Question about HP Compaq nc6320 Notebook
General extraction error location ES1 - HP Compaq nc6320 Notebook
    Sergeant:
  • HP Expert
  • 427 Answers
As I understand you are not able to play the games from iwin.
1. Is the issue specific to games from iwin?
2. Are you playing the downloaded version or are you referring to online games?
3. Are you able to play games from other websites?
4. Do you have any third party security program installed on the computer?
5. Are you aware of any changes made to the computer prior to the issue?
If you are using the Internet Explorer from the desktop view, follow the steps to try and run the game in compatibility mode.
a) Open Internet Explorer
b) Press F12
c) Click on Browser mode and click on Internet Explorer 9 or 8.
d) Check if the game runs.
Posted on Apr 17, 2013
How to Use WinRAR?
The WinRAR application will compress the files and save in the same folder or location as the original files. The WinRAR program can also extract compressed files with a RAR or ZIP format. Select the files that require extraction using the pointer. Right click on the selected file to display a drop down menu.
Materials Needed:- PC
- winrar archiver program
- file to compress
- compressed files
Step 1
Ensure that the computer you are going to use for compressing files has WinRAR program installed before proceeding with the compression of file.
Step 2
Select all the files to you want to compress by using the mouse and the CTRL button or the SHIFT button. The CTRL button is for selecting several files in the same folder or location. The SHIFT button is for selecting blocks of files.
Step 3
Right click on the selected files to display a drop down menu. Select the 'Add to Archive' option from the drop down list. This will display a WinRAR window menu.
Step 4
Input a name for the compressed files in the Archive name section in the General tab. Ensure that the name is not similar to any other compressed files in the save location.
Step 5
Select the file format of the compressed file after the deciding on the name. File formats can either be RAR or ZIP. There are also other options such as deleting of the original file after the compression, putting authenticity verifications, and putting a recovery record.
Step 6
Click the 'OK' button after completing all the required fields in the menu. The WinRAR application will compress the files and save in the same folder or location as the original files.
Step 7
Step 8
Right click on the selected file to display a drop down menu. Select the 'Extract files' option from the menu. This will display a window from the WinRAR program.
Step 9
Specify where the extracted files will be located in the 'Destination path' option of the General tab. Do not replace the destination path if the extracted files will also be placed in the same location as the compressed file.
Step 10
Click the 'OK' button after filling the required fields in the window. This will start the extraction process of the RAR or ZIP file.
Oct 19, 2016 | Computers & Internet
Hp 1402 fatal error and MSI.scan
Hi Ihan,
You are facing terrible problem with that error message.. However we can try to fix it. There are few methods you can do..
Solution 1.
  1. Insert the product software CD into the CD-ROM drive on the computer.
  2. Right-click Start and then click Explore . Windows Explorer opens.
  3. Locate and select the CD-ROM drive that contains the product software CD.
  4. Locate and double-click the Setup and then the Scan folders to open them.
  5. Double-click Data1.cab or Scan.cab to open the contents of that file.
Extract, rename, and save the filesLocate the following files, right-click them, select Extract , and save them to the Windows Desktop. Leave Windows Explorer open after extracting the files.
  • F1922_TWUNK_16.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the Desktop, right-click it and rename it to TWUNK_16.EXE .
  • F1923_TWUNK_32.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWUNK_32.EXE .
  • F1928_TWAIN.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWAIN.DLL .
  • F1939_TWAIN_32.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWAIN_32.DLL .
Then you have to copy these files to C:\windows\system32 folder ( this means overwrite the files ) and try to install the software. it should work.
for better understanding check the link below.
MSI.SCAN Solution
Solution 2.
you need to remove all the HP Printer entry from Add/remove or Programs and features under Control panel.
Then download the latest software from HP website by clicking on the link below.
HP PSC 1402 Printer Drivers
Regards,
Suhail
Oct 19, 2011 | Office Equipment & Supplies
Jandy LT400 ES1 light blinking because vent on top was blocked while unit was running
The manual manual says to check the flue (blower motor). The ES1 fault probably means emergency shutdown 1. When the flue was blocked it likely overheated something like the blower motor or some safety device and the system board is now detecting this problem and is indicating ES1.
If one of my customers had this issue then I would be prepared to open the heater and probe locations in the heater with a volt/ohm meter while on the phone with Jandy's technical support number, 800-822-7933. They are likely to help you diagnose this issue and recommend a repair.
Please let me know how this works. Thank you.
Sep 01, 2011 | Jandy Laars Lt 400,000 Btu Heater
Where is the fuel filter located on a 2005 honda civic ex coupe
This site says that there is only an in tank filter that is accessed under the rear seat: http://www.civicforums.com/forums/109-7th-gen-do-yourself-articles/307208-classic-diy-fuel-filter-replacement.html
Jun 16, 2011 | 2005 Honda Civic
I need driver of toshiba ES1 424PDE
I can help you with your Toshiba ES1 424PDE driver problem.
Please review your make and model number information. My research is turning up Dynabook ES1 and also Techra R10-ES1 model numbers. I believe more specific model information is required to provide you with the preferred drivers. Also, operating system preference may be relevant.
I hope that helps.
Aug 30, 2010 | Toshiba Satellite A100-S8111TD Notebook
I have tried to download the driver for my Canon Selphy ES1 photo printer but nothing happens afterward the download finishes. I've lost the disc so can't use it!
You can download the drivers and manuals for your printer at the official Canon site
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=359&modelid=14226
Generally, you need to disconnect your printer before you install the driver, plug in the printer after installation. Things should work fine from there.
Let me know if you need additional help. Thanks.
Nov 12, 2009 | Canon SELPHY ES1 Thermal Printer
Selphy ES1 printer switches on,
remove all the connection go to control pannel printer and default ur Selphy Es1 printer
Jun 18, 2009 | Canon SELPHY ES1 Thermal Printer
Required LG Desktop model-ES1-V24CC,VGA DRIVER
Can i get Vga Driver link for the Lg es1-v24cc Model Desktop
Nov 06, 2008 | LG LW20-EV Notebook
Reset after using emergency close feature
Hi jimmac123
Where exactly in the UK are you ? I'll try and locate another - more helpfull company.
May 20, 2008 | Sony VPL-ES1 Multimedia Projector
HP Compaq nc6320 Notebook Logo
262 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
