Then hit stop and click ok. click cancel on the window right behind it. So now you are viewing the POV assignment window that we opened before. Here what you do is, say for instance hit the "N" button and then to the right of it you see "pov north", hit the scroll down menu and hit "keystroke Up" for N. Like wise you click the "E" button and for POV east you assign "Keystroke right". And so like wise "keystroke down" for "S" and "keystroke left" for "W". Once you have all that done. You hit ok and just open up whatever game you want to play and the Direction pad should be able to allow you to steer or go in the up, down, left or right direction. Hope these instructions help solve your problem.
Oct 16, 2008 | Saitek Cyborg Rumble Pad Game Pad
SEcured web sites not opening
plz scan for viruse an use mozilla firefox it if free,more secure and fast
Jun 23, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
No game connection
What i would suggest for this problem is for you to use add remove programs. Remove the firmware or software for your rumble pad. Then use your favorite search engine and look for a a registry repair program and download it ( this is just incase that during your install it might of changed the registry that it would not reconize your rumble pad) once you have run this program then install the rumble pad according to what the manufacture has printed. Follow each step exactly as they printed. This is critical because each add on to a computer requires a specific order for the install to be complete and for the registry to enable it. After you are done installing it. Go to your system settings and into device manager. There you will find a list of devices avaliable on your computer. look for your product usually listed under USB. Once you find it click on it and go through the menu to see if this hardware has been enabled and there is no problems. If there is a problem you will see "!" next to the problem area.
Sep 23, 2007 | Logitech Rumblepad 2 Vibration Feedback...
Saitek P2500 Rumble Force Pad (J62) Game Pad Logo
183 people viewed this question
Top Saitek Video Game Consoles & Games Experts
 TE5LA
TE5LA
juanmireles1
Michael Vincent Cruz
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
