Cut out in the process of washing,did check the wall plug,and there is power
No power on the machine
  • Washing Mach... Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Posted on Jan 14, 2013
4 Suggested Answers
  • 1294 Answers
SOURCE: Hoover VHD Washing machine
Surely it is the wall socket.
Posted on Mar 19, 2008
blueextc3221
  • 15935 Answers
SOURCE: No power to washing machine
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
  • 6277 Answers
SOURCE: Power on at wall but nothing lights up or works on
Sorry but with such a fault it is virtually impossible for anybody on this FixYa forum to guess remotely what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 12, 2011
Testimonial: "thanks for your help"
My Bosch 1244E will not go on I plug it and no power?
Washing Machine Won't Start - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 21, 2013 - If wall socket & fuse are OK but washing machine won't start ... didn't work - so I tried plugging my Hoover washing machine into another plug and all systems are go! ... I have a bosch washing machine which is 16 months old.
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine will not start, no power. ... So begin at the plugand make sure that there is power to the socket and that the fuse is okay ... I have aBosch washing machine which is leaking from underneath and the water is coming out the front at the bottom. .... It washes but won't go into rinse or spin.
Washing Machine Will Not Start - What To Check - How To Fix
removeandreplace.com/.../washing-machine-will-not-start-what-to-check...
Apr 10, 2015 - Be sure the washer is plugged into the electrical outlet in the wall. ... If the lid switch is faulty, then the washing machine will not start. ... If the lid switch is being pressed but no power is being supplied to the washers motor, ..... October 28, 2014; Bosch Washing Machine Error Fault Codes October 28, 2014 ...
Dishwasher Will Not Turn On - How To Fix ...
Jan 19, 2016 | Bosch Washing Machines
My LG F1247TD5 washing machine has no power only 5 yrs old last month
first check the power supply to the plug in the wall, you may just have a dead machine.
Dec 21, 2014 | LG Washing Machines
I have no power to my washing machine - fuse? Motherboard? Power point is fine.
the fuse in the plug has gone open circuit
check the circuit breaker in the fuse box of your home
sometimes there is a fuse on the plate on the wall
i think the pump is leaking somewhere around the hozes
blown a fuse or something similar
and you need to get back on to the engineer you payed
and get him to do the job right!!!!
Dec 08, 2014 | Washing Machines
Front load GE Profile washing Machine is locked and non- responsive
Try turning the power off at the wall switch so your display goes blank. These locks are safety devices set on a timer which had been affected by your power cut. After about two minutes you should hear a click and the door lock should be released. Hope this helps
Mar 03, 2013 | Washing Machines
Washing machine won't turn on
Hello, first, check the circuit breaker and wall. Make sure the Is power entering into the machine. Or plug another unit to the wall to make sure the outlet is having power. If the outlet has power, that means the power supply of the unit Is with defective. Check the fuse of the machine first.....
Dec 31, 2011 | LG Washing Machines
LG WD-1265TP washing machine household electricity cut out switches off the power
I think that either:
A: you have too many things running on that circuit (space heater perhaps?) or...
B: your washing machine needs a repair.
Best of luck
Dec 18, 2011 | Indesit Washing Machines
I have a front load machine that when you cut it on and it cuts off without finishing the cycle. Not everytime just a few times a week. When it sits cut off for a few hours then it will start working...
Suggestion: Remove the plug from the wall & open up the machine. Check to see if all the connections are plugged in well; especially the one harness leading to the motor. Before that check your washer plug for loose connections; also check your wall socket with another electric gadget - could be a loose connection somewhere.
Feb 10, 2010 | Whirlpool Washing Machines
Had power cut now machine wont work changed the fuse still nothin
check power from the wall socket if its ok the doorlocks and motors are prone to blowing the circut board can be expensive
Jul 30, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Machine not spinning after a power cut
machine can be reset unplug from the wall for 5 mins that will reset com board.
Jan 07, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
