Question about Hotpoint TDC32 Electric Dryer
Runs for a few minutes then switches off
Dryer runs for few mins then turns off, press the on switch hear a grumble noise, then turns back on, runs 4 few more mins then off again. Producing good heat works fine accept 4 this
  • gtn301072 Feb 14, 2009
    I have the same problem but it keeps blowing the trip on the house any ideas
There is a relay just inside the control panel at the front ,
it allows the mchine to rotate in both directions
by replacing this it should cure the problem
Posted on Jan 29, 2009
Hi i have a novotronic T560C there is a loud noise that starts after a few mins and moisture on the drum door when I put in dry clothes
Buzzer sounds when the drum turns during the
intermittent anti-crease action period. When the programmable switch is set on the following settings: Normal+, Normal, Hand iron
Refer to page 4 of the user's / owner's manual
Dec 03, 2013 | Dryers
Ge adora dryer model dhdvh52ef0ww runs for about 5 minutes then cuts off
Inside the back and the bottom of your dryer are several ( From 2 to 6 ) "overheat thermostat switches".
One of these is doing it's job really well.
These are designed to prevent your dryer from overheating and catching fire.
I suspect one of them is failing, and needs replacement.
Someone handy with electrical testing tools and mechanic's tools need to take it apart and check these to find the "bad" one.
While they have it all apart, it should need a really good cleaning inside.
Be blessed.
Mar 22, 2013 | Dryers
Dryer wouldnt turn on its saying door is open
most of the time. its the door switch that causes this. if door is closed and it does not start, its the door switch. try this! unplug power, remove the door switch, hook the wires from switch together. this will make a complete curcuit.put black tape on wires so it wont short out. plug back in. it should work, if it runs ok door switch is bad. good-day !
Mar 29, 2012 | Frigidaire Dryers
Runs for 4-5 minutes shuts off. Beat on door and it runs for 4-5 minutes and then won't run for about 20 minutes. Is it the door switch?
Hello
Try taking the door switch out and tieing the wires toghther with a wire nut.UNPLUG DRYER FIRST.
If dryer runs ok then its the door switch.If not then its possible the motor is heating up,you can clean the lint and dust off the motor with a vacum cleaner by taking off the rear panel or turning machine on its side.
Apr 06, 2011 | Amana LEA11 Dryer
I have a kenmore 90 series dryer model 110.60922990. It makes a funny noise while running for a few min. After about 10-15 min it shuts off and will not restart immediately, I have to wait for a few min...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 06, 2011 | Kenmore Dryers
I start time dry for 60 mins. It will run for
The heater element is not heating, they are fragile easy to get to at the back of the dryer. Check the thermal or overheat switch too, but would bet its the heater element.
Nov 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
F1 code on Fisher and Paykel dishdrawer
It would seem to be in an endless loop (firmware glitch). Initially, pls try:
  • unplug from the mains or switch off the breakers for a couple of minutes;
  • plug back in/switch on the breakers say after 20 minutes;
  • press POWER to turn drawer on;
  • Press and hold (at the same time) both the POWER and ECO buttons for a few seconds;
  • a five minute demonstration wash cycle will come on;
  • press POWER again to put unit on standby, all the LCD segments will start flashing (and light up);
  • press and hold START/PAUSE for a few seconds to hear confirmation beep/tune.
Alternately, should you have the two-drawer, open any drawer and look at the wash intensity/economy buttons. Now press them, one at a time, alternating between the two, at even timing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Roper RGX4634KQ will run for 3 minutes then stop.
if you can restart after it stops but have to wait 30 mins or longer suspect bad motor
Jul 21, 2008 | Roper RGX4634KQ Gas Dryer
Hotpoint TDC32 Electric Dryer Logo
246 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
