Question about Sony vpcyb33kx/b Vaio Y Series Vpc-yb33kx/b - 11.6" - E-450 - Windows 7 Hom
S.M.A.R.T. Hard drive detects error. please consider to back up the hard drive. press any key to continue
2 Suggested Answers
SOURCE: when i cut on the
SMART is a set of indicators of hard drive failure, when one or more of these indicators surpass certain level, the computer assumes hard disk useful life is getting to an end, follow the recommendation, back up all your important files, and use the hard disk until it's not functional anymore, then you'll have to replace the hard drive and reinstall the operative system and your backed up files.
Too bad it has to be me the one to give you this news.
Posted on May 30, 2011
Pri master hard disk s.m.a.r.t. status bad, backup and replace press del to resume
Hard drive is bad or is going to fail soon.
Solution
Backup your information and contact the maunufacturer of the computer or the hard drive for replacement or additional help.
In some very rare cases the S.M.A.R.T. implementation on your computer may have issues of its own and may need to be patched before replacing the hard drive.
If I am receiving the S.M.A.R.T. error, is it ok if I continue to use my hard drive and do not replace it?
As stated above, S.M.A.R.T. is designed to detect upcoming failures in the hard drive.
While it is possible that the hard drive may not fail for several months, it is still inevitable that the hard drive will fail.
It is ok to continue to use the hard drive, however, we highly recommend that if you are still under warranty that you consider getting the drive replaced before your warranty runs out.
hope this helps
Sep 20, 2012 | Western Digital WD AV WD2500AVJS hard...
My LG laptop keyboard was stepped on after which i tried to restart but has refused to com on. after the initial LG logo, instead of opening windows it will show a black screen with the product...
Hi there! Welcome to FixYa! Boot Failure error is generally an error saying that it cannot find Windows on the hard drive. More likely that the hard drive is already broken during the incident or the cable that connects your hard drive was disconnected. You can check if hard drive is still detected by going into BIOS (usually you need to press F2 to launch it). if its not there, then its either the cable is disconnected or the hard drive is broken.
Sep 03, 2011 | Computers & Internet
Check cable connection..! PXE-E63: Error while initializing the NIC PXE-MOF: Exiting Intel PXE ROM No bootable device -- insert boot disk and press any key
Hard drive is not detected. Change the Boot sequence in BIOS
1. To access the BIOS you must tap F2 or delete key upon turning the computer on
2. Try to look for the Hard drive if it is detected by BIOS if not got to step 6
3. Look for Boot Sequence or anything that is associated Boot
4. The Order boot of must be 1st: DVD Drive, 2nd: Hard drive, 3rd: Network etc.
5. Save the changes and Restart
6. If you still get the same message I suggest that you take out the hard drive and put it back in until it is detected in BIOS
7. If Step 6 did not work I think you need to replace the Hard drive
Thanks for Choosing
Jun 16, 2011 | Acer Computers & Internet
When start up my Emachine E525 the laptop the screen is blank, then after a while if any key is pressed a bleeping sound is made the some system language appears on the screen saying: 'For Atheros...
It seemed that the laptop is booting to the network to correct this
1. Go to the BIOS Check if the hard drive is detected by the computer (Hard drives are usually shown as alpha numeric) 2. If the hard drive is detected make sure that the hard drive is the first boot device 3. Save all changes and restart the computer 4. If the hard drive is still not detected you have to take out the hard drive and put it back in (reseat the hard drive) 5. Go to the BIOS again check if the hard drive is detected if not replace the hard drive
Hope this helps
Jun 02, 2011 | E-Machines emachines (emachinees) CD-ROM...
When i cut on the computer it reads S.M.A.R.T. Hard Drive Detects Error. Please consider back up drive. Press ESC to continue
SMART monitoring is a feature of some motherboards that keeps watch of several hard drive parameters. If any of these go outside of a preset range you'll get that message at startup. While this doesn't mean a hard drive failure is imminent, you should follow the advice and back up any data you don't want to lose before it's too late. It's a good habit to back up important files like digital pictures that may be impossible to replace, but far too few people do it.
May 30, 2011 | Sony VAIO EE Series Notebook VPCEE31FX/BJ
My WD5002ABYS drive crashed and it won't format.
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
one bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Mar 12, 2011 | Western Digital WD RE3 WD5002ABYS hard...
Hello: I'm having troubles with a Hard disk Seagate ST31051N Setup configuration. Screen Shows: Non sistem Disk or disk error, Replace and press any key when ready. Booting from Hard...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Nov 26, 2010 | Seagate (ST31051N) 1.06 GB Hard Drive
Hi!im using a toshiba a210 laptop.i put it on some fews days ago it says "smart failure on hard disk 4-hitachi-(s1). warning:immediately back-up your data and replace your hard disk drive.a failure may...
Your drive is failing and you should back up any important data you need onto CD/DVD or an external USB device (hard drive/pen drive). The drive may keep working for a while but your system is warning you that it has detected a critical error with the drive and failure is imminent.
Jun 10, 2010 | Toshiba Satellite A215-S5822 Laptop
When i boot up i get a message that my hard disk failure is immenent is there anyway to repair this problem
if you get a "Disk Controller Error" error messages that may occur before Windows XP or Windows 2000 is started. Imminent Hard Disk Failure This error may appear when the hard drive detects that it will fail or stop working sometime soon.
Backup Data Before Proceeding Although the notebook may continue to start Windows after displaying the message, it is advisable that you immediately backup your personal data from the PC by copying it to a Network Drive, CD, DVD or USB storage device. After completing the backup, use one of the following methods to resolve the error. Step 1: Test the Hard Drive Use the steps below to test the hard drive in a Notebook PC using the HP Hard Drive Self Test.
  1. Plug the AC Adapter into the Notebook PC.
  2. Press and hold the Power button for 5 Seconds to turn off the PC.
  3. Press and hold the F10 key while you press the Power button to turn on the PC. Release the F10 key after text is displayed on the screen of the PC.
  4. After the BIOS Setup Utility is displayed, use the Right Arrow key to select the Tools menu.
  5. Select Hard Drive Self Test
  6. Press the Enter key to start the test.
The Hard Drive Self Test will provide an Estimated test time . A Quick test, a Comprehensive test, and a SMART test will execute when the Enter key is pressed. If any test fails , order a replacement hard drive. If all of the tests pass, the hard drive is not damaged.
If all tests pass , press the power button to restart the PC. The error was most likely a result of a shock to the PC triggering a SMART error from the Hard Drive. Since the Notebook PC passed the Hard Drive Test, it is safe to use.
Mar 07, 2009 | Acer Aspire 3680 Laptop
Dell Latitude D600
It is the Hard drive on the system. Hard Drive is failing. Another Error code for the Hard Drive is Error Code 7. Check BIOS setup if the system still detects the Hard Drive as well. You may want to consider changing the Hard Drive on the system.
Nov 09, 2008 | Dell Latitude D600 Notebook
Sony vpcyb33kx/b Vaio Y Series Vpc-yb33kx/b - 11.6" - E-450 - Windows 7 Hom Logo
307 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
